| newmannewy |
 newmannewy Borekit Bruiser
 Posted: 11:55 - 06 Apr 2012 Post subject: Quick need help :) |
Right Im working on my daytona 955i attempting to measure & then adjust the valve clearances..
However Im following the manual (haynes) and it says, remove valve case, remove spark plugs, place it in a high gear and turn the backwheel until the 1st cam is in TDC position..
however ive done everything removed case, plugs & put it in a high gear, but the back wheel refuses to turn.. So how do i turn the wheel or engine so that the lobes are pointing up ?
anybody  |
| Maruchino |
 Maruchino Spanner Monkey
 Posted: 11:58 - 06 Apr 2012 Post subject: |
No expert, but I'd assume you're on the top of the stroke and you need to man up!
I did mine by manually turning the engine over by hand using a socket / long bar. |
| newmannewy |
 Posted: 12:07 - 06 Apr 2012 Post subject: |
If you have the bike in top gear you should be able to turn the rear wheel forwards by hand quite easily with the plugs out. ____________________ a.k.a 'Geri'
| newmannewy |
 Posted: 12:12 - 06 Apr 2012 Post subject: |
Does it turn freely in neutral? ____________________ a.k.a 'Geri'
| newmannewy |
| newmannewy |
| andym |
 andym World Chat Champion
| Suntan Sid |
 Posted: 12:58 - 06 Apr 2012 Post subject: |
Is there a small round cover in the centre of the generator cover?
If so, remove it, (checking first, in your manual, that you're not going to dump all your oil), put socket on the large nut and turn it in the correct direction.
Failing that, take bike off the stand and roll it forward, a liitle bit at a time, while it's in gear, ____________________ "Everybody needs money, that's why they call it money!"  |
| newmannewy |
| Maruchino |
 Posted: 16:22 - 06 Apr 2012 Post subject: |
Anything in tolerance is good. I might consider swapping a shim right on 0.18 with another shim on the looser side if they were close in size, but that's only something you can tell by comparing shims and clearances.
My shimcalculator is still available for download.
https://www.bikechatforums.com/viewtopic.php?t=150267 ____________________ a.k.a 'Geri'
| newmannewy |
 Posted: 17:25 - 06 Apr 2012 Post subject: |
Thanks for your help folks, managed to do what I needed to do. Now I just need to source some shims. Seems its a bank holiday weekend and im going to be screwed until wednesday
need
3 x 2.47 or 2.475's
3 x 2.50
if anyone's got spares knocking about they want to sell and just so happens to live within 20 miles of me (Wolverhampton). |
The last post was made 13 years, 312 days ago. Instead of replying here, would creating a new thread be more useful? |
