| Helen |
 Helen L Plate Warrior
| alains |
 alains World Chat Champion
| Kickstart |
 Kickstart The Oracle
 Posted: 19:09 - 27 Sep 2004 Post subject: |
The ignition switch works to turn the engine off by earthing the ignition system through it. So if the earth wire to the ignition switch is broken the it will not stop the engine. My guess is that the wiring is broken and just happens to make contact when you turn the bars to the right, or the wire is hanging around and catches on the frame / etc when you turn the bars to the right.
| alains |
| Helen |
| Kickstart |
 Posted: 13:52 - 28 Sep 2004 Post subject: |
Suspect they might just fit a new ignition switch (non original one for the older CG125 is about £11). Chances are that the problem is in the wire from the main wiring loom up to the ignition switch.
For the neutral light the sensor is probably next to the front sprocket. You will see a "bolt" with a small wire going to it. The wire probably attaches to the "bolt" with a small cross head screw.
The last post was made 22 years, 11 days ago. Instead of replying here, would creating a new thread be more useful? |
