Cornering and braking
Screw Loose
PostPosted: 22:21 - 28 Mar 2012    Post subject: Cornering and braking Reply with quote
Ladies & Gentlemen of BCF,
something which has had me wondering for the last few weeks is that if i accidently enter a corner too fast, and so need to slow down a bit, how do i do so? obviously letting off the throttle is one way, but I was shown on my CBT the dangers of braking whilst turning, so question is, how the hell can i slow myself down without going arse-over??
Thanks,
Veho
Themightyimp
PostPosted: 22:25 - 28 Mar 2012    Post subject: Re: Cornering and braking Reply with quote
Thanks,
Veho
If you really must brake during a corner,i've been lead to believe you should use your rear brake,due to the fact it's easier to control a rear lockup if you over do it.Wether it's correct or not I don't know.
J.M.
PostPosted: 22:35 - 28 Mar 2012    Post subject: Reply with quote
If you accidentally enter a corner too fast, one of the worst things you can do it try to slow down. You'll probably end up making your corner wider and going off.
Best thing to do is lean the bike over more. Unless you're riding the bike to its absolute limits, it'll be able to learn further than you're confident pushing it. Leaning your body forwards on the bike whilst holding a steady corner should also tighten your turn a little bit.
On the other hand, if you need to slow down for a hazard, try and get the bike as upright as you can and use both brakes.
2004 R1 & 2018 XSR900
Themightyimp
PostPosted: 22:44 - 28 Mar 2012    Post subject: Reply with quote
Good job someone who knows more than me has replied to you.
lihp
PostPosted: 22:59 - 28 Mar 2012    Post subject: Re: Cornering and braking Reply with quote
If you're really in that quick the bike cannot turn any more, then chopping the throttle will overload the front just like pulling the front brake, all weight will transfer forwards and down you will go.
recman
PostPosted: 23:05 - 28 Mar 2012    Post subject: Reply with quote
So basically, don't enter a corner too fast?
Too much of anything is bad for you. Wink
Kal
PostPosted: 23:06 - 28 Mar 2012    Post subject: Re: Cornering and braking Reply with quote
Or it will run wide in the turn and go to the outside.
It is possible to brake in a turn, and to be honest you probably will.
One of two things will happen. You will go down, or you will manage it and need to change your underwear.
However, your best response is to push the handlebar on the inside of the turn away from you and the bike will drop lower into the turn.
Kal...
PostPosted: 23:13 - 28 Mar 2012    Post subject: Re: Cornering and braking Reply with quote
This is the best answer so far. Counter steering conscientiously. Its saved me once or twice, you just have to get over the mental "OMG I must push the handlebars in the opposite direction" and you'll be fine.
Make sure you are looking where you want to go. A lot of times if you think you have overcooked it you tend to stare at the edge of the road that you are trying to avoid and that creates target fixation, make sure you look around the corner and where you want the bike to go.
Kal
PostPosted: 23:24 - 28 Mar 2012    Post subject: Reply with quote
_Iain_ wrote:
Front brake makes you go wide, proper fucks you up. Had a big issue with this my first week or two. apparently makes you fall off too. I'd not advise this!
Rear brake can fuck your day up in highside kind of way if you are heavy with it.
The reason you run wide when you use the brakes is that the bike stands up because of loss of speed, same as rolling off throttle can send you wide.
Rolling on the throttle can actually tighten the bike into the turn.
In general, and corners in particular;
Bike controls are analogue not digital. If you use them like on/off switches you will get fucked up - trust me I have that Tshirt.
However if you use them gradually and smoothly you can get away with a lot more and your riding (not to mention fuel/tyres etc) will be a lot better for it.
When it comes to bike controls your survival instinct will do you no favours as your natural reaction ie: cut the throttle, hit the brakes etc will be the wrong thing to do.
Its a learning process.
Oh and what the man above said, yes target fixation will cause you to crash into the thing you are looking at.
Kal...
PostPosted: 23:26 - 28 Mar 2012    Post subject: Reply with quote
I'm with Kal here. Rolling on while pushing the bar on the inside forward actually makes the turn tighter. Funny and strange but true.
Kal
PostPosted: 23:32 - 28 Mar 2012    Post subject: Reply with quote
pinkyfloyd wrote:
I'm with Kal here.
Oh dear, you really are fucked.
Kal...
J.M.
Me too.
Also, I'd advise against the rear brake as well. I used to have a problem with this, fast (~60mph) roundabout corners have been much tighter now that I don't Thumbs Up
Themightyimp
PostPosted: 23:37 - 28 Mar 2012    Post subject: Reply with quote
Thanks guys for answering the OP.I have really learnt something tonight.Hopefully i'll now take corners faster with learning how to put into practice what you guys have said.I'm only 3 weeks into a full licence.
Nexus Icon
PostPosted: 23:44 - 28 Mar 2012    Post subject: Reply with quote
I try and get all the braking and screaming out of the way before having to fully commit to getting round the odd corner that's sprung out of nowhere.
TBH, I stuck to routes I knew well for the first month or so just to avoid the surprise corner syndrome.
Greetings from Shitsville!
Themightyimp
PostPosted: 23:52 - 28 Mar 2012    Post subject: Reply with quote
I'm guilty of all of this,other than I haven't come off yet.lol
PostPosted: 00:04 - 29 Mar 2012    Post subject: Reply with quote
Lean more. If you lowside, you'd have come off anyway if you'd tried braking, and you'll look way cooler doing it.
Sako
PostPosted: 13:41 - 29 Mar 2012    Post subject: Reply with quote
the bike will lean waaay more than you will feel comfortable doing just now - which in turn means it will corner way quicker than you will feel comfortable doing too, so the safety margin will always be there for you if you need it, ie. if you think you are going in too hot just focus on your exit point, gently apply more throttle through the turn and hold a slight pressure on the inside bar until the bend starts to open. you will make the bend because the bike can.
theatty
PostPosted: 13:53 - 29 Mar 2012    Post subject: Reply with quote
When you feel like you're cornering too fast, you're probably not riding too fast at all. When you run wide on a bend this is rarely due to speed, this is usually caused by your brain. Here's what happens:
You go into a bend quite fast, which is nerve racking
You start to panic
You look straight forward, or down at the line/verge in fear of going towards it
Your focus is no longer on where you should be heading, that is the vanishing point of the bend (the furthest point you can see). Your focus is now on where you don't want to be, i.e to the outside of a bend, the verge, curb, hazard line.
You run wide, towards what you're looking at.
Anybody who thinks about it enough will know that if you look at something for long enough, you will be drawn towards it.
The solution is not to slow down (although it does reassure you) but it's to look further. This is crucial in cornering and a massive cause of mistakes.
Hope this helps
The truth is out there.
theatty
PostPosted: 13:55 - 29 Mar 2012    Post subject: Reply with quote
Sako wrote:
just focus on your exit point [...] you will make the bend because the bike can.
This advice is sound.
Alpha-9 This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
PostPosted: 14:35 - 29 Mar 2012    Post subject: Reply with quote
Look where you want to go...not the hedge I was aiming at Laughing
Definitely remember the bike far outweighs your capabilities, you may see a corner that you have been doing for years at 60mph and think I'll try faster, then brick it when you go into it... I did. Laughing
Alpha-9
PostPosted: 16:20 - 29 Mar 2012    Post subject: Reply with quote
lol, noone likes my technique then.
It works! At slower speeds anyway Rolling Eyes
Fzr-600 1999
Sako
PostPosted: 16:48 - 29 Mar 2012    Post subject: Reply with quote
you can get away with this on your 125, but if you tried it on a bigger bike at speed during a corner you would end up being highsided to the fucking moon!
Alpha-9
PostPosted: 17:10 - 29 Mar 2012    Post subject: Reply with quote
Duly noted Thumbs Up
Fzr-600 1999
The last post was made 14 years, 99 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 133.41 Kb
