Just got given a Macbook...
MaybeGuy
PostPosted: 23:00 - 18 Mar 2012    Post subject: Just got given a Macbook... Reply with quote
It's got a cracked screen, but that's all that's wrong with it, so I plan on fixing it.
I hate macs, so won't really be using it. What are these things realistically worth in good working order?
It's pretty old, 2006, and the model is A1181.
tech specs are here.
https://support.apple.com/kb/SP31
and it's the 1.83ghz one.
Frost
PostPosted: 23:40 - 18 Mar 2012    Post subject: Reply with quote
Plug it into an external monitor and then set it up as a web/file server / download box?
Neorion
PostPosted: 09:16 - 19 Mar 2012    Post subject: Reply with quote
Your best bet is to check ebay. Dont use what is my mac worth or any of those sites. They dont take graphics into consideration and usually undervalue.
You could pop a small SSD in it and it would be a speedy netbook.
You could see what it goes for with the cracked screen. Might not be worth your time fixing if you can get a fee quid for it for nothing,
VFR FI 2000- Shiney Red Thing
"some things man was never meant to know, for everything else there's Google"
daemonoid
PostPosted: 16:49 - 19 Mar 2012    Post subject: Re: Just got given a Macbook... Reply with quote
They hold their value well, definitely worth a fix and sell, although the link suggests 2008 and you say 2006? is it definitely intel? 2008 is probably worth £500.
Could probably do without the faffing and still get good money on ebay. Stick it on a £1 NR auction and you could probably get £300+.
current: ducati monster 750
Seb
PostPosted: 10:31 - 20 Mar 2012    Post subject: Reply with quote
If it matches that spec you've linked, with the screen fixed I'd say getting £250 for it would be a pretty good result. Upgrading the ram to 2GB for (mountain) Lion would make it quite a bit more sellable. If you brought it it into my lot we would probably give you ~£150 on the spot for that, likely £100 as is with the broken screen as long as the plastics are reasonable.
Can't really go wrong with an Intel GMA based mac though. Just be sure to check the slot loading superdrive, they are the pinnacle of unreliability.
2010 Triumph 1050 Sprint ST
neil.
PostPosted: 10:56 - 20 Mar 2012    Post subject: Reply with quote
It's a 32 bit CPU (Core Duo) so won't run Lion or Mountain Lion. You're stuck with Snow Leopard.
Shinigami
PostPosted: 11:17 - 20 Mar 2012    Post subject: Reply with quote
set fire to it.
MaybeGuy
PostPosted: 11:23 - 20 Mar 2012    Post subject: Reply with quote
It's my sisters old laptop, and i've had it going off an external monitor. I'll definitely be swapping the screens over. I can get a 13.3 inch wxga for 65 spondoonys, so unless anyone can find cheaper, I guess the next port of call is ebay and praying for £250. Cheers for the info.
It's def. A 2006, the site says it was last revised in 08, so that must have been the last of the a1181's.
Anyone want to swap/px it for a proper laptop when it's finished? Wink
Kingstondavo
PostPosted: 14:19 - 20 Mar 2012    Post subject: Reply with quote
I would be very surprised if you don't get £250 for it, you'd probably get £200 with the cracked screen...
Current Ride - 2010 Hornet 600
The last post was made 14 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.3 - MySQL Queries: 13 - Page Size: 62.29 Kb
