| Pol Anorl |
 Pol Anorl Banned
 Posted: 23:57 - 17 Apr 2012 Post subject: carb screws are buggerd. |
wanted to take my carbs apart on the xj to inspect the diaphragms but 3 our of the 4 screws on all 4 carbs are knackerd, tried to undo and just minced the head.
Any idea on how i can get them off without killing them completely?
SORTED!!
Was on live chat and someone was like "just use a chisel" ..
2 days later i got bored and set upon doing my carbs then i remember what someone said (forgot who it was)
So i grabbed the chisel and got to work.
now i know what your thinking "oh no he didn't"
I used a junior hack saw to make a grove stuck the chisel in and turned it.
For some reason the chisel was far more superior than a screw driver and worked with every single siezed screw with minimum effort.
I suppose it worked better due to the more sharper edge and the broad handle got more weight on it.
So carbs all done all screws replaced and 1 diaphragm looking a bit tired added to shopping list. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges
| Casper |
 Casper World Chat Champion
| Pol Anorl |
 Pol Anorl Banned
| Casper |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 00:05 - 18 Apr 2012 Post subject: |
may have to do that tbh, didn't really want to take the carbs all the way out but looks like i probably have to. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| andym |
 andym World Chat Champion
| andym |
| bodger |
 bodger Nova Slayer
| Pie-Roe |
 Pie-Roe World Chat Champion
 Posted: 12:57 - 18 Apr 2012 Post subject: |
I got replacement screws and drain bolts when I did mine.
Had to dremel down a side part to get mole grips on number 2 and 3.
All the bits I needed cost about 21 quid. ____________________ Previous: GSF600, FZR600 x2, ZXR750, XT600 Tenere, CB125, CZ125, ETZ 250, ER5, CCM R30, DRZ400, RF600x4, RF900x2, GS500, VTR1000F, 640 SMC, CB250 NIGHTHAWK, GT550x3, GPX750 TE610, CB500, X11x2, SV650, ZING 125, TL1000R,CB250 Superdream, CBR1100XX |
| Raffles |
 Raffles World Chat Champion
 Posted: 14:45 - 18 Apr 2012 Post subject: |
There should probably be a sticky for this as it is a very common problem. The heads are usually rounded off because people use the wrong type of screwdriver. The tool required is a J.I.S. screwdriver and they are not readily available in this country.
Anyway as for sorting the immediate problem, you will need to remove the carbs from the bike. Once they are on your workbench/floor you should be able to remove the chewed screws with a combination of a small set of mole grips and an ill-fitting Phillips type of screwdriver.
The proper screwdrivers for the job are available from the link below:-
https://www.probuild-uk.co.uk/jis-screwdriver-set?language=en¤cy=GBP
BTW Don't even consider putting the old screws back into the carbs.
Best of luck. ____________________ A good loser will always be a loser. |
| karthead |
 karthead Trackday Trickster
| Raffles |
| mickfulton |
 mickfulton Nova Slayer
 Posted: 20:59 - 20 Apr 2012 Post subject: |
Had teh exact same prob today. 16 screws top and bottom all shit, rotten and painted on - never been loosened in 21 years. Used the hacksaw method with the carbs in a vice wrapped in foamy gear, found the biggest flat head socket wrench attachment and used plenty of wd40 and patience.
I say me, it was actually the missus who spent hours at it It took a while and I would have just tried to drill it out, but she done it ( how luck am I - a woman who can fix bikes ) ____________________ Current half-cars :2004 SV650, VX535 1991
Exes: YBR 125 2007,GPZ500S 1998 |
| Ingah |
 Ingah World Chat Champion
| Raffles |
| karthead |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 04:57 - 25 Apr 2012 Post subject: |
SORTED!!
The last post was made 13 years, 289 days ago. Instead of replying here, would creating a new thread be more useful? |
