MOT - Bare minimum
PostPosted: 16:56 - 17 Apr 2012    Post subject: MOT - Bare minimum Reply with quote
Nearly got my road legal mini bike ready to ride... just want to clarify what is needed for a "daytime" MOT.
All lights and switches have been removed, wiring loom does not exist. The 4 wires currently on there are taped and hidden from view. There are 2 earth points should one fail.
It has a number plate and can arrange for a rear reflector to be fitted.
The frame is visible... I'll get some photos later, but is that likely to cause issues? The rear had plastics but they were beyond salvageable. I "could" make up some metal covers...but if its not necessary I wont bother.
Is a horn required... I have no power source so I'm assuming if its needed I can get one of those squeezy ones? Laughing
Kal
PostPosted: 17:06 - 17 Apr 2012    Post subject: Re: MOT - Bare minimum Reply with quote
Squeezy horn hasn't been viable for a while.
Online MOT Manual
Kal...
WannaBeDude
PostPosted: 17:06 - 17 Apr 2012    Post subject: Reply with quote
Get a place to sign it off legal when it is not ... Legal.
PostPosted: 17:08 - 17 Apr 2012    Post subject: Re: MOT - Bare minimum Reply with quote
Really? Mates C90 went through with a "Tango" squeezy horn...was a D reg though.
Kal
Hasn't been legal for some years now.
Kal...
PostPosted: 17:10 - 17 Apr 2012    Post subject: Reply with quote
Suppose I can mount a 12v battery on there and wire the horn direct with a push button on the - feed to the left thumb cluster?
Kal
PostPosted: 17:17 - 17 Apr 2012    Post subject: Reply with quote
I think you'll find you need a stop light as well if the bike is later than '86...
Kal...
PostPosted: 17:18 - 17 Apr 2012    Post subject: Reply with quote
Having a stop light means you need all other lights by the looks of it...
Kal
PostPosted: 17:21 - 17 Apr 2012    Post subject: Reply with quote
Its considered seperately as far as I am aware.
They dont like vehicles on the road without brakelights.
Kal...
PostPosted: 17:28 - 17 Apr 2012    Post subject: Reply with quote
Shit, looks like it needs a brake light operated from both front and back brakes...
Hmm, I think I have the rear switch, its never had a front switch.
Nip sack... Laughing
Even if I can do this... how do I make it so the rear light doesn't come on?
Bezzer
PostPosted: 17:34 - 17 Apr 2012    Post subject: Reply with quote
I emailed VOSA a year or so ago back when we were having a discussion on OSS about it, they came back you don't need ANY lights, which includes the brakelight for the MOT.....but to be road legal you do, it's commonsense to have one anyway.
PostPosted: 17:37 - 17 Apr 2012    Post subject: Reply with quote
So for an MOT, you reckon no stop light is needed...
MOT manual says it should, I just basically want to nip around on it once or twice a month, its not gonna be a main bike at all.
Hmm, unsure how to go about this now...might have to pm binge Laughing
PostPosted: 17:57 - 17 Apr 2012    Post subject: Reply with quote
Right, I'm up for bodging this.
Going to fit the rear light. + wire from battery to front brake switch - to earth. Run a wire from the + on battery to the rear brake switch and earth the - on the rear. Then wire from front + rear switch to brake light.
Would that sound like it would work?
If so I'll wire that up later and use battery from GSXR to do that.
Horn wise... I'll chuck another battery on there for the MOT so it doesn't interfere with the brake lights...as that looks to be a fail too.
Just means I'll wire a charge point on there for the battery (basically a + wire and a - wire on either side of the bike covered with rubber connectors so I can charge battery without removing seat Laughing
andy_uk
PostPosted: 18:03 - 17 Apr 2012    Post subject: Reply with quote
Do you need the battery?
Can you not just run the horn & brake light off the alternator/dynamo (via a reg/rec if required) ?
J.M.
PostPosted: 18:12 - 17 Apr 2012    Post subject: Reply with quote
Was thinking this too!
2004 R1 & 2018 XSR900
PostPosted: 18:23 - 17 Apr 2012    Post subject: Reply with quote
Nope.
I have 2 wires running to CDI and 1 to earth. It has no additional wiring and is running a race setup so no way of producing power.
garth
PostPosted: 18:26 - 17 Apr 2012    Post subject: Reply with quote
All you need is a numberplate, reflector and horn.
That's it.
T0MMY
PostPosted: 18:34 - 17 Apr 2012    Post subject: Reply with quote
Hang on...so does this mean you will pass the MOT with no brakelight but could get stopped by popo for it? That seems weird Confused
Is that definitely right because I was thinking about getting race fairings for my ZX and ditching the lights (but still need it to be road legal).
ZX6R + CBR600RR
StormCrow
PostPosted: 18:37 - 17 Apr 2012    Post subject: Reply with quote
Yeah something to do with Construction & Use - MOT only checks the 'road worthiness' of the vehicle, whereas if you take it on the road, plod checks the rest...
Or something...?
Derivative
PostPosted: 18:43 - 17 Apr 2012    Post subject: Reply with quote
I believe the 'original' reasoning behind the MOT is to make a vehicle 'roadworthy' in the sense that it's not going to fall apart, have a brake failure, explode, or something equally dangerous.
Though there are some bits in there that don't relate to mechanical safety like the rear reflector requirement, mirrors, etc.
RIDINGforKICK...
PostPosted: 18:46 - 17 Apr 2012    Post subject: Reply with quote
A lot of this stuff depends on the year of manufacture.
A new (ish) vehicle won't get away with much, where as a vintage job will get away with murder.
RIDINGforKICK...
PostPosted: 18:55 - 17 Apr 2012    Post subject: Reply with quote
Why don't you just have a chat with the MOT man, Paddy?
They will usually give advice before you present the bike, and even if you fail the MOT, most places offer a free retest, anyway.
MaybeGuy
PostPosted: 18:57 - 17 Apr 2012    Post subject: Reply with quote
That's it.
I concur.
I've had several bikes through on a daytime MOT with just this. No need for a brake light.
Kal
PostPosted: 20:09 - 17 Apr 2012    Post subject: Re: MOT - Bare minimum Reply with quote
Online MOT Manual wrote:
Exemptions
For this test if a stop lamp is fitted, it must meet the requirements of this inspection, but need not be fitted to a machine which:
a. cannot exceed 25mph, or
b. was first used before 1 January I936.or
c. was first used before 1 April 1986 and which has an engine capacity of less than 50cc.
The language is a little ambiguous, however it reads to me as if the exemptions to the stop lamp are just those three there.
Strictly speaking a number plate is not required, an MOT can be done on the frame number. Numberplate does not appear on the MOT list.
The clubmans first MOT was prior to it being registered in this country.
Kal...
binge
Emo Kiddy
PostPosted: 20:26 - 17 Apr 2012    Post subject: Reply with quote
All you need is a 9v battery;
https://3d4me.files.wordpress.com/2009/02/9v-battery.jpg
A 6v horn off ebay;
https://www.ebay.co.uk/itm/BSA-TRIUMPH-SMALL-6V-HORN-IDEAL-FOR-FITTING-IN-NACELLE-/260986156028?pt=UK_Motorcycle_Parts&hash=item3cc3fcb3fc
And some common sense with wiring.
You dont need any lights what so ever.
To wire a stop light, just get an LED type one. I have an enduro style rear fender you can have, with an LED light in if you wanna collect it.
Basic way to wire it is;
Live from battery to switch on front brake.
Take a feed from that live, and run it to the rear brake switch.
Then from the other side of the front brake switch, run it all the way to the rear light.
Take a feed from that wire, and run it to the output of the rear brake switch.
Then return the tail light to the neg on the battery.
Like this;
https://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash3/s720x720/536722_10150743125065606_506045605_9460461_1267897390_n.jpg
The last post was made 14 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 126.33 Kb
