Carb setup
PostPosted: 08:06 - 30 Mar 2012    Post subject: Carb setup Reply with quote
Hey,
Carbs are one thing I've never really touched.
I've heard about moving the needle up one notch and stuff, I have no idea what that means.
I'm going to try and setup a 26mm carb for my road pit and I'd just like a breakdown of what will need adjusting when I fit it. Clueless carb person Laughing
Reid
PostPosted: 09:57 - 30 Mar 2012    Post subject: Reply with quote
One "notch" is usually in relation to dynojet (or similar) kits with adjustable height. Top needle in the pic below is stock Mikuni, the other two are from Dynojet and Factory Pro respectively.
https://s93420228.onlinehome.us/fzr/carbs/DSCF0266.JPG
PostPosted: 10:37 - 30 Mar 2012    Post subject: Re: Carb setup Reply with quote
The needle is just one part of the equation.
I believe this should be appropriate for your carb:
https://mikoarts.com/images/KZ1000/Carb_Part_Work_Diagram.jpg
Presume it's not a CV carb for a pit bike.
PostPosted: 11:19 - 30 Mar 2012    Post subject: Reply with quote
That throttle marking thing sounds like a good idea... I'll definitely have to do that.
I assume if it bogs you need to adjust the jetting? What exactly does the mix screw do, is it purely an idle mix screw or does it affect the whole range?
The last post was made 14 years, 184 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.13 - MySQL Queries: 13 - Page Size: 38.78 Kb
