| Ingah |
 Ingah World Chat Champion
 Posted: 23:01 - 14 Apr 2012 Post subject: 'One-man' brake bleeding kit (one-way valve) - UPDATE: Argh! |
Have bought one of these one-man bleeding kits, and have changed my brake hose, so will be looking to refill the system and then bleed it, but i need some advice on it really as i don't find bleeding brakes easy at all.
One man kit as below:
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320870889328
With this sort of kit, am i supposed to just connect it to the bleed nipple, leave the nipple 'open' and pump the brake lever (having tried this before, i remember watching the brake fluid go up and down the tube but not make actual progress to the end...), and does this all rely on gravity to work (because i've taken the caliper off the bike and don't have lots of different-height surfaces to use), because i've had a right bugger of a time getting this type of kit to work previously (couldn't make it happen) so ended up cutting the one-way valve end off, making it into a tube, and accepting a sub-standard bleed. ____________________ -- Ingah
| binge |
 binge Emo Kiddy
| Pete. |
 Pete. Super Spammer
 Posted: 23:06 - 14 Apr 2012 Post subject: |
Yes, that's how it's supposed to work, but the reality is that you usually draw air in through the bleed nipple threads. ____________________ a.k.a 'Geri'
| The Artist |
 The Artist Super Spammer
| temeluchus |
| binge |
 binge Emo Kiddy
| janner_10 |
 janner_10 World Chat Champion
| instigator |
 instigator Super Spammer
| Noxious89123 |
 Noxious89123 World Chat Champion
| temeluchus |
| Ingah |
 Posted: 00:14 - 17 Apr 2012 Post subject: |
Argh i knew this would happen - disc brakes y u so difficult to service!
Replaced the pads, copper-greased the backs, pushed the pistons back and cleaned them, new spring clip and everything, put it all back together, bled the system for ages, and on putting it all together and making sure its all tight - my brake is absolute crap!
It doesn't feel spongy, the lever feels like it should do - decent resistance, but you have to apply the brake really hard to actually stop the bike even at running-with-the-bike speeds* - it also makes a load squeak just as it stops too, as though i'd forgot the copper grease.
Is it my fault for buying EBC organic GG pads? (i've heard they're awful, but i didn't realise it was the organic ones i was buying)
I don't think its a problem with the bleeding because i can feel plenty of resistance at the lever, but i've cable-tied the brake on overnight anyway just in case.
Anyone got any ideas before i'm forced to concede i've wasted my time and take it to a garage?
* = even after running up and down the road trying this about 10-15 times just to be sure it wasn't going to sort itself out. ____________________ -- Ingah |
| bridlad |
 bridlad Borekit Bruiser
 Posted: 08:43 - 17 Apr 2012 Post subject: |
Dont give in now mate youve done the lions share of the work new pads no matter what type do need to be bedded in so its worth just havin a steady ride and using the brakes to bed them in ,also give the discs a clean with aerosol brake cleaner or celly thinners you may just have got a smear of grease on therm,check the pads are clean too using the same method .On the squeaking front they may squeak slightly for a while but it will wear off.Lastly if you really think the pads are at fault it would be cheaper for you to buy another set and try them first before shelling out for a stealer to look at it  ____________________ Wheels polished and painted £90 a pair all in ..........bargain! |
The last post was made 14 years, 195 days ago. Instead of replying here, would creating a new thread be more useful? |
