When should the slides lift on cv carb
kneedown
PostPosted: 21:36 - 15 Apr 2012    Post subject: When should the slides lift on cv carb Reply with quote
Hi guys
Got a zx9r, revs freely when not under load, as soon as its under load it won't rev past 4k stutters then dies, starts straight back up but then won't rev past 3 even when not under load.
I stripped and cleaned the carbs and it again revved freely through the whole range
Took it out again as soon as under load did same again, now won't rev past 4k without stuttering then dying, when I looked at slides they don't lift, when you rev it to 4k there is no slide movement at all not even a judder, the slide pushes up and returns as it should and ther are no holes in the diaghrams, but revving seems to have no effect on them
Any ideas, cheers guys
Budgetboy
PostPosted: 21:53 - 15 Apr 2012    Post subject: Reply with quote
carbs need cleaning or balancing.
How old is battery?
one of those normally. Thumbs Up
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
lihp
Have you checked that the coils aren't breaking down on load?
Are you sure that carbs are in good and correct condition? And correctly set up?
The last post was made 14 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 35.46 Kb
