| fzr600 |
 fzr600 L Plate Warrior
| Big Pete |
 Big Pete Spanner Monkey
 Posted: 11:53 - 30 Sep 2004 Post subject: |
Assuming you have removed the bolt from the bottom of the damper rod and taken the top off the fork and removed the spring then wipe the fork clean of oil then you hold the bottom and someone else holds the top, then yank them apart as though you were being particularly violent with a Christmas cracker.
Basically the top bush is under the seal, so it needs to push the seal out .
Did this on my FZR about a month ago. Not too bad a job.
| fzr600 |
| Guest |
 Guest Brolly Dolly
| Git |
 Git Brolly Dolly
| mr.z |
 mr.z World Chat Champion
 Posted: 16:38 - 01 Oct 2004 Post subject: |
I had to do mine recently, a bit intimidateing haveing my forks sprawled allover the shed
I got an alan key, cut it down so i was left with a "bit" and then used a 6mm (i think) socket to go on the ratchett, it is in an akward position and i wanted to torque it properly, this did the trick nicely..
Didn't have any problem like this though? to be honest i'd try and get the propper tool can't say i'd like the idea of haveing bit of mankey wood in the forks, or at least a nice shiney new broom handle to do it with
Also when your putting the seal on go to your local hardware shop, take the mesurement of your fork upper diamiter, then find a section of drainpipe that will fit over it, make it longer than the upper, because then you use it to hammer the seal into place evenly without makeing a mess of your fork legs or the seal  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Guest |
 Guest Brolly Dolly
| Git |
 Git Brolly Dolly
 Posted: 18:10 - 01 Oct 2004 Post subject: |
Ok, two notches on my pistol
Well we all have different ways of doing things and thats cool by me, just as long as it's not on my forks, I am a factory boy in another trade and firmly believe if it has not been done by the book it has not been done right, thats just the way I am and how I have been trained, it's what my customer expects when they pay you money to do the job properly.
One fleck of wood accidently missed when cleaning will more than likely aid in the damage to fork components, I view it very similar as to, how much dirt is safe to enter an engine or how much moisture is safe in the gas of a cooler or something.
Admittedly, the chances of a bit of timer killing a bush or seal or something is not that likely, but, it happens and the risk in my eyes is just not worth it.
Just my pennys worth on that one.
Fork oil smells nice. |
The last post was made 22 years, 15 days ago. Instead of replying here, would creating a new thread be more useful? |
