Any help welcome!****FIXED****
c058y
PostPosted: 19:42 - 28 Sep 2004    Post subject: Any help welcome!****FIXED**** Reply with quote
I have an NSR 125 Y reg. I noticed that my bike had some problems starting a while ago (battery problems?) so I got a new battery and that seemed to sort out the problem.
Unfortunately the problem seems to be coming on again after having the new battery for around a month.
Symtoms:
*When pressing the ignition switch all the lights on the dash dim signaling low battery power.
*When my main lights are on and indicating whilst stationary at traffic lights the lights dim significantly until I give it some throttle.
On my gs500 it had a similar problem and my mechanic changed the starter soleinoid and that solved the problem. Does the NSR have a similar part that I could change and where would that be?
Any help in tis matter would be very grateful. Very Happy
PostPosted: 20:00 - 28 Sep 2004    Post subject: Reply with quote
The lights will dim when you press the starter button. The starter motor is pulling a lot of current. The lights will also tend to dim at idle speeds.
However, get a voltmeter and check the voltage over the battery with the engine off, engine running at idle and with the engine being revved.
binge
Emo Kiddy
PostPosted: 20:09 - 28 Sep 2004    Post subject: Reply with quote
On my speedfight, I have got a Zennon bulb in the front and when Im indicating at idle or when I brake my headlights dim, I dont have a starting problem though.
Alot of bikes do it if their eletrical supply requires alot of energy to run.
Good luck!
Ben
c058y
PostPosted: 20:17 - 28 Sep 2004    Post subject: Reply with quote
Hello Keith,
I just checked the battery with my voltmeter, results are as follows:
Engine off: 12.6V
Engine at idle: 13.8V
Engine revving: Volts drop sharply, as low as 5V, only gaining once releasing throttle.
I hope this is normal.
Thank You
Richard
baldy
PostPosted: 20:23 - 28 Sep 2004    Post subject: Reply with quote
Hi,
could be the regulator?
One day i will rule the world, just not today.
Retro-Man
PostPosted: 21:12 - 28 Sep 2004    Post subject: Reply with quote
definitely a charging problem
at idle voltage should be 13.something but should rise a small amount when revved maybe as high as 14 volts, if its dropping to 5 volts the battery is taking a heavy drain at any engine condition other than at idle.
Try a regulator first
https://domharnessphotography.webs.com
c058y
PostPosted: 21:38 - 28 Sep 2004    Post subject: Reply with quote
obviously the consensus is to get a new regulator. Please explain where I would find this on my bike and where to purchase one.
Thank You
mr jamez
PostPosted: 22:05 - 28 Sep 2004    Post subject: Reply with quote
On my old nsr, it is under the tank near the power valve actuator, it is about 1 inch square, there are currently two on ebay and they look like this.
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=9946&item=7924503080&rd=1
c058y
PostPosted: 14:42 - 02 Oct 2004    Post subject: Reply with quote
Well done guys!!!! I got a new regulator today so I fitted it. What a nightmare that was, but the good thing is the problem has been solved thanks to all your knowledge. Very Happy
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thanks once again!! Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Richard
The last post was made 22 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 62.3 Kb
