clutch release mechanism (worm)
flumpy7
PostPosted: 20:47 - 24 Mar 2012    Post subject: clutch release mechanism (worm) Reply with quote
Hi all
Had to change the front sprocket cover on a gsx750f which involved removing the clutch release mechanism-worm screw thing to install it on the inside of the new cover. Having removed it, all the little ball bearings just fell out of it. What a bastard...any ideas why this should happen? It was all nicely greased by the looks.
Anyway, i have ordered a new one and just wondered if it comes ready adjusted or will it need some adjusting to get it to move the pushrod properly? I dont wanna muck about with it too much incase all those little ball bearing fuckers fall out again!
I'll find out in due course when i come to install it but just wanted to be prepared. Thanks!
2012 Sinnis apache
P.
PostPosted: 20:52 - 24 Mar 2012    Post subject: Reply with quote
Fitted one recently as mine did the same.
Put it in its little hole after giving it a nice dose of grease. You'll need to adjust it correctly so it pushes on the rod at the correct time, otherwise you'll get what I got, slipping clutch Laughing
flumpy7
PostPosted: 21:15 - 24 Mar 2012    Post subject: Reply with quote
Thanks for that. So do you mean adjust it once the cover is fitted (by removing the rubber bung and adjusting the screw) or is there a way you can get it just right before installing the cover?
2012 Sinnis apache
P.
PostPosted: 22:13 - 24 Mar 2012    Post subject: Reply with quote
Once its all together and you have got the cable set to no adjustment on your clutch lever, then whip the rubber off and adjust.
flumpy7
PostPosted: 19:04 - 25 Mar 2012    Post subject: Reply with quote
Cool thanks Thumbs Up
2012 Sinnis apache
The last post was made 13 years, 125 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.38 - MySQL Queries: 13 - Page Size: 43.83 Kb
