Honda NSR125 02 Starting problem
Mrs Vale46
PostPosted: 10:28 - 24 Apr 2012    Post subject: Honda NSR125 02 Starting problem Reply with quote
Hi Chaps
I have a bit of a starting problem with my NSR. When I switch ignition on there isn’t anything there, completely dead! I’m going to replace the battery first of even tho it’s not that old (probs only just over a year) and the plug, but the starting problem started a while ago where you push the start button and it start to turn over but then did nothing else. The battery still had life as neutral light and side stand light would come on.
I wasn’t sure if this was a common problem with them or weather you guys could suggest anything else to try?
Thanks
Budgetboy
PostPosted: 11:03 - 24 Apr 2012    Post subject: Reply with quote
Change battery 1st and see what happens after that.My guess is you will change the battery and it will work again.
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
jimmyjaffa
PostPosted: 11:33 - 24 Apr 2012    Post subject: Reply with quote
Hi, if its not the battery try the main glass fuse by the battery as mine had bad connection and did all sorts, Hope this helps
ahaughey536
PostPosted: 22:09 - 24 Apr 2012    Post subject: Reply with quote
I had trouble before also, even if you're getting a spark with your plug which i was with the standard, which i'm guessing you also have on, I fit these for instant start, more MPG, better throttle response.
https://www.ebay.co.uk/itm/NGK-IRIDIUM-IX-SPARK-PLUG-BR9EIX-BR9E-IX-3981-/380392404389?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item58912775a5
NSR125R
st3v3
PostPosted: 22:36 - 24 Apr 2012    Post subject: Reply with quote
Generally the age of the battery doesn't matter, it's the conditions of use that affects it's ability to do its job.
Have you tried charging it overnight?
It is possible (probable) the starting issue is different to the battery issue.
The last post was made 13 years, 293 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.64 - MySQL Queries: 13 - Page Size: 44.15 Kb
