'One-man' brake bleeding kit (one-way valve) - UPDATE: Argh!
Ingah
PostPosted: 23:01 - 14 Apr 2012    Post subject: 'One-man' brake bleeding kit (one-way valve) - UPDATE: Argh! Reply with quote
Have bought one of these one-man bleeding kits, and have changed my brake hose, so will be looking to refill the system and then bleed it, but i need some advice on it really as i don't find bleeding brakes easy at all.
One man kit as below:
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320870889328
With this sort of kit, am i supposed to just connect it to the bleed nipple, leave the nipple 'open' and pump the brake lever (having tried this before, i remember watching the brake fluid go up and down the tube but not make actual progress to the end...), and does this all rely on gravity to work (because i've taken the caliper off the bike and don't have lots of different-height surfaces to use), because i've had a right bugger of a time getting this type of kit to work previously (couldn't make it happen) so ended up cutting the one-way valve end off, making it into a tube, and accepting a sub-standard bleed.
-- Ingah
binge
Emo Kiddy
PostPosted: 23:05 - 14 Apr 2012    Post subject: Reply with quote
Buy a massive syringe, and just suck the fluid through with that. Best and cleanest way without pressurebleeding from the top.
PostPosted: 23:06 - 14 Apr 2012    Post subject: Reply with quote
Yes, that's how it's supposed to work, but the reality is that you usually draw air in through the bleed nipple threads.
The Artist
PostPosted: 23:07 - 14 Apr 2012    Post subject: Reply with quote
Yes, it is supposed to work like that. Loosen the nipple, put tube over nipple and pump keeping the reservoir topped up but sometimes it doesn't work. Ideally the tube needs to be full of brake fluid. You can make it shorter to make this job easier. They are only long so you can use them on cars.
Make sure the nipple isn't too loose otherwise air will get back in past the threads. Good idea is to wrap the nipple in PTFE tape if you have any.
Personally I use the syringe method for bleeding brakes. Get a big syringe, fill with fluid, attach tube to nipple and push all the fluid back up to the reservoir.
temeluchus
PostPosted: 01:24 - 15 Apr 2012    Post subject: Reply with quote
for anyone interested in this, google "catheter tip" syringes.
binge
Emo Kiddy
PostPosted: 09:57 - 15 Apr 2012    Post subject: Reply with quote
Reverse bleeding is good, but it doesnt half squirt out of the reservoir if you're not careful! Laughing
janner_10
PostPosted: 13:46 - 15 Apr 2012    Post subject: Reply with quote
Whats wrong with the standard way?
instigator
PostPosted: 14:20 - 15 Apr 2012    Post subject: Reply with quote
I just use a simple bit of tubing for bleeding the brakes (more just to direct the brake fluid into a can than anything else), you don't need any form of valve to do it whatsoever.
Noxious89123
PostPosted: 20:01 - 15 Apr 2012    Post subject: Reply with quote
^This. One of the easiest things to do to your bike I reckon. Only reason I'd bother with using a syringe or one way valve thingumy is if I was having trouble getting the last bit of air out.
temeluchus
PostPosted: 01:25 - 16 Apr 2012    Post subject: Reply with quote
Vaccum or reverse bleeding can get the job done in seconds if done right, thats my main reason for doing it over the old fashioned way.
Rubber tube and a catheter tip syringe are only a few quid.
Ingah
PostPosted: 00:14 - 17 Apr 2012    Post subject: Reply with quote
Argh i knew this would happen - disc brakes y u so difficult to service!
Replaced the pads, copper-greased the backs, pushed the pistons back and cleaned them, new spring clip and everything, put it all back together, bled the system for ages, and on putting it all together and making sure its all tight - my brake is absolute crap!
It doesn't feel spongy, the lever feels like it should do - decent resistance, but you have to apply the brake really hard to actually stop the bike even at running-with-the-bike speeds* - it also makes a load squeak just as it stops too, as though i'd forgot the copper grease.
Is it my fault for buying EBC organic GG pads? (i've heard they're awful, but i didn't realise it was the organic ones i was buying)
I don't think its a problem with the bleeding because i can feel plenty of resistance at the lever, but i've cable-tied the brake on overnight anyway just in case.
Anyone got any ideas before i'm forced to concede i've wasted my time and take it to a garage?
* = even after running up and down the road trying this about 10-15 times just to be sure it wasn't going to sort itself out.
-- Ingah
bridlad
PostPosted: 08:43 - 17 Apr 2012    Post subject: Reply with quote
Dont give in now mate youve done the lions share of the work Wink new pads no matter what type do need to be bedded in so its worth just havin a steady ride and using the brakes to bed them in ,also give the discs a clean with aerosol brake cleaner or celly thinners you may just have got a smear of grease on therm,check the pads are clean too using the same method .On the squeaking front they may squeak slightly for a while but it will wear off.Lastly if you really think the pads are at fault it would be cheaper for you to buy another set and try them first before shelling out for a stealer to look at it Thumbs Up
Wheels polished and painted £90 a pair all in ..........bargain!
The last post was made 14 years, 193 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 75.84 Kb
