| locko |
 locko L Plate Warrior
 Posted: 12:36 - 20 Apr 2012 Post subject: Old Norton |
Hello, i have a bit of a problem my 1956 model19s Norton has a "quick release" rear wheel. This means by removing the spindle on right, the three studs holding it to the brake drum and lifting up the hinged rear mudguard the wheel can be removed. Leaving the sprocket-ed drum, brake plate and chain in place on a stub axle fastened on the left. Now when everything is in place and tightened up there is movement if i hold the wheel at 12 and 6 o'clock and rock it backwards and forwards, as if a bearing has gone. I have tried spacers and shims between the stub axle and the brake drum although none are shown in the maintenance manual or the spares list to take up the slack but this makes the drum binded on the brake plate. Any one got any ideas?  |
| paddlesat16 |
 paddlesat16 Crazy Courier
 Posted: 15:06 - 20 Apr 2012 Post subject: |
Not many old bike riders on here chap, maybe you should try a norton forum. They will have more of a clue
Regards ____________________ I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T. |
| steveh |
 steveh World Chat Champion
 Posted: 18:54 - 20 Apr 2012 Post subject: |
Ive got a 73 norton commando, and ive had this issue when the spacer in the sproket carrier fell out, if its not a bearing issue, you could be missing a spacer.. do you have a workshop manual?
Ill try scan a blown up image if i can find it!
Drop me a pm if your still stuck.
Steve. ____________________ Current : 06 Zx10r, 07 Wr450f SM, 74 850 norton commando, 63 bsa b40, 1962 Triton 650, 67 Triumph Tr6r, 1955 Triton 750, 1978 TY250E. |
| acid drop |
 acid drop Nova Slayer
| Ariel Badger |
 Ariel Badger Super Spammer
 Posted: 22:37 - 20 Apr 2012 Post subject: |
Owning an old British iron is best done with an owners club behind you.
NOC ____________________ Bikers make great organ donors, get 115 on your licence today. |
| locko |
| locko |
The last post was made 14 years, 37 days ago. Instead of replying here, would creating a new thread be more useful? |
