Adjusting Valve Clearences/Tappets Honda CD250u
89CBRChris
PostPosted: 15:21 - 27 Sep 2004    Post subject: Adjusting Valve Clearences/Tappets Honda CD250u Reply with quote
Hi,
I am going to have a go at adjusting the valve clearences on me Honda CD250u and just wanted to ask a little advice.
I have had a good read of me haynes manual and am reasonably confident that I should be ok at doing this, however according to the manual I need to unbolt and remove the head of the engine to get to all the adjuster thingies, you should be able to see from attached pic which bit of the engine I mean. now if I remove the head from the engine it also says to carefully remove the seal and replace if neccesary. Now what I need to know is if you think I will need to replace this seal or just reuse the old one, also if I do need to replace this where do I get one from and are they expensive?
Thanks in advance for any advice.
Chris
Scooby
Scrappy Doo
PostPosted: 15:33 - 27 Sep 2004    Post subject: Reply with quote
If you remove the head carefully you can get away with reusing the gasket. Make sure the bike is cold when you check and adjust them, ideally leave it overnight and then do the work before you ride the bike.
89CBRChris
PostPosted: 15:45 - 27 Sep 2004    Post subject: Reply with quote
cool, thanks scooby.
If I make a hash of the removal and screw the gasket, where can I get a new one from and are they easy to get, don't want to screw it up then have a 2 week wait to get a replacement.
oh and will I need a feeler gauge too, if so where do I get one of those (will gerricke sell them?)
Scooby
Scrappy Doo
PostPosted: 15:47 - 27 Sep 2004    Post subject: Reply with quote
Should be fairly commonly available for your bike. Can't see you having a problem getting it off if you take your time, unless someones gashed it up before and used a load of silicon or something to seal it. They are quite expensive though, so try not to damage it Smile
swampy
PostPosted: 15:55 - 27 Sep 2004    Post subject: Reply with quote
You should be able to get a feeler gauge from any tool supplier, even helfords sell them. It might be worth getting a gasket before you start working, then if you screw it up your bike wont be off the road if you have to wait for one to be delivered etc.... Thumbs Up
PS Isn't that bit your taking off the rocker cover ? I thought the 'head' is the cylinder barrel etc only mention it because you need to ask for the right gasket if you do indeed need a new one (I stand to be corrected on that !!)
89CBRChris
PostPosted: 16:16 - 27 Sep 2004    Post subject: Reply with quote
ok cool, i might get one just incase then, I am a bit heavy handed at times and its quite likely i'll bugger it up, i'll have another read of the manual and work out if its head cover/rocker cover etc.
where do you get a new gasket from and what sort of price should I be looking at paying?
mr jamez
PostPosted: 16:26 - 27 Sep 2004    Post subject: Reply with quote
www.davidsilverspares.co.uk ring them up, they should have it.
Smoto Bob
PostPosted: 19:20 - 27 Sep 2004    Post subject: bike Reply with quote
dude thats only the rocker cover mate doesnt even need a gasket really its only to keep crap out and the oil from flying out. it will be fine with out replacing teh gasket
All our xt's have inspection covers so you dont even need to take that off
F'it DO WHAT EVER MAKES YOU HAPPY!!!!! Even if it screws over everyone else :p
Titz wrote: "..and my 3rd accident was when this police car....."
89CBRChris
PostPosted: 19:40 - 27 Sep 2004    Post subject: Reply with quote
cool no gasket required then Thumbs Up
The last post was made 22 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 59.82 Kb
