| guile |
 guile Spanner Monkey
| snikks |
 snikks Spanner Monkey
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 12:41 - 30 Mar 2012 Post subject: |
If there's been fuel left in the tank for more than, say six months, I'd be expecting sediment buildup. This can block carb jets/fuel injectors.
If, however, there hasn't been any fuel in the tank for any notable period of time, then I'd be expecting some minor corrosion in there.
Happy hunting. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| guile |
| Sako |
 Sako World Chat Champion
| Sako |
| guile |
| the_quick |
 the_quick Nitrous Nuisance
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 14:01 - 30 Mar 2012 Post subject: |
Give us a clue here; what bike?
(I am taking a guess its Kawloon-Kentukki-Flied-Speshal; left derelict when it proved less than wonderful to ride, and owner baulked at resale losses! Few people would leave a brand new Jap that would sell easily & for good money sat in a garage!)
Four years isn't TOO much; for a bike to be 'layed up'. I have pulled bikes out of the back of garages or barns that have been there far longer, and worked fine. But does depend.
As said, lighter fractions in petrol will evaporate, & if left with the petrol switched 'on' carbs can constantly 'sweat' petrol vapour leaving a laquer gumming the float-bowls, float needle's & jets.
Condensation can collect in the petrol tank and settle at the bottom; along with rust & sediment not 'agitated' and washed through.
Tyres can go flat, and rubber hard and perish, along with other rubber bits, like seals.
Paint & plastic, if the bike is exposed to strong sunlight; eg left in a green-house or summer-house, can fade, go hard & brittle; though often this takes more than ten years to be significantly noticeable.
Exposure to chemicals; garden fertiliser for instance; can cause excessive corrosion; but sat with moving parts not moving, the chain will tend to go tight and rusty, along with wheel-bearings & headstock bearings. Cables similarly seize up, as do drum brake links.
Forks, are a common one; oil ages; water settles at the bottom of the damping oil; seals remain 'dry' and harden, & unwiped with damping oil from being compressed; stansion chrome will rust more readily to 'pits', and the seals will dry out and harden; & you can expect a premature fork seal failure shortly after recommissioning a long layed bike, as work highlights weaknesses like this.
All sounds worse than it may be; all depends on what state the bike was in before it was layed up, & circumstances since.
But you have to balence; enviromental degredation from NOT being used, vs lack of 'wear & tear' from not being used...
Almost brand new bike? Layed up 4 years? Ought not be THAT significant.
But does depends what it is. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| guile |
| Rogerborg |
 Rogerborg nimbA
| guile |
| Teflon-Mike |
 Teflon-Mike tl;dr
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:49 - 30 Mar 2012 Post subject: |
Have it. ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 14 years, 100 days ago. Instead of replying here, would creating a new thread be more useful? |
