tyre valves questions
colin1
Captain Safety
PostPosted: 18:35 - 11 Apr 2012    Post subject: tyre valves questions Reply with quote
With my bike (triumph tt600), as standard, the valves are solid metal and are right angle. Ebay is my supplier for most things, and i can only find these
https://www.ebay.co.uk/itm/2x-SNAP-TYRE-VALVE-90-DEGREE-BRASS-RUBBER-MOTORCYCLE-/130444198531?pt=UK_Motorcycle_Parts&hash=item1e5f148283
My local motorbike tyre place has already fitted me one of these and they suggest changing valves every other tyre. I'd tend to think this is excessive but I had a tyre valve that was pretty old fail on my so I'm now thinking it's sensible.
I've recently bought a pair of wheels which have the right angle valve stems which seem to be in good condition but the internal valve bit is missing. I've bought one like this before, and just replaced the whole valve, but I'm now thinking someone might be able to supply the internal valve bit.
If not, maybe get more of the solid metal valves.
Or do you lot reckon that the type in the ebay link are fine on sportsbikes ? I cant help thinking they look more like something you'd have on a small bike.
The other question is, a cheap tyre fitter will change tyres if I supply the wheel only but i'm not sure he would fit the valve. Are they easy to put in on a wheel that doesnt have a tyre on it ?
The "snap in" description makes them sound easy to put in but...
PostPosted: 18:49 - 11 Apr 2012    Post subject: Re: tyre valves questions Reply with quote
First off, you can easily swap/buy new internals for a valve.
The tyre fitter I used in Reading (Rideinbiketyres, top bloke Thumbs Up) always used to give you a whole new valve with new tyres - it helps to have the right tool, but isn't essential.
A couple of metal ones at least on google.
yen_powell
PostPosted: 19:24 - 11 Apr 2012    Post subject: Reply with quote
I put new ones in on my last two tyre changes. Mine were straight forward tubeless valves, no right angle.
With the tyre off, I cut the old valve off, lubed up a new one with tyre soap and used a cheap tyre tool screwed onto it to pull it through.
With one of these you can either screw it onto the outside of the valve or remove the valve core and use the smaller thread to screw inside the valve tube. Then you lock your fingers on the cross piece and pull the valve till it pops into place.
https://www.metals4u.co.uk/resources/files/SL380153.jpg
XT1200Z and a DR350 in bits
colin1
Captain Safety
PostPosted: 19:48 - 11 Apr 2012    Post subject: Re: tyre valves questions Reply with quote
ok so i've bought the tyre tool on ebay now, so where can i buy valve internals ? or valve core, or whatever you call it ?
stonesie
PostPosted: 20:19 - 11 Apr 2012    Post subject: Reply with quote
The tyre fitter can easily swap in the new core from a standard rubber valve if it is needed, or you can buy them from Ebay and some new valves that look pretty much like the Triumph originals are to be found HERE Bridgeport valves... As has been said by G the core is the only part that needs changing.
The rubber based 90° valves are crap, the centrifugal forces flex the rubber every time you go fast, if they're good rubber it's not bad, if they are El-Chepo then it will crack and leak.
binge
Emo Kiddy
PostPosted: 20:24 - 11 Apr 2012    Post subject: Reply with quote
Just a few pointers for this thread, cant be arsed clicking on links or reading properly. But from what I skim read;
Valves should be changed at every tyre change, especially if they are the rubber bodied valves. They cost fuck all, so why ponse on changing one.
IF, you are the type of person who likes to run them annoying stainless steel bodied valves. Fair enough.
But DO NOT replace the core with a standard core from a rubber valve.
These have copper internals, and will react with the stainless valve, making it useless in a few months time.
I get it all the time at work, pain in the arse.
Customers buy them wanky metal dust caps. They seize onto the valves within a few months.
Besides that, they look fucking shit anyway!
Rubber valves all the way. You can bend them over to pump the tyres up. And if you change them every time you change your tyres, then they wont perrish or break when you are bending them about to pump the tyres up.
Ben
salty21
PostPosted: 20:26 - 11 Apr 2012    Post subject: Reply with quote
as far as i know push bikes, cars and motorbikes all use the same core in there valves, so finding one should be easy. If you dont have any old push bikes or car wheels knocking about just go to your nearest car or bike garage and buy a complete valve, the tool you just bought will have the specially designed forky thing on it to remove and install valve cores.
Edit* apparently not Laughing
binge
Emo Kiddy
PostPosted: 20:28 - 11 Apr 2012    Post subject: Reply with quote
Valve cores are worth fuck all.
I throw maybe 40 in the bin every day which come out of tyre valves.
I can post out some valve cores, and PLASTIC dust caps in the post to anybody who wishes to cover the postage and my time.
I've also got disposable amounts of valve core removers, not one of them little Xmas cracker tools that has been posted above.
binge
Emo Kiddy
PostPosted: 20:30 - 11 Apr 2012    Post subject: Reply with quote
Not strictly the purpose of them tools, but I like the way you have improvised.
The threaded parts are for cleaning the threads on the valve. Kinda funny though, if a valve thread is gone, just put a whole new valve in for what they cost. Maybe 10 pence? Book price in a garage is about £2.50, and that included fitting the thing.
To fit a valve without any tools, just apply a bit of tyre soap (or WD40 / fairy liquid) to the stem. Push the stem through the wheel, then bend the top of the valve over a couple of times.
It'll pop right through. Thumbs Up
stonesie
PostPosted: 20:43 - 11 Apr 2012    Post subject: Reply with quote
I was told most valves were Brass because Copper is too expensive? Anyway the Bridgeport valves are aluminium so nickel plated brass cores shouldn't cause any problem.
I had a stint as a tyre fitter but got out of that game, I was on 6 full days a week and they started talking about Sunday opening Shocked
binge
Emo Kiddy
PostPosted: 21:27 - 11 Apr 2012    Post subject: Reply with quote
Im not a tyre fitter, but yeah. I did it for a good few years, but escaped that a while back! We do have tyre fitting equiptment at our workshop now though, even though we dont sell tyres as we cant match tyremark's prices who are next door. So we just have an alliance with them really, share tools, and share workload etc.
Brass, copper, whichever it is, it shouldnt be mixed with the steel valves, weather they are the ripspeed special valves, or the pressure sensor valves, costing up to £100 a piece. As the core seizes in.
Go buy a brand new metal valve, and pull the core out. It'll be silver in colour, as apposed to copper/brass in colour.
They are specefic cores for those type valves.
I sat on a pressure sensor valve course a few years ago for about 6 hours. Learnt everything there is to know about the pressure valves fitted to new cars etc.
Regarding the 6 day a week thing. Was on that at the Clutch center, but the new place only requre me to work 5 to 5.5 days a week. 9 - 5.30, £5k salary rise on my previous job etc. Absolutely love it!
And I'm replacing engines, and gearboxes daily.
yen_powell
PostPosted: 06:48 - 12 Apr 2012    Post subject: Reply with quote
I knew they were really thread chasers, but although I have changed my own tyres for years, I have only recently had a bike that had tubeless tyres and I didn't have a proper tool so thought it might work and it did, will try your tip next time though.
The last post was made 13 years, 317 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 79.74 Kb
