zxr 400 revival
wilz1234
PostPosted: 23:22 - 23 Apr 2012    Post subject: zxr 400 revival Reply with quote
Did have this up on tjtuning but it appears that sites gone now Sad
Heres how my bike looked back in 2008 when I bought her, it's a 1992 ZXR 400 L:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/Untitled.png
Was running a bit rough and generally needed a tidy up so here goes.
Unfortunately I didn't have a camera at this point, but basically the only bit i dont have pictures of is stripping the whole bike down into bits, cleaning the engine, stripping it apart then replacing gearbox bearings and big end surface bearings and all seals down there.
New rings back on the pistons:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0068.jpg
New base gasket and rehoned cylinders back on:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0089.jpg
On the stand me and a mate knocked up one afternoon.
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0093.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0014-1.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0015-1.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0013-1.jpg
Just ignore the hammer:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0010.jpg
Freshly skimmed cylinder head:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0105.jpg
Reground valves:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0103.jpg
All the valves, springs, seals, collets etc back in:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0107.jpg
Rocker arms back in:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0113.jpg
Cam covers back in, with new chain. All the valve clearances were measured and luckily I only had to swap 2 of the shims around.
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0013.jpg
Forks stripped apart (never used those nikone seals in the end because they sent the wrong size)
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0028.jpg
New seals and oil, quick bit of polish:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0053.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0055.jpg
Bits got back from the powder coaters (wish they had masked of the places I told them to and put bolts in the holes):
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0059.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0062.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0071-1.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0070-1.jpg
New bearings for everything:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0075.jpg
New swingarm spindle from wemoto which was the right diameter but 23mm too long:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0076-1.jpg
Went to a turners to see if they would shorten it but because its hardened they wouldnt touch it. So took it into work and used the wire eroder to cut it down to the correct length:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0084-1.jpg
Et voila!:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0086-1.jpg
Headrace bearings:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0079-1.jpg
Some rubber:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0089-1.jpg
Frame/swingarm/suspension going back together:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0091-1.jpg
And the test fit of a cbr600rr tail fairing from ricambi weiss on ebay (would never ever use them again after the trouble i had with various fairings from them)
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0095.jpg
And yes, that is the dining room table Very Happy
Back outside and ready to take the forks:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0100-1.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0101-1.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0102-1.jpg
Engine back in:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0106-1.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0107-1.jpg
Exhaust on...hmmmm stainless....
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0108.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0130.jpg
Fake pazzos, bobbins, renthal grips
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0150.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0157.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0159.jpg
Fairings arrived....good work ricambi weiss....not
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0165.jpg
Disks:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0170.jpg
Stripped paint from calipers:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0173.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0174.jpg
This looks a little more tarty xD
Seriously contemplated streetfightering it:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0179.jpg
Spacer machined up to allow a press fit 52mm(i think, cant remember now) end can:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0183.jpg
Mivv Silencer:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0187.jpg
Trail fitting fairings:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0190.jpg
Link to the first running video:
https://s944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/?action=view¤t=VIDEO0010.mp4
Tarty lines to match the tarty brakes
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0273.jpg
Set of samco hoses:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0276.jpg
DID chain and talon sprocket:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0280.jpg
Mocked up seat support:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0288.jpg
Mocked up undertray:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0289.jpg
Undertray finished:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0303.jpg
Some random teasers:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/Pic1.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/Pic6.jpg
Carbon goodies:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0321.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0322.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0325.jpg
New screen and mirrors:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0338.jpg
The 3 kawasakis i've had since passing my test reunited
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0348.jpg
Subframe off for chopping and powdercoating:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0351.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0352.jpg
Painting (thanks to a friend from work)
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0362.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0363.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0364.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0370.jpg
Bottoms done black and stickered up:
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0391.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0390.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0394.jpg
And finished, apart from the foam seat which i still dont like.
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0419.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0415.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0417.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0418.jpg
https://i944.photobucket.com/albums/ad290/wilz1234/zxr%20400%20project/IMAG0440.jpg
So if you're still awake after all that feel free to throw some comments/criticism my way. I don't normally post much here but it's nice to finally add my project xD
RS50 - ZXR400 - ZXR 400 - ZX7R - Bandit 600 - NTV 650
CaNsA
PostPosted: 23:45 - 23 Apr 2012    Post subject: Reply with quote
That is bloody awesome dude.
I am seriously wanting that sort of engine work carried out on mine.
Have you posted this up on zxrworld.co.uk forums?
wilz1234
PostPosted: 23:50 - 23 Apr 2012    Post subject: Reply with quote
I was going to but everytime I signed up last year my account was getting deleted.
Its still work in progress really. Wants a good carb set up and possibly lowering the seat unit a little so the seat position isn't so high/uncomfortable
CaNsA
PostPosted: 23:52 - 23 Apr 2012    Post subject: Reply with quote
We had loadsa spammers giving us hassle.
Should be sorted now, if you sign up ill pop a note on your account.
wilz1234
PostPosted: 23:54 - 23 Apr 2012    Post subject: Reply with quote
Cheers man. I'll get on that tomorrow
haroman666
PostPosted: 00:12 - 24 Apr 2012    Post subject: Reply with quote
Frickin' sweet build dude!
I'd love to have the dedication and monies to do that.
One day maybe... Razz
Bike Bunker
PostPosted: 01:12 - 24 Apr 2012    Post subject: Reply with quote
Very awesome build... really hope to go into this much detail on mine sometime, only ever manage to do 1 thing at a time
as for nikone seals i fitted those to mine the one failed the week after against all the belief i had they would be ok, kawasaki cradley worked out best even for £20 instead of 6
fager This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
PostPosted: 09:03 - 24 Apr 2012    Post subject: Reply with quote
Nice work the only thing I will say is the tail unit is a tad too long, I think. Thumbs Up
kentpunkster
PostPosted: 13:07 - 24 Apr 2012    Post subject: Reply with quote
Top job!!! Very Happy Very Happy Very Happy
highland biker
PostPosted: 13:17 - 24 Apr 2012    Post subject: Reply with quote
good work sir! you definately have some skills Thumbs Up
past: klx 250, cbr125, SRAD 600, cbr600rr
present: uber practial r1 for the daily commute
Hetzer
PostPosted: 13:39 - 24 Apr 2012    Post subject: Reply with quote
Seriously impressive. Thumbs Up
wilz1234
PostPosted: 14:06 - 24 Apr 2012    Post subject: Reply with quote
Thanks guys!
If anyone has any experience setting up carbs properly I'd love a hand sometime. I'd imagine i could balance it myself, but wouldnt really know where to start in order to get the mixture right other than spark plug colour
Moxey
PostPosted: 20:01 - 24 Apr 2012    Post subject: Reply with quote
Very nice work Thumbs Up
Two of my mates have ZXR 400s a H and a L both look awesome but I see from this the L does suit a modern tail unit (only qualm is it looks like a ducks beak if you envision it without the rest of the bike)
Fowlersrs
PostPosted: 20:05 - 24 Apr 2012    Post subject: Reply with quote
looks like a really nice job mate, uve covered every aspect of the bike in nice detail, can I ask how much uve spent? on the original bike and bits uve added too it?
Aff
PostPosted: 20:13 - 24 Apr 2012    Post subject: Reply with quote
Very nice job, well done Thumbs Up
Electric Bike Project
Tim..
PostPosted: 20:34 - 24 Apr 2012    Post subject: Reply with quote
Nice work...but for me the seat unit doesnt fit the style of the rest of the bike
Have some Thumbs Up Karma though Wink
www.marshallracing.co.uk
Benson_JV
PostPosted: 21:07 - 24 Apr 2012    Post subject: Reply with quote
Very. Nice. Thumbs Up
wilz1234
PostPosted: 21:27 - 24 Apr 2012    Post subject: Reply with quote
Originally I got the bike for £1200, and then during my gap year while I did it up I probably spent in the region of £2k. Seems a lot but when you think theres nearly £500 of genuine kawasaki parts just in the engine alone
wilz1234
PostPosted: 21:29 - 24 Apr 2012    Post subject: Reply with quote
I think I must have a thing for modern looking bikes but I've loved the zxr ever since I got one xD
CaNsA
PostPosted: 21:36 - 24 Apr 2012    Post subject: Reply with quote
*pokes with stick*
Gazza M
PostPosted: 21:43 - 24 Apr 2012    Post subject: Reply with quote
sweet as. i'd love to do something like this, onyl time and monez atm are a bitch!
i actually quite like the look of the green/white gradient, continue that to the tailpiece and i reckon it'd look awesome!
Past: '07 YBR125, '00 GPZ500S, '99 ZRX1100, '98 CBR600 track bike, '97 ZX9R
Present: '05 R6 track bike, 140 pit bike
wildmark13
PostPosted: 22:56 - 25 Apr 2012    Post subject: great project Reply with quote
What a fantastic project, you have some great talent and connections. I have a couple of friends with zxr400s, and they do make me quite envious. I hope you enjoy riding it as much as I enjoyed your posts! Smile
Current Bikes: Honda CRF 250R, Honda CB500R
Mod 2 (pass) 14/05/12.
There is a gap of 1 year, 236 days between these two posts...
wilz1234
PostPosted: 12:53 - 18 Dec 2013    Post subject: Reply with quote
Been over a year now and I haven't really had much use out of her. I think part of the reason is that the new seat position is terrible.
I'm going to go back to a standard looking zxr shape with no pointy back end. Anyone know where I could find a solo seat like this?:
https://www.motorcyclespecs.co.za/Gallery/Kawasaki%20ZXR400%2093%20%201.jpg
Billing
PostPosted: 04:15 - 19 Dec 2013    Post subject: Reply with quote
https://item.mobileweb.ebay.co.uk/viewitem?sbk=1&nav=SEARCH&itemId=280953884545
this any good mate? Cant be too hard to do the cut out for the tail light.
The last post was made 12 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 145.58 Kb
