Old Norton
locko
PostPosted: 12:36 - 20 Apr 2012    Post subject: Old Norton Reply with quote
Hello, i have a bit of a problem my 1956 model19s Norton has a "quick release" rear wheel. This means by removing the spindle on right, the three studs holding it to the brake drum and lifting up the hinged rear mudguard the wheel can be removed. Leaving the sprocket-ed drum, brake plate and chain in place on a stub axle fastened on the left. Now when everything is in place and tightened up there is movement if i hold the wheel at 12 and 6 o'clock and rock it backwards and forwards, as if a bearing has gone. I have tried spacers and shims between the stub axle and the brake drum although none are shown in the maintenance manual or the spares list to take up the slack but this makes the drum binded on the brake plate. Any one got any ideas? Rolling Eyes
paddlesat16
PostPosted: 15:06 - 20 Apr 2012    Post subject: Reply with quote
Not many old bike riders on here chap, maybe you should try a norton forum. They will have more of a clue Very Happy
Regards
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
steveh
PostPosted: 18:54 - 20 Apr 2012    Post subject: Reply with quote
Ive got a 73 norton commando, and ive had this issue when the spacer in the sproket carrier fell out, if its not a bearing issue, you could be missing a spacer.. do you have a workshop manual?
Ill try scan a blown up image if i can find it!
Drop me a pm if your still stuck.
Steve.
acid drop
PostPosted: 19:50 - 20 Apr 2012    Post subject: Reply with quote
Try this site it's a mine of information
www.vintagebike.co.uk
Ariel Badger
PostPosted: 22:37 - 20 Apr 2012    Post subject: Reply with quote
Owning an old British iron is best done with an owners club behind you.
NOC
locko
PostPosted: 15:56 - 24 Apr 2012    Post subject: Old Norton Reply with quote
NOC
I was in the NOC for a while but found it obsessed with twins, in particular commando's. One time i asked there spares department for a rear brake drum with 21 teeth for my 19s. They sent a drive socket for a atlas. Sad when you think Norton made singles for seventy years and twins for thirty.
locko
PostPosted: 13:47 - 02 Sep 2012    Post subject: Reply with quote
Steve.
steve, thanks for your help i fixed it in the end i did replace the bearings but also the spindle and stub-axle. locklo
The last post was made 14 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 51.66 Kb
