power valve mito evo 2??? plz help
Biker_Dene
PostPosted: 19:23 - 29 Sep 2004    Post subject: power valve mito evo 2??? plz help Reply with quote
ok just got a new power valve motor and vlave well a new second hand 1
i put it all together and noting happeneing? if i take a spanner to the mototr and turn it all the way to the left and then turn the ignition on then the motor will spin right round but only one way ?
could this be becouse the wires are in the wrong way round or becouse it needs setting ?? and i have no idea how to adjust it eit her
please help
"RIDE LIKE A KNOB AND YOU'LL DIE"
K9 Suzuki Hayabusa
PostPosted: 20:08 - 29 Sep 2004    Post subject: Reply with quote
I had something similar on a Freccia. The valve would open when you turned the ignition on but not close (so the next time you turned the ignition on it did nothing). The problem was the control unit for the power valve.
I think what happens is that the power valve cables get badly adjusted and put a large strain on the motor. The motor draws its power through the control unit and I think it just burns it out. I understand that on late bikes Cagiva fitted a fuse to this circuit to try and prevent this problem.
Biker_Dene
PostPosted: 20:41 - 29 Sep 2004    Post subject: Reply with quote
YES I HABE HAD TO CHANGE THE FUSE MEANY TIMES Sad
SO ALL IT IS, IS THAT THE CABLES ARE BADLY ADJUSTED?
o soz about caps guys
K9 Suzuki Hayabusa
Biker_Dene
PostPosted: 18:00 - 30 Sep 2004    Post subject: Reply with quote
still doesnt work any help me ?? im getting realy anoyed at it now
K9 Suzuki Hayabusa
PostPosted: 18:33 - 30 Sep 2004    Post subject: Reply with quote
Suspect you have blown the control unit. It would not surprise me if the power valve cables are wrongly adjusted so the power valve motor has tried to open the valve further than it can, thus drawing a large current. Suspect the fuse helps, but sometimes you get unlucky and burn out part of the control unit.
Bang goes £200+ at new prices.
The last post was made 22 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 44.68 Kb
