| richjp |
 richjp Renault 5 Driver
 Posted: 19:18 - 21 Apr 2012 Post subject: Back to getting the Bike Started (CB 125 TDC) |
Hi all
Been a while, but now it's warmer and I have time at weekends again, I'm back to trying to get my Superdream 125 started.
I have fixed the problem with the starter clutch and bought a car battery to save stressing the bike battery.
Spent some time again today trying to get it started, but as reported last year, turns over, lots of 'phut, phut phut' and greyish smoke coming out of the exhaust ports on each 'phut' (running it without exhausts for the moment), but still not firing up.
I have checked the plug gaps and also that they are both sparking. As Mike suggested I swapped over the HT leads, but didn't make any difference. Petrol is getting into the carbs. Am not using the choke, just have it on full throttle.
Mike - you said something last year about "a good dose of neat petrol down each carb inlet", I wasn't quite sure how to go about that - the inlets already have the fuel lines going into them?
That apart, is there something else I should check? So close, but yet so far . . .
cheers
Richard |
| Usher4566 |
 Usher4566 Spanner Monkey
| richjp |
| Usher4566 |
| richjp |
| Usher4566 |
| richjp |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 17:13 - 29 Apr 2012 Post subject: |
1/ No Petrol in tank, Old/Stale fuel in tank
2/ Water/Sediment at bottom of tank
3/ clogged tank-strainer (on top of fuel tap)
4/ clogged 'sediment-bowl' / sediment bowl screen (bottom of fuel tap)
5/ Fuel Tap. Clogged, or switched 'off' or on 'main' without enough fuel in tank to flow through 'main' take-off
6/ blocked, clogged, kinked or otherwise perversely routed fuel hose.
7/ after-market, 'in-line' fuel filter, causing obstruction, or air-lock to fuel flow
8/ Blocked carburettor fuel 'inlet'
9/ Stuck Needle Valve in float bowl.
10/ Blocked idle-jet
11/ blocked main jet
12/ blocked primary air-way
13/ inoperative/poorly adjusted. non functioning choke mechanism
14/ air-leak between carburettor & manifold
- Perished, cracked or split carb mounting rubber (very common, with people ripping carbs off without removing air-boxes first)
- gasket at manifold
- missing balence port screw
15/ air-filter / air inlet blocked or obstructed
16/ Engine not 'sucking'
- tappets far too wide (setting is I believe 0,025mm, not 0.25mm, and at 2.5mm valves probably wont even lift off seats!)
- cam timing out, broken rocker, misaligned rocker, variouse other engine maledies.
But I'd start by taking carbs off and cleaning the buggers; draining tank & looking at colour of petrol coming out, swill & clean tank & dry it, strip teh fuel tap & clean, then re-plumb with new hose.
TIP: go to a motorfactors & they will sell you nylon re-inforced CAR hose, thats about 10mm diameter, wont bend and is too thick to be any use. Get 6mm internal diameter PVC 'windscreen-washer' pipe or fish-tank pump hose. Discolours and hardens over about 3 years, but clear, you can see fuel and see its not full of rust through it, and it is easier to 'plumb' to the carbs.
TOP TIP> Double & tripple check choke flap operation. Maker sure that the connecting tank between teh two choke shafts is a tight fit (Use cable tie snipping to wedge it if needs be) make sure that both flaps are fully open at the same time, and be sure that the cable is attached to hold them open, or they wobble around and send mixture 'all funny' ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Fizzer Thou |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 17:53 - 29 Apr 2012 Post subject: |
fixer just reminded me; READ the book carefully, and set the needle heights and air mixture screws EXACTLY as stated.
Far too often found them screwed ALL the way in (well, we wouldn't want them falling out now, would we?!) and the bike a pig to start.
Needle also sits one notch DOWN from mid-point, so often set mid, on presumption.
AND, while you have the carb apart, check the jets when you clean them for the Keihin 'Star', denoting genuine jet and Kehin sizing.
spent MONTHS faffing with teh carbs on the Corporal, swapping different carbs on and off, using different bodies, different jets trying to get it to run cleanly... UNTIL I discovered a Mikuni 38 jet is an AWFUL lot bigger than a Keihin 38!
Put Keihin Star jets in; went for a test run, and SUDDENLY not only did it pick up its skirts and GO, it went all the way to 70, like a star! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| richjp |
| bikenut |
 bikenut World Chat Champion
| richjp |
| Usher4566 |
| Walloper |
 Walloper Super Spammer
| richjp |
 Posted: 09:39 - 26 May 2012 Post subject: |
Many thanks guys.
When I last checked it I thought it was a blue spark, but I'll take a look at the spark / ht leads again. I can do it at night in the shed too.
Before I took it on, the engine had run, but the previous owner had a mechanical problem with it which I believe I have fixed by rebuilding it (in fact I think it was the starter motor clutch in the end ) So I had assumed the CGIs (and ht leads) were still OK.
I'll also check the tappets though if the spark looks healthy.
Will update you asap!
cheers
Richard |
| stinkwheel |
 Posted: 10:22 - 26 May 2012 Post subject: |
When mine had sat for a long time, it would never start off the button but would go pretty easily if I push started it. After it had started once, it would then go off the button.
Second gear, get some speed up then dump the clutch. If you're big and heavy enough, you'll probably be able to paddle it along in second until it catches and fires (or you pass out from heat exhaustion).
Worth a try anyway.
EDIT: For what it's worth, it's unlikely to be a CDI problem. It has two totally seperate CDI units and those bikes will start on one pot quite happily (in fact, I've never known one fire up on both cylinders at once from cold, one of them usually lags slightly). Both CDIs would have to have popped to stop it firing up. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| richjp |
| Walloper |
| richjp |
 Posted: 17:26 - 02 Jun 2012 Post subject: |
Good news - well partly anyway. I got it running on easystart - so I guess I know my engine rebuild was OK as it didn't explode . That makes me happy at least - been a long while coming, but I'm chuffed.
However, it doesn't keep running, so I assume that means although the ignition system is OK, I do have a fuel supply problem? A couple of weeks ago I had the carbs off and they seemed OK. I cleaned the fuel tank and put new pipes on, so not sure where to go next?
cheers
Richard |
| Usher4566 |
| richjp |
| richjp |
 Posted: 12:39 - 03 Jun 2012 Post subject: |
Hi all
Seems now to be working (after a fashion I appreciate) without easystart! I have attached a short clip of starting up. I appreciate it sounds rough as f**k, but to me it's music to my ears as I rebuilt the engine from a complete dismantle and it's my first foray into mechanics.
It doesn't idle - I guess there's adjustments still to be done and runs roughly, but I just wanted to make sure its basically working before I move onto stage 2 - which is to now strip the whole bike down and rebuild everything (plus get some exhausts ). When I have done that I can worry about getting the engine humming, even if that means dismantling parts of it to get it smooth.
Many thanks to all of you who have helped over the past year and a bit - especially Mike who has been a constant source of sound advice- much appreciated .
cheers
Richard |
| Usher4566 |
| nightshaddow |
 nightshaddow Nearly there...
The last post was made 14 years, 146 days ago. Instead of replying here, would creating a new thread be more useful? |
