| Biker_Dene |
 Biker_Dene Crazy Courier
| Kickstart |
 Kickstart The Oracle
 Posted: 20:08 - 29 Sep 2004 Post subject: |
I had something similar on a Freccia. The valve would open when you turned the ignition on but not close (so the next time you turned the ignition on it did nothing). The problem was the control unit for the power valve.
I think what happens is that the power valve cables get badly adjusted and put a large strain on the motor. The motor draws its power through the control unit and I think it just burns it out. I understand that on late bikes Cagiva fitted a fuse to this circuit to try and prevent this problem.
| Biker_Dene |
 Posted: 20:41 - 29 Sep 2004 Post subject: |
YES I HABE HAD TO CHANGE THE FUSE MEANY TIMES
SO ALL IT IS, IS THAT THE CABLES ARE BADLY ADJUSTED?
o soz about caps guys ____________________ "RIDE LIKE A KNOB AND YOU'LL DIE"
K9 Suzuki Hayabusa |
| Biker_Dene |
| Kickstart |
 Posted: 18:33 - 30 Sep 2004 Post subject: |
Suspect you have blown the control unit. It would not surprise me if the power valve cables are wrongly adjusted so the power valve motor has tried to open the valve further than it can, thus drawing a large current. Suspect the fuse helps, but sometimes you get unlucky and burn out part of the control unit.
Bang goes £200+ at new prices.
The last post was made 22 years, 15 days ago. Instead of replying here, would creating a new thread be more useful? |
