| Jenks |
 Jenks World Chat Champion
| Reid |
 Reid Nitrous Nuisance
 Posted: 18:18 - 12 Apr 2012 Post subject: |
Looks a beaut mate - can't wait to see the work on it  |
| Jenks |
 Posted: 14:17 - 13 Apr 2012 Post subject: |
| P.addy |
 P.addy Red Rocket
| devojunior |
 devojunior Brolly Dolly
| Jenks |
 Posted: 15:43 - 13 Apr 2012 Post subject: |
got lots of little niggley bits to replace. motor has a load of compression which is good. fork seals for definate. new coolant and fluids. tank wasnt too clever inside - ill get a pic of the old petrol
just to clarify, this has been in a garage for 12 years unused  ____________________ 1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi |
| P.addy |
 P.addy Red Rocket
| garth |
 garth World Chat Champion
 Posted: 15:59 - 13 Apr 2012 Post subject: |
Bearings don't randomly collapse when they get old you muppet.  |
| P.addy |
 P.addy Red Rocket
| MarJay |
 MarJay But it's British!
| Jenks |
 Posted: 16:21 - 13 Apr 2012 Post subject: |
well the garage was definatilly NOT damp. - i live in germany at the moment. Not damp old england  ____________________ 1978 MZ TS 250 1 Supa 5
| MarJay |
| Jenks |
 Posted: 19:09 - 13 Apr 2012 Post subject: |
An early Sintesi. 1988 model one (quite likely registered in 1989).
The seat lock and petrol cap lock should have the same key. Note that there are a couple of different petrol caps which at a glance look VERY similar. If you can get the cap off you should be able to remove the lock from the cap to make it easy to get a key copied.
Rotax / Aprilia did have an issue with main bearings failing when parked up over winter and then used again. They changed the spec of the bearings used to avoid this. Think the early ones were not meant to have a major issue with this though.
Good luck getting the fuel gauge to work if the tank is all clogged up.
As a road test said, the stickers on the forks probably looked like that from people trying to peel them off and put them on the right way up. From memory they were the first road bike sold with USD forks.
The dynamic airbox is just directing cool air at the intake to the real airbox. The air filter is oiled foam, but check it hasn't rotted away by now.
The tail lights quite often seem to break the small mount at the bottom.
Remember to use high octane petrol (unless you want a hole in the piston).
| Jenks |
| Gamble |
 Gamble Borekit Bruiser
There is a gap of 194 days between these two posts... |
| Jenks |
| Valentino Mossy |
 Valentino Mossy World Chat Champion
The last post was made 13 years, 168 days ago. Instead of replying here, would creating a new thread be more useful? |
