My bike is brocken :( Gearbox??????
Chris750
PostPosted: 13:01 - 21 Apr 2012    Post subject: My bike is brocken :( Gearbox?????? Reply with quote
Riding along today I lost all gears accept for first, I limped it 30 yards to safety out of the way of traffic and the back wheel locked up.
I't won't even roll freely in neutral. Luckly I wasn't far from home, so rather than wait for the AA, I had a 30 minute push with the clutch held in.
Now I am at a bit of loss what to do. If the gearbox is gone I may as well break the bike, as its not worth that much so I don't think it would be worth repairing.
What would be the likely cause of this issue? Is it even worth bothering trying to sort out?
Bike is a GSXR 750 WS.
Current Rides: GSXR-750 WS, GSXR-1000 K5, KTM EXC 300
PostPosted: 14:34 - 21 Apr 2012    Post subject: Reply with quote
hahadumball wrote:
sounds like a possible track bike to me
Stop being a dick dumball.
I'm not sure what to do Chris. I'd guess the first step would be to get the clutch cover off and make sure there is no debris in the clutch. I'd also have a look at the gear linkage and see if that has what has caused it to jam. To be honest it doesn't sound good though...
Robby
Dirty Old Man
PostPosted: 14:39 - 21 Apr 2012    Post subject: Reply with quote
If it's failing to select gears, then you're looking at a failure with the selector rather than with the gears themselves. A fair amount of the selector mechanism can be viewed without splitting the cases, you can get to it by removing one of the crankcase covers.
If the problem isn't in the linkage, then a possibility is the knurled selector wheel that bolts onto the end of the drum. This is usually keyed into position with quite a slim dowel, and if that dowel sheared then the selector drum wouldn't turn. Not a particularly difficult fix, and something that would come under stress from a lot of harsh (clutchless) gear changes.
That or a bolt worked loose in the selector mech.
Chris750
Thanks Marjay that is very helpfull. I think I will spend the day tomorrow seeing if I can identify what is wrong.
I am fairly familiar with the working of the bike except clutch and gearbox as its one thing I have never had to deal with.
If the gear box has gone, I did see one on ebay a couple of months ago for a couple of hundred if I can get another. Would this be a nightmare to change though?
Chris750
PostPosted: 14:42 - 21 Apr 2012    Post subject: Reply with quote
That is awesome advise and will give me something difinitive to have a look into tomorrow, Thanks.
Depends if the GSXR is a cassette type gearbox or not. IIRC it isn't, but it might be. If it is, it'll just slide out and slide in. If it isn't then you'll have to split the whole engine. It would be easier and cheaper to replace the entire engine in that case.
Chris750
PostPosted: 14:52 - 21 Apr 2012    Post subject: Reply with quote
One further thing that has come to my attention now I think about it.
A couple of time when I changed from first to second it wouldn't go into gear. So I had to stay in first for another second, close the throttle again and it would go in. This has only happened 3 or 4 times though over the last few months.
Also I had the sentsation this morning that something was slipping under hard acceleration like I had the clutch lever was not properly released. I had assumed the clutch may be on its way out.
I think this bike has had a hard life with its previous owners.
I have now spent so much money and time into trying to make it good, that everytime something new come up I think I may as well put it right or else the previous effort and expense would be wasted.
This was also my first bike I have owned so I do have some sentimental attachment to it and was planning to just use it as my getting to work/backup bike when I have other bikes.
But I will have to see what happens now.
PostPosted: 17:00 - 21 Apr 2012    Post subject: Reply with quote
You can't wheel it in neutral but you can push it in 1st with the clutch in? Sounds like you have a broken shift fork, and every attempt to select any gear but 1st is attempting to select two gears.
Not a terribly serious problem but it will require at least the crank cases split, if not the head off. I suggest you mosey on over to oldskoolsuzuki.info and ask in the watercooled forum there, you might even find a replacement engine.
Chris750
PostPosted: 17:11 - 21 Apr 2012    Post subject: Reply with quote
I can't now wheel it in any gear or neutral. If I pull in the clutch I can wheel it, whatever the gear selection.
When it initially broke, it wouldn't select any gear except first, which I used to trundle the few yards to safety. As I moved along in first the revs seemed much higher than they should of been in order to move at my current speed.
After a few yards the back wheel locked causing me to skid to a stop.
mad4it028
PostPosted: 17:22 - 21 Apr 2012    Post subject: Reply with quote
good breakers gsxrs failing that engines can be picked up fairly cheap
PostPosted: 17:27 - 21 Apr 2012    Post subject: Reply with quote
Complete engine on OSS for £175
Chris750
PostPosted: 22:27 - 23 Apr 2012    Post subject: Reply with quote
This engine has now been purchased and is sat in my garage. It looks in much better condition than mine and has done less miles.
Thanks for your taking time to contact the guy for me Pete.
I am not working this weekend so I am going to do the swap out then.
I will see if I can fix my gearbox, but now with less urgency and on an engine that will be off the bike this should be easier.
All going well it will mean I will have a spare, just in case.
cloric_tzr
PostPosted: 23:58 - 23 Apr 2012    Post subject: Reply with quote
do you want to sell the old engine? just make a nice little project for me to strip tinker sort any probs n get some experience with iL4's? Smile
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
PostPosted: 18:56 - 24 Apr 2012    Post subject: Reply with quote
My pleasure. I'm actually working in OX3 this week and next. If you get stuck with anything give me a shout and I'll see if I can pop round.
Chris750
PostPosted: 00:06 - 30 Apr 2012    Post subject: Reply with quote
I did the swap out this weekend and it's up and running.
Whoever said broken gear selector fork for the old engine (Robby?), ten out of ten.
I will probably hang onto the old engine Cloric_tzr, I will either repair it or it will keep me in spares for years.
Thanks everyone
Sako
PostPosted: 08:37 - 30 Apr 2012    Post subject: Reply with quote
good result! Thumbs Up
m1tch
PostPosted: 17:19 - 30 Apr 2012    Post subject: Reply with quote
Thanks everyone
Bolt it onto a kart, im bolting an SV650 onto a kart for a bit of fun lol Very Happy
The last post was made 14 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 102.74 Kb
