Corner and Gear Selection
Lupine Lacuna This post is not being displayed because it has a low rating (Boring). Unhide this post / all posts.
Dean-J
PostPosted: 08:50 - 20 Mar 2012    Post subject: Reply with quote
Have you ever driven a car you moronic arsewipe? Because guess what, they fucking do it too!
Stop reposting shite you have read on the internet and pretending its your own opinion. we can see through you a mile off by now.
And how the fuck you carried too much "heat" into a corner is beyond me on your little island of retards, with your 40mph speed limit...
Dean-J
PostPosted: 08:52 - 20 Mar 2012    Post subject: Reply with quote
Unless of course you were on your naked bike, which obviously is just as fast as a modern day sports bike eh.... Rolling Eyes
snikks
PostPosted: 10:11 - 20 Mar 2012    Post subject: Re: Corner and Gear Selection Reply with quote
Lupine Lacuna wrote:
I scared myself carrying too much heat into a corner; Because I was in a higher gear than I am used to, I had no engine braking. And engine breaking I like. Can I assume that, always, if you have that scary roll on, you're in too high a gear to:
1. accelerate out efficiently
2. maintain proper traction
3. have greater control
Separately, why do motorbikes brake so much when you are in a lower gear at speed - I have not experienced this in a car
Three points here:
You shouldn't be engine braking around a corner, first of all, what you want is slight acceleration around a corner in order to move weight onto the back wheel which has a wider contact patch (although if you absolutely must slow around a corner, back brake or engine braking is the way to do it, as a rear slide is easier to control).
You should always attempt, therefore, to be at the correct speed and gear for a corner, before you reach that corner. All braking, engine or otherwise, should ideally be completed before the corner (unless you're "trail-braking" which there's no need to really go for on the road, and certainly not at under 40mph).
Cars definitely do engine braking too - it's maybe not quite as pronounced as the car has a lot more weight to push it forwards.
- CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F
PostPosted: 10:20 - 20 Mar 2012    Post subject: Reply with quote
All your roads are slow, meaning your corners are about as fun as sitting on a cactus.
Just keep it in 2nd round your whole island and maintain some throttle.
Too much heat into a corner...Oh, how we laughed
Alpha-9
PostPosted: 10:27 - 20 Mar 2012    Post subject: Reply with quote
Engine braking round a corner is one way to lose traction easily Thumbs Up
Personally I try to avoid using brakes or anything going round a corner, if you need to slow down ease off the throttle, then power out when you're facing the right way
It's not that complicated
Some pre-thought and you should be at the right speed before you begin the turning manuevre, it couldnt be IM TURNING OH GOD TOO FAST DUMP THE GEARS AND BRAKE SWEET JESUS
Fzr-600 1999
J.M.
PostPosted: 10:32 - 20 Mar 2012    Post subject: Re: Corner and Gear Selection Reply with quote
Have you ever changed down a gear in a car at too-high revs? I've experienced it.
1. No, but if your RPM is too low, drop down a gear!
2. No, I can't see how you being in a higher gear will lessen your traction? Confused
3. No, you should be able to control the bike just fine. It's your survival instincts that get in the way
Unless you're literally pushing the bike to it's edge, you can always lean the bike further over and accelerate more to get yourself round a corner. Panic breaking is what makes it scary - it can make you crash, too.
2004 R1 & 2018 XSR900
Sako
PostPosted: 10:37 - 20 Mar 2012    Post subject: Reply with quote
I love this guy's post's, but still think he's not for real...it's not possible!
PostPosted: 11:08 - 20 Mar 2012    Post subject: Re: Corner and Gear Selection Reply with quote
First off, it should never be scary because you're in too high a gear - I would suggest this is your lack of confidence mixed with a slightly different circumstance.
You won't accelerate as hard if you're in too high a gear. Not an issue unless you're "racing".
Can't see why not. Ideally on most bikes you'd be applying gentle power around a corner - on 'most-all bikes, you can still do this in most gears. If you don't do it, unless you're really near the limits of traction, it shouldn't matter anyway. Not an issue for the road.
Only really got greater control to accelerate out. If you have very little control of the brakes, it might give you a bit better control in that you can't lock up a wheel with engine braking (though on many bikes you certainly can make it slide.)
Power to weight ratio I suspect, though it certainly does happen in cars too.
PostPosted: 12:38 - 20 Mar 2012    Post subject: Re: Corner and Gear Selection Reply with quote
Two shotguns?
Careful, if you exceed twenty of her Britannic Majesty's miles per Greenwich Hour, the Gendarmes' sketch-artist might capture your likeness. And then he'll own your soul.
duhawkz
PostPosted: 12:54 - 20 Mar 2012    Post subject: Reply with quote
wait till you over cook it round a blind bend, into the path of an on coming car with your missus on the back. then you'll know what scared is Twisted Evil
Lupine Lacuna
PostPosted: 15:30 - 20 Mar 2012    Post subject: Reply with quote
What I meant was pre corner. I am used to being in low gears revving high and then coming off or sloowing the throttle and the bike slowing considerably, but there are two issues here:
1. there one big long straight, which are dangerous in themselves as I am not at a stage where I can 'feel speed', I find I lose all sense of how fast I am going quite quickly, until I try and slow down and it doesn't seem to be working.... Smile Its also odd how much slower a road feels when it has a good surface than when it is sketchy.
2. I did this coming down from 4th and when coming off the thorttle I was thinking, christ, the bike isnt slowing (like it normally does)
Seperately, I have tiny hands and I think I need to get my breaking lever nearer the bar to make breaking easier.
PostPosted: 15:36 - 20 Mar 2012    Post subject: Reply with quote
You have brakes for a reason; learn to use them.
Engine braking is nice to play about with getting it sideways with a touch of rear brake, but certainly shouldn't be relied upon, whatever the police might say.
PostPosted: 16:02 - 20 Mar 2012    Post subject: Reply with quote
Thank you Mr "I've been riding three months and never gone above 40mph on my Bandit" for giving us old timers pointers on how to ride.
My twelve years of experience on bikes and ownership of 20+ different machines in that time wouldn't have prepared me for the lesson that you've given me. I humbly bow to your superior knowledge.
Oh, and this telegram just arrived for you:
https://www.bikechatforums.com/files/lacuna_136.jpg
PostPosted: 16:20 - 20 Mar 2012    Post subject: Reply with quote
And the six fingers and webbing can't make it easy either.
PostPosted: 18:14 - 20 Mar 2012    Post subject: Reply with quote
Lupine, just for you... and to give my stuff a decent use, I'll record some of our "boring" roads for you at the weekend.
You'll soon see you need to come visit the UK (Don't...but you'll want to)
I'm far from a good rider but I'm pretty sure I can corner Laughing
kestrel
PostPosted: 18:25 - 20 Mar 2012    Post subject: Reply with quote
Or perhaps he'd rather skip your 'boring' NSL roads ##Paddy## and come to the other island, no boring roads here and no NSL either Laughing
Isle of Man.........Road Racing Capital Of The World
janner_10
PostPosted: 18:47 - 20 Mar 2012    Post subject: Reply with quote
Poor bloke, although perversely i look forward to his posts just for the chuckle.
arry
PostPosted: 18:53 - 20 Mar 2012    Post subject: Re: Corner and Gear Selection Reply with quote
It's not actually engine braking, it's air braking - the air is hitting your meat head and slowing you down a treat. In a car you have a windscreen to stop this happening.
Hope that helps.
Paulington
PostPosted: 19:47 - 20 Mar 2012    Post subject: Reply with quote
From my RoSPA/IAM training:
Gears are to GO, brakes are to SLOW.
Use your brakes to slow down. Only use engine braking when it is efficient to do so, I mainly use it for roundabouts and going down hills. Remember, when you are using engine braking to slow down the cars behind you have no brake light to tell them that you are braking so those that aren't paying much attention (Read: almost all of them) are much likely to rear end you.
Second bit of advice:
IPSGA
I- Information
P- Position
S- Speed
G- Gear
A- Accelerate
If you run through that in your head whilst you are approaching junctions/hazards/every few seconds on the road then you will find that you find yourself driving much smoother, being much more prepared and not having to make any sudden moves/being surprised a lot less and generally being a better driver.
I also find it makes me drive/ride a lot slower too, this is partly because it's just as fast when you pay a lot of attention and because the kind of attention you need to pay to be overly safe on the road that my advanced driving has drilled into me actually requires a lot of conscious effort and needing to be able to stop in the distance you can see to be clear tends to slow you down.
You can't really generalize such that 'motorbikes have more engine braking than cars' as it depends on so many factors such as weight, engine displacement, gear, compression ratio and a whole lot more. Get in a car doing 30mph, put it into first and let the clutch out. You'll feel the engine braking.
If you scared yourself by carrying excess speed into a corner, then chances are you weren't paying adequate attention to the road/your driving because if you were you'd have started braking long before the moment that if your brakes didn't work, you were buggered and if you were paying attention and the engine braking wasn't as strong as you thought you'd have slammed on the anchors.
Maybe take some training? RoSPA is free after you've joined a local group (apart from maybe covering the tutor's fuel fees) for all the training and only £45 for the test if you wish to take it. If you do so, you'll find that you get surprised on the road a whole let less.
Cheers!
T0MMY
PostPosted: 22:04 - 20 Mar 2012    Post subject: Reply with quote
Christ, dump the clutch in first at 30mph in a car and you might feel the engine breaking.
ZX6R + CBR600RR
bLiXeY
PostPosted: 22:44 - 20 Mar 2012    Post subject: Reply with quote
Lupine, is it like 'The Wicker Man', on your island?
(The original of course, not the remake.)
edb
PostPosted: 22:53 - 20 Mar 2012    Post subject: Reply with quote
Everything paulington said times a million. Except the 1st gear business maybe Confused
Old Git Racing
PostPosted: 23:21 - 20 Mar 2012    Post subject: Reply with quote
Engine braking into a corner is important, even if you are using the brakes, ever hit a false neutral? If you are in a higher gear than you thought or a lower one for that matter then you will go in at the wrong speed , panic, and hit the brakes or lose the back most likely. Bet there's a few on here done that.
The difference between bikes and cars is the weight and momentum caused by it, less weight = more effect in terms of engine braking so you are bound to notice it more on a bike.
To the o.p. It happens, we all make mistakes, even the heroes on here replying to your question. The secret is to learn from it and put the experience to use next time it happens, to get a bit more feel for it cos thats what riding a bikes all about, feel. Until it comes naturally you have to concentrate a bit and accept you will f*ck it up occasionally. Just don't be going too hard when that happens or you'll be joining the spill counter.
As for training, yeah do some if it appeals but when it comes right down to it, it's down to you. I know people who have done IAM after been riding bikes for 2-3 years and are now observing and telling people what they do wrong. Joke. Crying or Very sad
Keep trying, get the experience, stay alive.
OGR
duhawkz
PostPosted: 23:58 - 20 Mar 2012    Post subject: Reply with quote
Here's a download link for the twist of the wrist dvd
https://torrentz.eu/314d4c7c07d0a7edc0f81fedfc8e6ea6a308f4bb
https://www.torrenthound.com/hash/cd00b34a18329e40d4e78a763e8f364d2b212040/torrent-info/A-Twist-Of-The-Wrist--Vol2-pdf
And one for twist of the wrist 2 PDF have a watch/read they have some good information.
As others have said above and is mention in twist of the wrist all your your braking, gear changing etc should be done before you enter the corner. It's all about been smooth.
The last post was made 14 years, 196 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 135.52 Kb
