Issues with little-used garaged bikes?
guile
PostPosted: 12:25 - 30 Mar 2012    Post subject: Issues with little-used garaged bikes? Reply with quote
What happens to a bike when you leave it in the garage for a long time and don't use it?
One second hand model I am looking at is a 2008 model but has only done 500 miles but he claims it has just passed a recent MOT.
I'm sure he will claim that he started the engine regularly but that's hard to believe over the period of 4 years.
snikks
PostPosted: 12:38 - 30 Mar 2012    Post subject: Reply with quote
Petrol and other fluids spoil over time, rubber components (tubing etc) can stiffen and possibly crack over time, metal parts can corrode due to a lack of use and proper care.
I think that broadly sums it up, but I'm sure someone will be along shortly to add details/additions/corrections.
- CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F
nowhere.elysium
The Pork Lord
PostPosted: 12:41 - 30 Mar 2012    Post subject: Reply with quote
If there's been fuel left in the tank for more than, say six months, I'd be expecting sediment buildup. This can block carb jets/fuel injectors.
If, however, there hasn't been any fuel in the tank for any notable period of time, then I'd be expecting some minor corrosion in there.
Happy hunting.
guile
PostPosted: 12:50 - 30 Mar 2012    Post subject: Reply with quote
Would the MOT have picked up anything really bad with regards to the engine?
Sako
PostPosted: 12:54 - 30 Mar 2012    Post subject: Re: Issues with little-used garaged bikes? Reply with quote
to be honest it would be better if he HASN'T been starting it regularly without riding it, people who do this are often causing more harm than good as the majority of engine wear is caused during the start-up and warm up, until all components are coated in oil, also starting a bike just to 'run it' over winter actually causes condensation to be drawn into the engine, again causing corrossion.
Sako
PostPosted: 12:56 - 30 Mar 2012    Post subject: Reply with quote
an MOT isn't there to check whether the engine is ok, its to check whether the bike is roadworthy/road legal, if you want to know the mechanical aspects of the bike, then service history is your indicator only, followed by a thorough inspection of the bike and test ride.
guile
PostPosted: 13:00 - 30 Mar 2012    Post subject: Reply with quote
So how would engine sediment/other inactivity issues manifest themselves? How could I tell if it was bad during a test ride?
the_quick
PostPosted: 13:14 - 30 Mar 2012    Post subject: Reply with quote
I really don't know how to test it, but I would takle bike for full service anyway
Bandit GSF600 '00
Teflon-Mike
tl;dr
PostPosted: 14:01 - 30 Mar 2012    Post subject: Reply with quote
Give us a clue here; what bike?
(I am taking a guess its Kawloon-Kentukki-Flied-Speshal; left derelict when it proved less than wonderful to ride, and owner baulked at resale losses! Few people would leave a brand new Jap that would sell easily & for good money sat in a garage!)
Four years isn't TOO much; for a bike to be 'layed up'. I have pulled bikes out of the back of garages or barns that have been there far longer, and worked fine. But does depend.
As said, lighter fractions in petrol will evaporate, & if left with the petrol switched 'on' carbs can constantly 'sweat' petrol vapour leaving a laquer gumming the float-bowls, float needle's & jets.
Condensation can collect in the petrol tank and settle at the bottom; along with rust & sediment not 'agitated' and washed through.
Tyres can go flat, and rubber hard and perish, along with other rubber bits, like seals.
Paint & plastic, if the bike is exposed to strong sunlight; eg left in a green-house or summer-house, can fade, go hard & brittle; though often this takes more than ten years to be significantly noticeable.
Exposure to chemicals; garden fertiliser for instance; can cause excessive corrosion; but sat with moving parts not moving, the chain will tend to go tight and rusty, along with wheel-bearings & headstock bearings. Cables similarly seize up, as do drum brake links.
Forks, are a common one; oil ages; water settles at the bottom of the damping oil; seals remain 'dry' and harden, & unwiped with damping oil from being compressed; stansion chrome will rust more readily to 'pits', and the seals will dry out and harden; & you can expect a premature fork seal failure shortly after recommissioning a long layed bike, as work highlights weaknesses like this.
All sounds worse than it may be; all depends on what state the bike was in before it was layed up, & circumstances since.
But you have to balence; enviromental degredation from NOT being used, vs lack of 'wear & tear' from not being used...
Almost brand new bike? Layed up 4 years? Ought not be THAT significant.
But does depends what it is.
guile
PostPosted: 14:08 - 30 Mar 2012    Post subject: Reply with quote
Nice replies. It's a Derbi Senda 125. It looks in good nick but the engine could be another state, I guess.
Are Derbi's reliable?
PostPosted: 14:15 - 30 Mar 2012    Post subject: Re: Issues with little-used garaged bikes? Reply with quote
Post a link to the advert, nobody is going to snipe it out from under you.
guile
PostPosted: 14:24 - 30 Mar 2012    Post subject: Re: Issues with little-used garaged bikes? Reply with quote
LOL Embarassed
www.autotrader.co.uk/classified/advert/201212457488534
Wouldn't be paying £1400 for it btw.
Teflon-Mike
tl;dr
PostPosted: 15:36 - 30 Mar 2012    Post subject: Re: Issues with little-used garaged bikes? Reply with quote
It's Spanish & I think uses the Suzuki GN125 copy-motor. Not the ideal Learner bike; but you could do a lot worse. Pics looks VERY good, and at that money I'd be surprised it stuck around very long.
Back to comments above; pro's of a lay-up is that it' dont get worn out (or crashed!) cons; still deteriorates.
Its had fresh MOT... I'd be comfy with it. I'd keep an eye on the fork seals and probably flush through brake fluid; but do that with ANY bike layed up or not.
When buying a 'new' 2nnd hand bike; always hold back a bit of budget to de-niggle early miles faults & problems you find, previouse owner couldn't be bothered to fix or never even noticed.
Dont think that that one would be different to any other 2nd hand bike, in that respect; other than lay-up giving a couple of pointers like fork seals, cables C&S etc.
If you can snag that price down a bit, so much the better; but it's not over-priced to start with, especially given 'cosmetic' condition & low miles.
PostPosted: 15:49 - 30 Mar 2012    Post subject: Reply with quote
Have it.
The last post was made 14 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 88.14 Kb
