| roozor |
 roozor Scooby Slapper
| Mr.Everready |
 Mr.Everready World Chat Champion
 Posted: 15:00 - 30 Sep 2004 Post subject: |
Maybe you've got to turn it upside down and shake it out just like a piggy bank  ____________________ the undemocratically unelected mod of the Scottish section |
| roozor |
| Mr.Everready |
| roozor |
 Posted: 15:10 - 30 Sep 2004 Post subject: |
no been trying on the web all this morning trying to get some info, sem a crazy idea tho, you cant drain the oil out from underneath ?
bloody japs :E |
| Adam_P |
 Adam_P World Chat Champion
Is the drain plug on the side of the engine - right down near the bottom but on the side of the casing?
Some bikes have the exhaust system underneath the engine so putting a drain plug there too isn't such a practical idea.
Just a question, but have you actually had a good look around the engine for something that might be what you're looking for?  ____________________ Colin McRae MBE 1968 - 2007 RIP
Orwell Rolls in his Grave
God is imaginary |
| carvell |
 carvell Scuttler
| Sparks! |
 Sparks! Sir Tart-a-lot
 Posted: 15:36 - 30 Sep 2004 Post subject: |
The goose has a DR350 engine, on the DR itself most of the oil was kept in the frame, I'd "imagine" the goose also has most of the oil in the frame, therefore there should be 2 drain plugs, one at the front of the frame near the bottom (it'll probably drain in a bit of an arc so make sure you have something ready to catch the oil!!) then there should be another one on the left side of the engine at the very bottom, either under it completely or on the left side a bit. You might have some sort of sump guard on blocking vision of it?
Not really sure how the goose has incorporated the DR engine but it should be similar to the above which is pretty much how you change the oil on the DR... I'm sure bonny/scotty or someone will be along to confirm or tell you the correct method soon ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
| roozor |
 Posted: 15:59 - 30 Sep 2004 Post subject: |
carvell, your right nice one chap
1 bolt directly above the side stand, drains the lot, ta ! |
| Mr.Everready |
 Posted: 16:08 - 30 Sep 2004 Post subject: |
And why did you not see this bolt before ?  ____________________ the undemocratically unelected mod of the Scottish section |
| Mr.Everready |
 Posted: 16:25 - 30 Sep 2004 Post subject: |
You do have a manual don't you? If as YamsR6 says, it is oil in frame, this means it is probably a dry-sump engine. They can involve a bit more fiddling than just draining the old oil and bunging new stuff in. For example, you have to prime the oil pump on my dry sump bike by undoing a screw and letting the air bleed out of the housing when the engine first starts. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Visitor Q |
 Visitor Q $25 whore
 Posted: 17:38 - 30 Sep 2004 Post subject: |
Ahem ill tell you your all wrong here. The dr350 used the frame as the sump, the goose has a pretty huge oil sump under the crankcase. Right infront of the kickstand pivot is a little bolt (its very very thick tho). Take that out using a socket, (make sure you have a huge bucket underneath cos there is alot) and presto. Also do the oil filter. Makes it such a better bike ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
From September 2014 to January/February 2015 I will not be using any English, nor reading any. As such, I won't be on here. PM at will, but I won't be checking/posting unless in emergencies. Certainly not for the first couple of months. Please berate me savagely if I break that rule... |
| roozor |
 Posted: 17:51 - 30 Sep 2004 Post subject: |
bonny,i done the oil now how do i do the oil filter! i found it, but havent dared taking it out yet. how do i clean it ? |
| Frost |
 Frost World Chat Champion
 Posted: 18:33 - 30 Sep 2004 Post subject: |
Generally you replace an oil filter rather than clean it  |
| roozor |
The last post was made 22 years, 52 days ago. Instead of replying here, would creating a new thread be more useful? |
