Cyclone V2 alarm niggle
LordShaftesbu...
PostPosted: 13:05 - 20 Apr 2012    Post subject: Cyclone V2 alarm niggle Reply with quote
I have one of these on both my bikes:
https://www.motorbikealarm.co.uk/node/47
The one on my Street Triple was installed at my local dealer's. It was all working fine for a while but now the alarm status indicator light on the instrument panel no longer flashes when the alarm is active. The alarm itself still seems to be functioning though. I took it to the dealer's and they said they couldn't see why it wasn't working (they were sceptical it had ever worked in the first place, despite them fitting it Confused ).
Before I go off and spend £275 on the horrendously overpriced Datatool alaram, can anyone tell me if they can think of what to check or how to get this light working again?
I realise it might seem extremely trivial but I would like to have the warning light functional as it's yet another deterrent to add to the list.
In before all the "If the want it they'll have it" etc. etc.
nowhere.elysium
The Pork Lord
PostPosted: 13:09 - 20 Apr 2012    Post subject: Reply with quote
The status light is only an LED. You can unplug it near to the alarm unit, and just stick a different LED on there, to see if the problem is with the long lead that the LED is attached to, or the unit itself. Personally, I'd suspect the lead.
LordShaftesbu...
PostPosted: 13:26 - 20 Apr 2012    Post subject: Reply with quote
Of course, so simple ... now why couldn't my dealer have thought of that?
I take it it's a trivial matter to find and unplug that one cable?
Now to buy an LED ... do you get different types? For example, do different LEDs take different amounts of juice to light up?
LordShaftesbu...
PostPosted: 13:32 - 20 Apr 2012    Post subject: Reply with quote
*cogs turning*
I suppose I could use my multimeter to test the voltage the long lead supplies and make sure the LED I get will light up with that amount?
Although if it measures sufficient voltage then maybe I don't need an LED at all?
nowhere.elysium
The Pork Lord
PostPosted: 13:37 - 20 Apr 2012    Post subject: Reply with quote
Because it's not the most expensive fix, that's why Laughing
Most LEDs are powered by 5v, going through a resistor that's ~270 ohm, in my experience. Any of the 5v ones that you get from places like maplins will work like that, certainly. There are LEDs that are rated for different voltages, but I'd imagine that it's a 5v one, and I think that the resistor is actually fitted inside the alarm unit, so you shouldn't need to worry about it.
To put another spin on it - they cost pennies; go grab a few from somewhere, and try plugging it straight into where the lead plugs in - if you get it backwards, it won't do anything, and if you over-volt it, you've popped a <10p component.
nowhere.elysium
The Pork Lord
PostPosted: 13:39 - 20 Apr 2012    Post subject: Reply with quote
Tell you what, if you can't get any this weekend, PM me your address, and I'll send you some on Monday.
LordShaftesbu...
PostPosted: 15:08 - 20 Apr 2012    Post subject: Reply with quote
I emailed the company that sells the alarms, no idea what to make of the reply.
Hi.
There is no reason I can think of, if the bike indicators and the alarm indication is operating.
May be the bikes ECU thinking there is a fault and correcting for the error?
Nigel
nowhere.elysium
The Pork Lord
PostPosted: 15:13 - 20 Apr 2012    Post subject: Reply with quote
To be honest, I didn't find him to be spectacularly helpful when I spoke to him on the phone, about an unrelated issue.
The ECU will have no bearing whatsoever on whether or not the LED flashes, so I have no idea what the hell he thinks that he's on about.
Do you have a digital multimeter? If so, plug it into the red lead that's running into the back of the LED. Arm the alarm, and then watch to see if the voltage blips between 0 and 5v. If it does, then the LED's dead, or the lead's been damaged. If it doesn't, then there's something wrong with the alarm internals.
LordShaftesbu...
PostPosted: 16:34 - 24 May 2012    Post subject: Reply with quote
Finally got around to this, but I can't for the life of me find the lead you're referring to. All I can see is one single thick cable that enters the rear of the instrument panel (see pic). It doesn't look like anyone has added an additional wire from the alarm unit.
Do I have to open up the instrument panel case to find which lead is running into the back of the LED (the LED is inside the instrument panel)?
LordShaftesbu...
PostPosted: 16:49 - 24 May 2012    Post subject: Reply with quote
This is the alarm indicator light that used to flash (this is the Speed Triple panel but it's similar).
https://cdn.bikechatforums.com/files/2011-triumph-speed-triple-10_copy.jpg
nowhere.elysium
The Pork Lord
PostPosted: 17:37 - 24 May 2012    Post subject: Reply with quote
Do you not have a wiring diagram?
CaNsA
PostPosted: 17:42 - 24 May 2012    Post subject: Reply with quote
If its the same guy spoke to, he is a wanker. Thumbs Up
LordShaftesbu...
PostPosted: 18:03 - 24 May 2012    Post subject: Reply with quote
I do, but it might as well be written in hieroglyphics, check 'em:
nowhere.elysium
The Pork Lord
PostPosted: 18:17 - 24 May 2012    Post subject: Reply with quote
I meant for the bike - they've usually got a general breakdown of what wire does what on the dash.
LordShaftesbu...
PostPosted: 18:29 - 24 May 2012    Post subject: Reply with quote
My owner's manual certainly doesn't, but I've found a workshop manual:
https://www.torrkish.com/triumph/Workshop%20Manual.pdf
LordShaftesbu...
PostPosted: 18:36 - 24 May 2012    Post subject: Reply with quote
These pages from the workshop manual appear revelant. But I've still no idea what I'm looking at.
nowhere.elysium
The Pork Lord
PostPosted: 19:10 - 24 May 2012    Post subject: Reply with quote
I've had a look through the service manual, and the wiring diagram I was originally after was on p256. However, the breakdown that you linked to tells me that the wires you want to try attaching the red lead to pin 3 on the plug, and the white lead to pin 2. Both of the leads that are going into those pins are black, which is rather unhelpful. They break out to the Triumph alarm socket (which I'm presuming is still present in the loom), to pins 11 and 10, respectively.
Taught2BCauti...
PostPosted: 20:27 - 24 May 2012    Post subject: Reply with quote
The problem here, is down to the way the Cyclone was originally fitted. It looks like the Cyclone's Warning LED has not been used, but the bike's built-in warning lamp in the instrument cluster has been utilised instead. You need to find out how this was done, by asking whoever wired it up.
Your copy of the Cyclone wiring diagram doesn't show how the Warning LED should be connected, but there will be a dedicated 2-pin connector for it, and one of those will be a permanent earth. I suspect that whoever did the wiring-up, took the live side of the 2-pin connector to wherever the header plug from the instrument cluster comes out of the loom, rather than solder it directly to the back of the LED inside the instrument cluster.
If you can find the 2-pin connector at the Cyclone end, do what nowhere.elsium suggested with a spare LED - if it works there, you can trace the red wire from there to where it joins the bike's original wiring.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
LordShaftesbu...
PostPosted: 12:03 - 25 May 2012    Post subject: Reply with quote
We're getting somewhere I think, everything you've written here makes sense. My Triumph dealership fitted the alarm a while ago, but had no knowledge of it when I asked them to take a look at fixing it Rolling Eyes .
This too sounds right, I think. Just to make sure I understand, the alarm unit has a 2-pin connector (items 10 and 11 below) that has been connected to something in the loom (which doesn't appear in the circuit diagram, correct?) which then connects to items 2 and 3 below. Am I right?
Would simply putting the multimeter probes across 10 and 11 do the job?
I'm hoping this video will tell me which parts of the alarm are 10 and 11 (although I can't watch it with the sound on right now as I'm at work):
https://www.youtube.com/watch?v=X-PBInW8h7U
LordShaftesbu...
PostPosted: 18:39 - 25 May 2012    Post subject: Reply with quote
This video is a fucking godsend, he names every wire coming out of the alarm unit. Now why couldn't the instructions do that?
So here's what I'm looking for:
https://cdn.bikechatforums.com/files/alarm_unit_led_connector.jpg
https://cdn.bikechatforums.com/files/connector_and_long_wire_terminating_in_led.jpg
So I'll try the multimeter probes across the wires in the first picture, if nothing registers I'll try connecting an LED.
LordShaftesbu...
PostPosted: 15:56 - 26 May 2012    Post subject: Reply with quote
Well, after poking around for about 5 secs the fuse blew. So now I need a new one. Rolling Eyes
It's a blue blade fuse with the number 15 on it, presumably that means 15 amp?
Although I have found that my last picture is partially wrong - that red and black lead is in my installation, it's just that everything's been wrapped in so much electrical tape I never noticed it before. From the alarm unit under the pillion seat it heads off in the direction of the tank, presumably the mysterious "loom" resides somewhere there ...
LordShaftesbu...
PostPosted: 16:24 - 26 May 2012    Post subject: Reply with quote
Well I've just bought these so hopefully they're the right ones; they look right anyway.
https://www.amazon.co.uk/BargainBitz-Standard-Auto-Blade-Fuses/dp/B007OUV2HO/ref=sr_1_1?ie=UTF8&qid=1338045676&sr=8-1
LordShaftesbu...
PostPosted: 16:41 - 26 May 2012    Post subject: Reply with quote
Are you sure? Because p256 in the manual I linked is about Fuel System/Engine Management ...
Also what is the voltage the alarm unit is likely to be using for the LED circuit? Because I need to make sure the LED I buy won't need more voltage than the unit is supplying.
Would I be fine with these for example?
https://www.amazon.co.uk/POWER-SUPER-BRIGHT-DIFFUSED-EMITTING/dp/B005VN57OU/ref=sr_1_sc_1?s=electronics&ie=UTF8&qid=1338047147&sr=1-1-spell
LordShaftesbu...
PostPosted: 17:12 - 03 Jun 2012    Post subject: Reply with quote
The fuses arrived and I replaced the blown one. Everything working again except the dash LED. I stripped the red and black wires coming from the alarm unit and measured the voltage with the multimeter - completely dead. This suggests to me that the problem is with the alarm unit, although I'm going to buy some LEDs and test using those just to make sure.
If it is the alarm unit I don't really want to replace it as the actual alarm and immobiliser parts are still working. So I found an alternative solution:
anthony_r6
PostPosted: 17:46 - 03 Jun 2012    Post subject: Reply with quote
Not sure if this has already been suggested. But you can remove the LED mid-way down the wiring - where the little plug disconnects from the main alarm wire.
If you have two alarms, why not just switch the two and see if they work on the opposite bike? It'll be a quick case of disconnecting and putting it on the other alarm and seeing if it flashes?
That way you can work out whether the problem is the wiring, or the LED?
If it's been suggested/done already - I apologise.
The last post was made 14 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 135.45 Kb
