White grease between the fork oil seal and dust seal
steven_191
PostPosted: 23:02 - 10 Apr 2012    Post subject: White grease between the fork oil seal and dust seal Reply with quote
Honda used some white grease but what is it exactly?
Going to be doing some forks this weekend and want to get the right stuff.
Casper
PostPosted: 23:07 - 10 Apr 2012    Post subject: Reply with quote
Are you sure its not an oil/water mix as your seals are buggered?
Ichy
PostPosted: 23:15 - 10 Apr 2012    Post subject: Reply with quote
If it is grease then it sounds like lithium. Might also be emulsified oil.
PostPosted: 09:34 - 11 Apr 2012    Post subject: Reply with quote
As above. It's probably a little oil that has leaked past the seals and emulsified. You wouldn't normally put grease between the oil and dust seals.
I have been known to run a bead of bathroom silicone round there if there is a potential water-trap above the oil seal though. It just peels out again if you want rid of it and stops the circlip corroding.
Budgetboy
PostPosted: 10:26 - 11 Apr 2012    Post subject: Reply with quote
Its the condensation mixing with the misting of the oil on your stanchions.
If you are doing your seals then dont worry about it. make sure you are carefull when fitting your new seals.
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
steven_191
PostPosted: 21:07 - 11 Apr 2012    Post subject: Reply with quote
as I said, honda used a white grease to pack between the oil and dust seals. I recently done my seals but because of a lack of oil seal driver I took them to honda to push them in. They packed it out with grease. I assume its a backup for the oil and oil dust to help against wearing the seals.
My first thought was white lithium but to be honest I didnt know whether that was abrasive?
It definietly not my seals going Laughing
Budgetboy
PostPosted: 21:32 - 11 Apr 2012    Post subject: Reply with quote
Ah now i know what you mean.. Very Happy They put this in between to act a a catch tank type thing.. It aids sliding on your forks and stops any crap ruining your new seals..Also stops water.
Dont use normal grease,, you want to use a Silicone based grease.. petroleum based ones will not do your seals any good.
Hope that helps. Thumbs Up
Ichy
PostPosted: 23:54 - 11 Apr 2012    Post subject: Reply with quote
Nope, the lithium is used to thicken the oil and change the temperature properties, other than that it is just plain old grease.
PostPosted: 11:44 - 12 Apr 2012    Post subject: Reply with quote
What forks are you doing? I packed mine with silicone grease. I figure it will stop water getting in.
Ichy
PostPosted: 13:32 - 12 Apr 2012    Post subject: Reply with quote
I can't say that I've seen or heard of the dust seal being packed with grease. Confused Personally I would see it as something that any dirt that does get through the seal to stick to. Long term you end up with a bit of grinding paste.
The last post was made 14 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 65.41 Kb
