| International... |
 International... L Plate Warrior
| wilcox.ian |
 wilcox.ian Two Stroke Sniffer
 Posted: 00:25 - 27 Mar 2012 Post subject: |
take all the bulbs out and put the fuse in, switch on the ignition and lights, does it still blow?
turn off ignition, put in the side light, turn on ignition and lights, does it blow?
turn off ignition, put in dip side bulb, turn on ignition and lights, does it still blow?
repeat with the main beam bulb.
doing it this way will at least narrow it down to which (if any) bulb it is, if none, grab a wiring diagram and see what's wired into the same circuit  ____________________ -=Facebook=-
-=[url=www.basement-bikes.co.uk]Basement Bikes eShop/[url]
-=Lurch=- |
| Vincent |
 Vincent Banned
 Posted: 01:07 - 27 Mar 2012 Post subject: |
You could also check the battery Pos + wire, make sure it's not chafing on the frame, and wires around the headstock, wires coming from the stator/generator, check inside the switches, reposition the loom to see if it helps. Use the correctly rated fuse wire rather than fuses while trying to find the problem, should save a bit on fuses  ____________________ Space Is Deep |
| wilcox.ian |
 Posted: 09:14 - 27 Mar 2012 Post subject: |
do you have a tester? would be a lot cheaper than blowing bulbs one by one  ____________________ -=Facebook=-
-=Lurch=- |
| P.addy |
 P.addy Red Rocket
 Posted: 09:17 - 27 Mar 2012 Post subject: |
Take alook at the headlight wires. They run close to the subframe.
Check the battery teminal/starter solenoid and the rear light.
Wires are really tight on the CBRs  |
| International... |
 Posted: 13:19 - 02 Apr 2012 Post subject: |
Thanks for the tips guys, after looking at it I couldnt see anything wrong so I put it in the shop for them to look at... it turns out that the previous owned who fitted an aftermarket bracket accidently put a screw through some wiring *muppet*
All fixed now  |
| WetSparks |
 WetSparks Renault 5 Driver
The last post was made 14 years, 188 days ago. Instead of replying here, would creating a new thread be more useful? |
