| LordShaftesbu... |
 LordShaftesbu... World Chat Champion
 Posted: 13:05 - 20 Apr 2012 Post subject: Cyclone V2 alarm niggle |
I have one of these on both my bikes:
https://www.motorbikealarm.co.uk/node/47
The one on my Street Triple was installed at my local dealer's. It was all working fine for a while but now the alarm status indicator light on the instrument panel no longer flashes when the alarm is active. The alarm itself still seems to be functioning though. I took it to the dealer's and they said they couldn't see why it wasn't working (they were sceptical it had ever worked in the first place, despite them fitting it ).
Before I go off and spend £275 on the horrendously overpriced Datatool alaram, can anyone tell me if they can think of what to check or how to get this light working again?
I realise it might seem extremely trivial but I would like to have the warning light functional as it's yet another deterrent to add to the list.
In before all the "If the want it they'll have it" etc. etc. |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| LordShaftesbu... |
| LordShaftesbu... |
| nowhere.elysium |
 Posted: 13:37 - 20 Apr 2012 Post subject: |
| LordShaftesbury wrote: | Of course, so simple ... now why couldn't my dealer have thought of that?
I take it it's a trivial matter to find and unplug that one cable?
Now to buy an LED ... do you get different types? For example, do different LEDs take different amounts of juice to light up? |
Because it's not the most expensive fix, that's why
Most LEDs are powered by 5v, going through a resistor that's ~270 ohm, in my experience. Any of the 5v ones that you get from places like maplins will work like that, certainly. There are LEDs that are rated for different voltages, but I'd imagine that it's a 5v one, and I think that the resistor is actually fitted inside the alarm unit, so you shouldn't need to worry about it.
To put another spin on it - they cost pennies; go grab a few from somewhere, and try plugging it straight into where the lead plugs in - if you get it backwards, it won't do anything, and if you over-volt it, you've popped a <10p component. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| nowhere.elysium |
| LordShaftesbu... |
| nowhere.elysium |
 Posted: 15:13 - 20 Apr 2012 Post subject: |
To be honest, I didn't find him to be spectacularly helpful when I spoke to him on the phone, about an unrelated issue.
The ECU will have no bearing whatsoever on whether or not the LED flashes, so I have no idea what the hell he thinks that he's on about.
Do you have a digital multimeter? If so, plug it into the red lead that's running into the back of the LED. Arm the alarm, and then watch to see if the voltage blips between 0 and 5v. If it does, then the LED's dead, or the lead's been damaged. If it doesn't, then there's something wrong with the alarm internals. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| LordShaftesbu... |
| LordShaftesbu... |
| nowhere.elysium |
| CaNsA |
 CaNsA Super Spammer
| LordShaftesbu... |
| nowhere.elysium |
| LordShaftesbu... |
| LordShaftesbu... |
| nowhere.elysium |
 Posted: 19:10 - 24 May 2012 Post subject: |
I've had a look through the service manual, and the wiring diagram I was originally after was on p256. However, the breakdown that you linked to tells me that the wires you want to try attaching the red lead to pin 3 on the plug, and the white lead to pin 2. Both of the leads that are going into those pins are black, which is rather unhelpful. They break out to the Triumph alarm socket (which I'm presuming is still present in the loom), to pins 11 and 10, respectively. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 20:27 - 24 May 2012 Post subject: |
The problem here, is down to the way the Cyclone was originally fitted. It looks like the Cyclone's Warning LED has not been used, but the bike's built-in warning lamp in the instrument cluster has been utilised instead. You need to find out how this was done, by asking whoever wired it up.
Your copy of the Cyclone wiring diagram doesn't show how the Warning LED should be connected, but there will be a dedicated 2-pin connector for it, and one of those will be a permanent earth. I suspect that whoever did the wiring-up, took the live side of the 2-pin connector to wherever the header plug from the instrument cluster comes out of the loom, rather than solder it directly to the back of the LED inside the instrument cluster.
If you can find the 2-pin connector at the Cyclone end, do what nowhere.elsium suggested with a spare LED - if it works there, you can trace the red wire from there to where it joins the bike's original wiring. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| LordShaftesbu... |
 Posted: 12:03 - 25 May 2012 Post subject: |
| Taught2BCautious wrote: | The problem here, is down to the way the Cyclone was originally fitted. It looks like the Cyclone's Warning LED has not been used, but the bike's built-in warning lamp in the instrument cluster has been utilised instead. You need to find out how this was done, by asking whoever wired it up. |
We're getting somewhere I think, everything you've written here makes sense. My Triumph dealership fitted the alarm a while ago, but had no knowledge of it when I asked them to take a look at fixing it .
| Taught2BCautious wrote: | Your copy of the Cyclone wiring diagram doesn't show how the Warning LED should be connected, but there will be a dedicated 2-pin connector for it, and one of those will be a permanent earth. I suspect that whoever did the wiring-up, took the live side of the 2-pin connector to wherever the header plug from the instrument cluster comes out of the loom, rather than solder it directly to the back of the LED inside the instrument cluster.
If you can find the 2-pin connector at the Cyclone end, do what nowhere.elsium suggested with a spare LED - if it works there, you can trace the red wire from there to where it joins the bike's original wiring. |
This too sounds right, I think. Just to make sure I understand, the alarm unit has a 2-pin connector (items 10 and 11 below) that has been connected to something in the loom (which doesn't appear in the circuit diagram, correct?) which then connects to items 2 and 3 below. Am I right?
Would simply putting the multimeter probes across 10 and 11 do the job?
I'm hoping this video will tell me which parts of the alarm are 10 and 11 (although I can't watch it with the sound on right now as I'm at work):
https://www.youtube.com/watch?v=X-PBInW8h7U |
| LordShaftesbu... |
| LordShaftesbu... |
 Posted: 15:56 - 26 May 2012 Post subject: |
Well, after poking around for about 5 secs the fuse blew. So now I need a new one.
It's a blue blade fuse with the number 15 on it, presumably that means 15 amp?
Although I have found that my last picture is partially wrong - that red and black lead is in my installation, it's just that everything's been wrapped in so much electrical tape I never noticed it before. From the alarm unit under the pillion seat it heads off in the direction of the tank, presumably the mysterious "loom" resides somewhere there ... |
| LordShaftesbu... |
 Posted: 16:24 - 26 May 2012 Post subject: |
| LordShaftesbu... |
| LordShaftesbu... |
| anthony_r6 |
 anthony_r6 World Chat Champion
The last post was made 14 years, 100 days ago. Instead of replying here, would creating a new thread be more useful? |
