Author |
Reid |
 Reid Nitrous Nuisance
Back to top |
jjdugen |
 jjdugen World Chat Champion
Back to top |
Reid |
 Posted: 11:33 - 25 Mar 2012 Post subject: |
Hub centre steering would be way out of my league so I'll have to leave that... for now
So how does the 3MA deal with these issues? I know the carbs are ridiculously low to the ground to deal with headstock issues, the exhausts flow around the actual seat and have a simple shield - is there anything more technical than that (fitting carbs so they don't foul the steering and making sure the exhausts aren't likely to melt you)?
I'm still kind of unsure on the benefits reversing the cylinders achieves. Are there any apart from being unconventional for the sake of it? I don't want to end up with a pure cosmetic showpiece, I want there to be at least a little logic to anything I attempt with it  |
Back to top |
Reid |
Back to top |
Kickstart |
 Kickstart The Oracle
 Posted: 11:57 - 25 Mar 2012 Post subject: |
Useful airbox is probably the hardest part (at least on a 2 stroke you have more flexibility on where you mount the carbs). As Chris says finding a suitable doner engine will be a pain, and then you have the fun of custom camshafts to sort the valve timing out again and have appropriate profiles for them to open / close. Even with something like a GPZ500 (central cam chain) I suspect that the sprockets on the cam shafts are slightly offset for clearance.
Cagiva managed to have under twin seat exhausts on the early C9 Freccia 2 stroke single, and that came out in 1986. Next thing girder forks will come back into fashion .
Back to top |
Kickstart |
Back to top |
G |
 G The Voice of Reason
Back to top |
Reid |
 Posted: 12:13 - 25 Mar 2012 Post subject: |
Okay - in that case I'll ditch the idea, just came to me the other night and I thought "why not?". Thanks for talking me back to reality
Out of curioisty though, I'm still a bit unsure of the benefits it'd pose - is it just the fact it opens it up to induction and cuts a bit of length/weight out of the exhaust? |
Back to top |
G |
Back to top |
Kickstart |
Back to top |
Frost |
 Frost World Chat Champion
Back to top |
kestrel |
 kestrel Nearly there...
 Posted: 18:28 - 25 Mar 2012 Post subject: |
Triumph 650cc engines quite often had the heads reversed in the 70's, some as custom mods and others in twin engined drag bikes. Twizzle down in bournemouth reversed the head on a GSX1100 on his bike known as 'The Beast' pic here :-
https://www.myspace.com/twizzlecustoms/photos/31079#%7B%22ImageId%22%3A31079%7D ____________________ Isle of Man.........Road Racing Capital Of The World |
Back to top |
The last post was made 13 years, 117 days ago. Instead of replying here, would creating a new thread be more useful? |
