180/55/17 or 190/55/17 Rear Tyre??
Lynchasaurus
PostPosted: 23:33 - 20 Mar 2012    Post subject: 180/55/17 or 190/55/17 Rear Tyre?? Reply with quote
Currently I'm running a 180/55/17 tyre (Bridgestone battlax) on my z750, and was wondering what difference it would make if I got a 190/55/17 tyre and how it would change the feel of the bike in cornering and if it would even fit with enough clearance from the swing arm, chain etc. ??
Any advice is welcome....
gray84
PostPosted: 23:38 - 20 Mar 2012    Post subject: Reply with quote
I'm not full of knowledge but my r6 come with a 190 and I fitted a 180. It turned into the bends much easier. Almost like it wanted to go round bends. I noticed this when I was fairly newish to bikes and didn't read up on it. Just from experience.
binge
Emo Kiddy
PostPosted: 23:49 - 20 Mar 2012    Post subject: Reply with quote
190/55 is the BSB size IIRC.
Going from 180/55 to a 190/55, will raise the back end a little, probably make it a little harder to turn in quick, but it will make it a little more stable at high speed on sweeping bends etc. Providing your rear wheel is wide enough to take the extra size in tyre.
190/50 is a whole different kettle of fish.
It has a smaller profile than the 180/55, and it's wider, making it more lardy,and lower at the back end.
My R1 is on a 190/50, and I am looking to go 180/55. Much better size.
I'd stick with what you've got. Thumbs Up
Lynchasaurus
PostPosted: 00:06 - 21 Mar 2012    Post subject: Reply with quote
Cheers mate, I just heard of someone doing it and was curious of the pro's and con's to having a wider tyre,
Thanks
bacon
PostPosted: 00:09 - 21 Mar 2012    Post subject: Reply with quote
190 section tyres are for 6" rims
180 section tyres are for 5.5" rims
Stick to the stock size for your bike
bacon
PostPosted: 00:12 - 21 Mar 2012    Post subject: Reply with quote
Raising the rear of a bike has the opposite effect you are suggesting, it will increase turn in speed and decrease stability
If you are on a 6" rear rim, fitting a 180 section tyre (that is designed for a 5.5" rim) will leave that tyre flattened out a bit and you will lose any increases in handling by changing to a steeping 180/55 profile. If you want a steeper profile go 190/55
binge
Emo Kiddy
PostPosted: 00:14 - 21 Mar 2012    Post subject: Reply with quote
Yes I know, But he's also going to be fitting a wider tyre, which is also being squashed onto a rim made for a 180 tyre.
190/55 probably wont clear the hugger on my bike either, hence 180/55, on the basis that it'll fit the rim properly.
bacon
PostPosted: 00:17 - 21 Mar 2012    Post subject: Reply with quote
So I would imagine it would be end up steeper still after the wider tyre is squeezed onto the thinner one?
I really cant see the point adding a 180/55 onto a rim designed for 190 section tyres, the 180 will end up squashed out and lose its intended profile, and the bike will lose height at the rear as a result probably even compared to a 190/50 section tyre?
Lynchasaurus
Well the z1000's run a 190 rear tyre standard and both bikes are identical apart from power, and wheels obviously so putting a 190 tyre on my bike can't be all bad if they have put it on the z1000's which are supposed to be better then the 750's??
bacon
PostPosted: 00:19 - 21 Mar 2012    Post subject: Reply with quote
Are you saying both the z750 and z1000 have the same size rear wheel? (not diameter, i mean width) yet use different tyre widths? I doubt it
190 section tyres are usually added to larger bikes to increase their contact patch to the road
Lynchasaurus
That's assuming I get some wheels off a z1000 aswell so the tyre fits properly**
bacon
PostPosted: 00:21 - 21 Mar 2012    Post subject: Reply with quote
lol doesnt seem worth the effort for a slightly bigger contact patch and slightly raised rear? If you want to raise the rear for quicker handling why not use some different dog bones to do it.
Lynchasaurus
PostPosted: 00:22 - 21 Mar 2012    Post subject: Reply with quote
Stop replying so fast! Haha
I can't find the rim sizes but the 1000 rim must be a 6" then.
Lynchasaurus
PostPosted: 00:23 - 21 Mar 2012    Post subject: Reply with quote
I did raise the rear before slightly but then people started saying I was trying too "street fighter" my bike /: haha
binge
Emo Kiddy
PostPosted: 00:24 - 21 Mar 2012    Post subject: Reply with quote
Which would then mess up the rear spring rate.
If ya wanna get down to the nitty gritty. Wink
Lynchasaurus
PostPosted: 00:26 - 21 Mar 2012    Post subject: Reply with quote
I was only asking what the difference was between a 180 tyre and a 190, haha
bacon
PostPosted: 00:33 - 21 Mar 2012    Post subject: Reply with quote
lols, maybe it should go back to the OP and ask him whats wrong with his bike as it is? Laughing
Lynchasaurus
PostPosted: 02:17 - 21 Mar 2012    Post subject: Reply with quote
Nothing's wrong with my bike! LOL
I just wanted to no why bigger bikes run 190 tyres and mine only has a 180....
Wanted too see what I was missing out on....(:
bacon
PostPosted: 04:46 - 21 Mar 2012    Post subject: Reply with quote
More power, so they use a larger tyre to increase the contact patch for more grip, thats all
PostPosted: 08:17 - 21 Mar 2012    Post subject: Reply with quote
GSXR K1-K3 are supposed to have a 180 rear, I use 190's.
Wheel is same size on the older Y model which came with a 190 stock.
I believe a 190 gives less contact when upright?
evoboy
PostPosted: 11:58 - 21 Mar 2012    Post subject: Reply with quote
A 190 in theory should give more of a contact patch at most lean angles.
Cant say ive really noticed a difference between the 2, other than on my old zx6 i used to run close to the edges of the 180 on track and it would cause it to slide/drift ( gotta love supercorsa's!). On 190's that never really happend...
APT Motorcycles
PostPosted: 12:05 - 21 Mar 2012    Post subject: Reply with quote
I have a set of those in the garage Luke Laughing 120 70 and 190 55?
PostPosted: 12:52 - 21 Mar 2012    Post subject: Reply with quote
I think it will probably ruin the handling of the bike... or what little there is on a z750 anyway.
Mikey3
PostPosted: 12:53 - 21 Mar 2012    Post subject: Reply with quote
It's probably a 180 as standard, so i'd keep it to 180, like said above, helps in bends a LOT and a 180 is hardly skinny so you can't upsize on the argument of 'its more stable in a straight line'... bollocks.
Stood still it looks more 'MANLY' but you'll look less 'MANLY' when you get out cornered when you're actually riding Wink.
My mate had one on his gix 750 and he said it looked cool but felt horrible to lean into corners, said it just didn't want to.
Really the negatives well outweigh the single poser positive.
Mike
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
The last post was made 14 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 120.03 Kb
