It's not big, It's not clever but boy it's satisfying!
Fisty
PostPosted: 22:01 - 27 Mar 2012    Post subject: It's not big, It's not clever but boy it's satisfying! Reply with quote
https://i302.photobucket.com/albums/nn82/mr_fisty/photolkkjnbg.jpg
https://i302.photobucket.com/albums/nn82/mr_fisty/photokjkj.jpg
https://i302.photobucket.com/albums/nn82/mr_fisty/photozasde45.jpg
Tis' how we make the sea fog on the river severn!
Fatter and faster than Fret
Babba This post is not being displayed because the poster is banned. Unhide this post / all posts.
Gazz
PostPosted: 22:11 - 27 Mar 2012    Post subject: Reply with quote
Babba wrote:
Old & worn tyres should be disposed of with carefull respect to the environment Very Happy
It was... The wind was blowing those smoke clouds over into Wales!
Kris
PostPosted: 22:15 - 27 Mar 2012    Post subject: Reply with quote
Mmmmmmmm tyres... Mr. Green
www.prisonplanet.com
Recluso
PostPosted: 22:40 - 27 Mar 2012    Post subject: Reply with quote
So THAT'S why you're changing your tires in the morning, is it? Razz
'Just erotic. Nothing kinky. It's the difference between using a feather and using a chicken.'
Honda PS125i > Yamaha YBR125 > Yamaha XJ6 Diversion > Yamaha Tracer 900
Tenko
PostPosted: 23:32 - 27 Mar 2012    Post subject: Reply with quote
...and I thought it'd be about having a wank in a public library.
PostPosted: 00:02 - 28 Mar 2012    Post subject: Re: It's not big, It's not clerver but boy it's satisfying! Reply with quote
Most definitely not big or clever with your feet on the floor.
Pick your feet up boy and do it properly! Razz
(Though, I will add a special exemption if you got it up to the limiter in 6th - did this on my zx9 and managed to dig a decent bit of a hole in the tarmac. Also cause some concern to the petrol station down the road - which the large cloud of smoke was blowing through.)
Fisty
PostPosted: 09:42 - 28 Mar 2012    Post subject: Re: It's not big, It's not clerver but boy it's satisfying! Reply with quote
6th gear and an indicated 170mph!! It went through to the metal in the carcass and started sparking, melted a hole in the tarmac and made a huuuuuuuge cloud of sweet smelling rubber smoke!
PostPosted: 10:00 - 28 Mar 2012    Post subject: Re: It's not big, It's not clerver but boy it's satisfying! Reply with quote
Ok, but; you didn't pop the tyre?
Give five man points back!
I had the perfect situation when walking my bike back with a split down half the tyre and it somehow turned inside out (just down the road) and a biker stopped to ask if I need help; "Oh, don't worry just seem to have got a puncture, almost home so will get it sorted there" :troll:.
pepperami
PostPosted: 10:23 - 28 Mar 2012    Post subject: Reply with quote
We should`nt encourage silly and environmentally bad behaviour but what the hell Smile Thumbs Up .
Consider yourself severly told off Smile
Acemastr
PostPosted: 10:53 - 28 Mar 2012    Post subject: Reply with quote
for fear of taking off and/or blowing a clutch up, I don't dare do this Very Happy
Looks impressive!
2016 Toyota Tacoma Limited
PostPosted: 11:45 - 28 Mar 2012    Post subject: Reply with quote
Clutch would only be a problem on starting it - once it's going it's not an issue (use clutchless changes going up the gears if you're killing it, obviously).
It's unlikely from 170mph the bike would get grip - more likely if you let the front brake off you'd just start moving forward in a rolling burnout. If you let the brake off and let the revs fall, possibly then, though in sixth gear less likely.
So Tut Tut no excuses Wink.
shereen
PostPosted: 12:17 - 28 Mar 2012    Post subject: Re: It's not big, It's not clerver but boy it's satisfying! Reply with quote
G wrote:
Ok, but; you match your leathers to your bike?
Fixed Thumbs Up
Acemastr
PostPosted: 12:37 - 28 Mar 2012    Post subject: Reply with quote
so... Front brake hard on(ba dum), lots of revs, clutch out fairly quickish, if front starts moving then clutch in ASAP?
h00dwink
PostPosted: 12:50 - 28 Mar 2012    Post subject: Reply with quote
clutch out fairly quick would probably see you doing a swift backflip.
front brake on, weight on front, build revs, ease out clutch until rear starts to bite then continues to just spin up, ease off clutch and enjoy smoke.
Sahf East Winnah 4LYF
https://bikepics.com/members/h00dwink/00sv650s/
www.youtube.com/h00dwink updated regularly
PostPosted: 12:51 - 28 Mar 2012    Post subject: Reply with quote
It's ok to slip the clutch to get it going and this is how I generally do it.
It will put a bit of wear on your clutch - but so will a fast get-away.
The bike you've got depends the revs needed. On the zx9 it was just a case of a teeny bit of slip at lower revs. On a lower powered bike, might need more revs and slipping to get it going and keeping the revs up a bit to stop it stalling.
Then progress to moving with your feet down, then your feet up, then turning with your feet up, etc Smile.
PostPosted: 15:55 - 28 Mar 2012    Post subject: Reply with quote
I just know if I tried this I would do the fastest drag start ever, straight into the closest tree or lamp post!
Fisty
PostPosted: 08:14 - 29 Mar 2012    Post subject: Re: It's not big, It's not clerver but boy it's satisfying! Reply with quote
Fixed Thumbs Up
Actually my bike matches the jacket, I had the jacket first so Razz
CaNsA
PostPosted: 08:17 - 29 Mar 2012    Post subject: Reply with quote
Fister, I am disappoint there is no video Sad
The last post was made 14 years, 216 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 102.78 Kb
