Few questions about Hyosung GT 125 R
carb0n
PostPosted: 13:13 - 26 Mar 2012    Post subject: Few questions about Hyosung GT 125 R Reply with quote
So i got the bike this weekend, 10 plate. 1500 miles on. Spent all weekend riding her, and i have discovered a few things. If you need to know anything else to give an answer let me know Smile
1) the front break sounds like its grinding when used. (like a bit of dirt is stuck and making a grinding sound)
2) sometimes when pulling away the engine dies a little, is this the engine flooding? sometimes happens from 2nd to 3rd
3) i know its a heavy bike for a 125. But is there anything you can do to increase the acceleration without losing top speed?
Thanks Smile
PostPosted: 13:19 - 26 Mar 2012    Post subject: Re: Few questions about Hyosung GT 125 R Reply with quote
Thanks Smile
1 > strip and clean the caliper, common issue on this.
2 > lift the tank off and see if the muppet has fitted some gash filter, also pull the front spark plug out and see what colour it is.
3 > No, the best way is to do your test. My GT125 (non R model) had an indicated 90+ GPS had it at 82mph down a hill with 2 people on it, had a straight through set of pipes with a scorpion end can, rejet and a K&N from an SV650.
carb0n
PostPosted: 13:35 - 26 Mar 2012    Post subject: Re: Few questions about Hyosung GT 125 R Reply with quote
Thanks Smile
once i get home from work ill have a look. doubt i'll be able to have a look at the engine until the weekend though.
Also how much do you think it would cost to take it to a garage and get it race tuned? if its a stupid amount ill just wait for more power until summer when i take my test Smile
c_dug
PostPosted: 13:55 - 26 Mar 2012    Post subject: Reply with quote
Without even looking at prices, just wait, it won't be worth it tuning.
PostPosted: 14:02 - 26 Mar 2012    Post subject: Reply with quote
You wont get it race tuned.
The cheaper way would be to buy a 250cc engine and whack it in, you'd need to buy new chain/sprockets as its a 520 pitch rather than a 428.
You'd also want to grind the 250 badge off the side, and change the engine number...
Its a simple swap...not that I'm saying do it... Wink
PostPosted: 14:44 - 26 Mar 2012    Post subject: Re: Few questions about Hyosung GT 125 R Reply with quote
That would suggest anyone raced them.
And that if they did, that it wasn't a series which restricted modifications so your 'race tune' may just be a stock bike Smile.
If you want more power in a 125, best bet would be to sell it and buy a 2 stroke.
You'll get a lot more power which will be more reliable than if you got the 4 stroke up anywhere close - also less weight and quite likely better handling and brakes.
PostPosted: 15:02 - 26 Mar 2012    Post subject: Reply with quote
You're onto your second 125 and haven't passed your tests yet?
You've brought this on yourself...
Teflon-Mike
Teflon-Mike
Teflon-Mike
carb0n
PostPosted: 15:19 - 26 Mar 2012    Post subject: Reply with quote
Teflon-Mike
Teflon-Mike
Teflon-Mike
i brought this so i can get used to a heavier bike, and sports position... i will be doing my test in the summer, so feel free to chuck any more abuse my way, cause tbh, it really doesn't bother me at all.
PostPosted: 15:45 - 26 Mar 2012    Post subject: Reply with quote
Its not an overly heavy bike compared.
I didn't mind mine... but I'd seriously consider putting in for your test Smile
PostPosted: 16:01 - 26 Mar 2012    Post subject: Reply with quote
Listed as pretty heavy, but seems a complete waste of time when the best way would be to pass your test and get a bigger bike.
From what I've seen the GT125r isn't really that 'sporty'.
Could have stuck some weights and lower clip ons onto the YBR if that's what you wanted Smile.
carb0n
PostPosted: 16:11 - 26 Mar 2012    Post subject: Reply with quote
i just wanted to get a "better" bike for the summer Smile cause at the moment i cant really get time off work to get my test done. So i have to make do with what i can get Smile Heads turn when i ride now Smile i hope for good reasons Smile its the feeling i wanted Smile
PostPosted: 16:13 - 26 Mar 2012    Post subject: Reply with quote
Get a nice exhaust for it Wink
carb0n
PostPosted: 16:26 - 26 Mar 2012    Post subject: Reply with quote
that's the head turner Wink got a scorpion exhaust without the baffle Very Happy sounds like a 600 <3
Paddy, what part of UK you from?
PostPosted: 16:28 - 26 Mar 2012    Post subject: Reply with quote
From Kent.
I had a Scorpion, doesn't sound like a 600, trust me. May look it though. Once you hear a 600 and have it between your legs... Thumbs Up
carb0n
PostPosted: 16:34 - 26 Mar 2012    Post subject: Reply with quote
##Paddy## wrote:
From Kent.
And for that day. I cant wait Smile
i take it you're never in the midlands then being all the way down south Razz
PostPosted: 16:36 - 26 Mar 2012    Post subject: Reply with quote
Never ever going to the midlands. Laughing
I like my bike thanks Wink
It probably isn't that bad. You coming to BCF BBQ? Laughing
PostPosted: 16:43 - 26 Mar 2012    Post subject: Reply with quote
Then don't. It only takes 20 minute to pass Mod 1 and an hour for Mod 2 and theory. They run 6 days a week. Claiming that you can't find the time to pass them is ridiculous.
carb0n
PostPosted: 16:47 - 26 Mar 2012    Post subject: Reply with quote
Where is it held?
"Then don't. It only takes 20 minute to pass Mod 1 and an hour for Mod 2 and theory. They run 6 days a week. Claiming that you can't find the time to pass them is ridiculous." i know Sad another reason is cause i have a weak wrist at the moment and i cant ride for long periods of time without pain :/ need to let it get a bit better before i try for my test cause i really don't want to balls it up Smile
PostPosted: 16:49 - 26 Mar 2012    Post subject: Reply with quote
LOLWOT?
PostPosted: 17:22 - 26 Mar 2012    Post subject: Reply with quote
Sorry, but no.
I've heard enough 125 4 strokess with loud exhausts - mostly they sound chavvy, though as a twin the GT isn't quite as bad as the singles which you'd think were just pit bikes.
Plenty of non-bike people will no doubt see your bike and think "big bike". Plenty of bike people will no doubt see you've got a heavy, big 10 plate 125 and think "tosser with too much money" Smile.
Usher4566
PostPosted: 18:09 - 26 Mar 2012    Post subject: Reply with quote
I think what ever bike watever size can make you smile .I've had plenty of big bikes 600cc's plus even a thou .I've got and old benly at min its gutless they all are but it can make me smile.and your 125 is Probs the same it makes you smile
New cd200 benly owner
PostPosted: 19:13 - 26 Mar 2012    Post subject: Reply with quote
You can make excuses from now until the end of the world (this December, right?) but if you can ride a bike, then you can pass your tests. It's entirely up to you of course, but nothing looks good with L plates on it.
iMark
PostPosted: 19:37 - 26 Mar 2012    Post subject: Reply with quote
Teflon-Mike
Teflon-Mike
Teflon-Mike
You forgot the mirror Razz
K8 GSXR 1000
carb0n
PostPosted: 21:50 - 26 Mar 2012    Post subject: Reply with quote
G wrote:
Sorry, but no.
i don't have too much money Razz i saved up 3 months wages for it.. i just dont waste my money on random crap like most 19 year olds do Smile
but i promise you. it doesnt sound chavy. my dads been a biker all his life. current bike GPZ 750 Turbo.. he said him self sounds like a much much bigger bike... anyway throw what ever hate you want Very Happy love you all Smile all part of the biking family <3
The last post was made 14 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 132.14 Kb
