CG125 Cleanup
tomh
PostPosted: 20:19 - 09 Apr 2012    Post subject: CG125 Cleanup Reply with quote
Hi, since my MOT has just expired I thought it would be a good time to take my CG apart and clean up the rust and dirt etc. The bike is a 2001 Honda CG125. I've been servicing the bike since I've got it so nearly everything is working and I shouldn't have to replace any parts. I'm just going to clean and paint parts as I go. Since it's just a 125 I'm not planning to spend much money on this however I am planning on keeping this bike once I've done my test so I would like to keep it looking as good as a CG can look Laughing
It looked like this when I bought it.
https://i1049.photobucket.com/albums/s383/TomHanley/My%20CG125/IMG_0110.jpg
However riding through the winter and not washing the bike has led it to its rust problem getting worse.
https://i1049.photobucket.com/albums/s383/TomHanley/My%20CG125/IMG_01162.jpg
I've lost the first lot of pictures but so far I've removed the tank, seat and panels.
First thing I've got to do is to remove the tail light.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0278.jpg?t=1333999772
Numberplate holder and rear indicators removed without much problem.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0281.jpg?t=1333999879
Next to remove is this rusted metal plate that holds the numberplate holder and mudguard to the frame. This is the only part I wanted to remove as it looked the worse but I've somehow ended up taking apart the whole of my bike Rolling Eyes
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0282.jpg?t=1333999982
As you can probally guess, the bolts are completely siezed in place. This is what happens when you apply force to cheap socket sets.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0285.jpg?t=1334000322
20 mins later and lots of WD40 the bolt finally unscrews
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0284.jpg?t=1334000426
Air box and battery removed. I've also removed the rear mudguard.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0293.jpg?t=1334000464
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0292.jpg?t=1334000531
The rear mudguard is the first part to be cleaned.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0302.jpg?t=1334001055
My main problem with the bike is the center stand as it has seized to the pivot pin and worn a hole into the frame.
To get access to the stand I've removed the exhaust.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0271.jpg?t=1334001401
To remove the stand first I will need to remove the brake pedal which is held on by a washer and split pin. Like most split pins on this bike they are rusted and snap straight away leaving me having to drill them out. Anyone got any advice on how to remove them intact when there in this condition.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0274.jpg?t=1334001599
You can see how much the pivot pin has worn into the frame.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0275.jpg?t=1334001701
After reading other people's experiences removing thier stand in this condition I was supprised to find that some WD40 and one big hit with a hammer removed the pin from the stand leaving both parts intact.
My plan to fix this to pass the MOT is to fill the hole with epoxy putty and then re-drill out the hole. I'm then just going to ditch the center stand and just refit the pivot pin and brake pedal.
I have found more rust on the frame than I expected although most of it is just surface rust and wipes off, other parts look quite bad.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0297.jpg?t=1334002193
Im undecieded on if I'm just going to patch these spots of rust with hammerite or repaint the whole frame.
I've got the next few days off work so I'm going to finish this over the next couple of days.
Thanks for reading,
Tom.
Hobgoblin
PostPosted: 21:07 - 09 Apr 2012    Post subject: Reply with quote
good work tom! Thumbs Up
Plodding along on my CG
tomh
PostPosted: 16:11 - 10 Apr 2012    Post subject: Reply with quote
More progress done on the bike today. I've stripped the bike down to the frame leaving just the rear wheel/swingarm and front end attached. I've only just recently refurbished the forks (I'll find the pictures of this later) and I've tided up the wiring in the headlight so I didnt see the need in stripping it.
First job of the day is to fill the centerstand hole with metal epoxy putty. Just need to file it down, redrill the hole and paint it.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0306.jpg?t=1334072923
No pictures for this part but I've had the engine out and washed the frame with soapy water and a scrubber. Thankfully nearly all the rust on the frame was just surface rust and came straight off. There were a few small patches including the picture in my last post, so I've sanded them down and painted them in hammerite.
Engine and rear mudguard refitted:
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0311.jpg?t=1334073122
I've used a wire brush on the rusted metal plate, painted it with some hammerite and put it back on the bike.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0312.jpg?t=1334073240
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0313.jpg?t=1334073320
Wiring loom put back in place:
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0314.jpg?t=1334073439
Airbox back in along with the battery:
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0315.jpg?t=1334073586
New indicator relay fitted, it should be a lot nicer riding having my indicators working again.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0316.jpg?t=1334073534
How it stands now:
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0320.jpg?t=1334074146
Not much left to do now,
- Sort the rear brake pivot out and paint the brake pedal,
- Clean and refit air filter,
- Clean up body panels,
- Clean the rear shocks,
- Refit the chain.
One problem I still need to sort out is my new forks I've fitted, there off a older CG and a slightly diffrent design so when you fully tighten the front wheel spindle it pulls the fork legs in and binds the wheel. If I don't fully tighten the wheel I loose braking power as the drums shoes are not tight in the drum.
My solution to this is to make longer wheel spacers, I've got a spare wheel spacer which I'm going to cut down once I work out what size the spacer needs to be.[/img]
tomh
PostPosted: 09:14 - 11 Apr 2012    Post subject: Reply with quote
Some more jobs on the bike completed already today.
New air filter foam oiled and fitted.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0336.jpg?t=1334135342
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0338.jpg?t=1334135432
My brake lever mount has snapped off but I don't want to pay £15 for a second hand one so I've made a new mount which works better than the original one. The lever doesn't move up and down any more, I just need to paint it black to finish it.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0333.jpg?t=1334135103
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0334.jpg?t=1334135354
Rear reflector fitted to pass MOT and make me a bit more visible.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0340.jpg?t=1334135585
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0339.jpg?t=1334135439
New brake shoes fitted at front and back, my rear shoe was in a bad condition and had several chips in it. The drum looks OK though.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0335.jpg?t=1334135423
I've been thinking about the body panels and the state there in, with the left side looking the worse after my crash.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0343.jpg?t=1334135598
I really want to repaint the panels but with my holiday coming up soon, I would rather paint them myself to save money, the only problem being is I have no experience of doing this...
bikertomm
PostPosted: 18:10 - 11 Apr 2012    Post subject: Reply with quote
Nice one mate looking good!
What did you use to clean the engine casing / block?
Mines basically the same and I want to get it looking clean! Razz
tomh
PostPosted: 18:44 - 11 Apr 2012    Post subject: Reply with quote
Thanks, my engine is the one bit where I've not really needed to do much to get it looking clean though, the person I got it off repainted the engine cases just before I bought it so all I needed to do is scrub it down with some soapy water to get it looking good again.
You can see it from around when I first got it in the first pic.
Not got much else done today, I've drilled out the pivot hole on the frame and painted it up. The brake pedal is painted in black ready to go back on the bike but I've gone through several drill bits trying to drill out the old split pin on the pivot pin. I need to do get some new drill bits to finish that off. Until then I can't put my rear brake pedal back on.
I've also made a new wheel spacer for my front wheel which would have fit perfect if I hadn't of lost it somewhere Mad I'm not looking forward to trying to take the front wheel off on my own without a center stand though...
Once them two jobs are finished I'm going to get all the body panels back on and get my MOT sorted.
I'm not going to bother repainting the bike as I'm planning on buying a old 250cc+ bike that I can restore as I've really enjoyed stripping this bike down, it will also motivate me to get my test done Thumbs Up
pendulum
PostPosted: 20:53 - 11 Apr 2012    Post subject: Reply with quote
This is exactly what I want to do with my CG, clean it up a bit and deal with all the surface rust because it looks bad.
A bit scared of painting though as I've hardly done any painting before. Just read this:
Hammerite Paint is specially formulated to be applied directly onto rusty metal with minimal surface preparation.
Is it really that simple? If so I will give it a go pretty soon!
Anyway. Just wanted to say. Your thread is useful. Wink
blurredman
PostPosted: 22:05 - 11 Apr 2012    Post subject: Reply with quote
I have a '91 CG.
I did the exact same thing, and my god the rear of the frame (where the back plastic mounts on) was very bad.
All surface rust however and it was still extremely solid. A little hammerite goes a long way!
Good progress!
deleted111
PostPosted: 10:08 - 12 Apr 2012    Post subject: Reply with quote
I ditched my centre stand and fitted a sidestand, best thing I've ever done to my CG.
Good work so far! Thumbs Up
Tim..
PostPosted: 12:33 - 12 Apr 2012    Post subject: Reply with quote
Nice progress
But
Do yourself a favour and buy a new (or 2nd hand) brake lever mount
www.marshallracing.co.uk
Hobgoblin
PostPosted: 17:49 - 12 Apr 2012    Post subject: Reply with quote
Tim:
Nice progress
But
a pattern part would be just as good, im sure mines a patern one and does the job just as well.
could always find someone BREAKING a cg and ask for pictures, advice on condition and a price?[/url]
tomh
PostPosted: 23:13 - 12 Apr 2012    Post subject: Reply with quote
Thanks for the replys, not got much done today as it was going dark by the time I got home from work but all my main jobs have been done.
My rear brake pedal is back on the bike as I've finally drilled out the split pin on the pivot pin, I really need to buy a punch instead which would of been much quicker. The rear brake pedal doesn't have much travel any more but I'm guessing that is due to it having new brake shoes.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0344.jpg?t=1334271508
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0346.jpg?t=1334271948
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0349.jpg?t=1334271993
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0350.jpg?t=1334272024
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0351.jpg?t=1334272079
I've also cut down a old wheel spacer and filed it down so my new fork doesn't bend in and bind the wheel when tightening the wheel spindle.
My front brake lever mount works quite well, ill take a picture of it tomorrow but I suppose I should really buy one to pass the MOT.
It got to dark to do anything else but I will have it all back together tomorrow and I will get my MOT booked Very Happy
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0358.jpg?t=1334272439
tomh
PostPosted: 20:20 - 13 Apr 2012    Post subject: Reply with quote
More progress Very Happy
My bike is more or less back together. All body panels, the tank and exhaust are back on although my mudguard has been taken off to repaint the inside as it's really rusty.
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0361.jpg?t=1334347954
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0366.jpg?t=1334347973
Really happy with the results of rebuilding the bike. My brake pedal is really nice to use now and no longer wobbles all over the place. The stopping power is a lot better with the new shoes I've fitted.
Going to get my MOT booked tomorrow. I've still got little jobs to do like repaint the fork legs but I'm going to leave them as they are for now. I'm going to autosol the chrome when I'm bored enough to do it Laughing
I also got a letter from the DVLA telling me my tax is due at the end of the month, my dad also got his letter...
https://i1049.photobucket.com/albums/s383/TomHanley/IMG_0359.jpg?t=1334348267
I love how cheap my CG is to run!
The last post was made 14 years, 218 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.15 Sec - Server Load: 0.14 - MySQL Queries: 13 - Page Size: 96.96 Kb
