Gilera Dna 125 Help!
sonam_raw
PostPosted: 21:46 - 28 Apr 2012    Post subject: Gilera Dna 125 Help! Reply with quote
Ive recently bought a Gilera DNA 125 but it was put in a 50cc frame. It was working fine for the first 2 days when it was home then this morning I tried to start it and it just make a "Clank" Noise. And smoke came out from the middle section just infront of the seat.
Since then the bike hasn't started, It turnes over and battery is still good, but just no combustion. Neutral
I checked the fuel and it seems to be getting into the carb fine and then I also checked the spark plug. It turned out to be black and wet, could be oil? Neutral I cleaned the plug and put it back in but still no luck
It turnes over and very rarely combusts for like 2 seconds then stops again
Really dissapionted I havent even had it for a week Rolling Eyes
Hope you can help Thumbs Up
Usher4566
PostPosted: 09:57 - 29 Apr 2012    Post subject: Reply with quote
Does it have a spark ? Check for spark wet meens flooding either because u have weak or no spark .if you have a spark then maybe float in bottom of carb stuck making it flood all time
New cd200 benly owner
sonam_raw
PostPosted: 10:04 - 29 Apr 2012    Post subject: Reply with quote
I didnt try when it was wet but after i cleaned it up and sanded it had a spark, was a brown/blue ish color spark, and hmm yeah Confused Carb could be the issue but i have no idea how to take that thing off, its not like any other carb ive seen Neutral Thumbs Up
Usher4566
PostPosted: 10:08 - 29 Apr 2012    Post subject: Reply with quote
I only gues its carb I've never had a DNA .could be fuel injection?fuel pump can you post a picture of what you think carb is .
Usher4566
PostPosted: 10:11 - 29 Apr 2012    Post subject: Reply with quote
Just looked up on eBay they do have carb .you need to check throttle slide is closing in side carb check throttle cable fed properly.if none of them remove float bowl at bottom and check float needle .
sonam_raw
PostPosted: 10:16 - 29 Apr 2012    Post subject: Reply with quote
Il go get some pictures asap, and the thrittle seems to be fine, the whole carb will need taking apart just to access the float bowl because its positioned right above the engine, thanks for you advice though Thumbs Up
Usher4566
PostPosted: 10:33 - 29 Apr 2012    Post subject: Reply with quote
No worries don't alter any mixture screws when taking carb to bits .
Usher4566
PostPosted: 10:34 - 29 Apr 2012    Post subject: Reply with quote
Also make sure throttle slide is going down because it could b something simple like reaped throttle cable
sonam_raw
PostPosted: 11:51 - 29 Apr 2012    Post subject: Reply with quote
Ive taken some pictures of the carb and spark plug, the plug is still sparking and It looks like the throttle cable seems fine.
Im not sure how to upload immages though :S
sonam_raw
PostPosted: 11:52 - 29 Apr 2012    Post subject: Reply with quote
https://i46.tinypic.com/2yo20pk.jpg
sonam_raw
PostPosted: 11:53 - 29 Apr 2012    Post subject: Reply with quote
https://i49.tinypic.com/dfua7c.jpg
https://i48.tinypic.com/24fy8sh.jpg
Usher4566
PostPosted: 13:12 - 29 Apr 2012    Post subject: Reply with quote
Check that that is correct plug for bike ie look in book or net type in eBay DNA 125 plug see if same plug pic of tip would b better .have u tryied kick start if has one .also unscrew bowl as mentioned urlyer .and take top off think yours has a diaphram check that its not got and holes replace if it has
Usher4566
PostPosted: 13:15 - 29 Apr 2012    Post subject: Reply with quote
Make sure that fuel filter is not blocked.one in picture although think you said petrol is geting to carb .once you get that carb off and striped ime sure u will find problem
sonam_raw
PostPosted: 13:36 - 29 Apr 2012    Post subject: Reply with quote
Im pretty sure its the correct plug, it fits perfectly, in the engine and same brand as the ignition plug. The petrol goes through the filter however im not sure on the orange pipe into the carb. I was really hoping I wouldnt have to take the carb off but I will if i have to.
Rolling Eyes
Its strange because it was working absolutely fine then one morning i just got smoke and now no starting
and there are also some random revs that occour when Im trying to start it
Thanks
MyCarVsYourHe...
PostPosted: 03:34 - 30 Apr 2012    Post subject: Reply with quote
That looks like a 4T carb, I'm unfamiliar with gilera dna125's so I may be wrong, have you checked the condition/level of engine oil?
Usher4566
PostPosted: 06:33 - 30 Apr 2012    Post subject: Reply with quote
Does it have plenty of two stoke oil that orange pipe is proberly oil feed
sonam_raw
PostPosted: 20:40 - 30 Apr 2012    Post subject: Reply with quote
I got a new spark plug and after almost killing the battery it finally fired up, ahh the feeling of joy lol, although hopefully it will continue to work, thanks for the input everyone Laughing Very Happy Thumbs Up Thumbs Up
Usher4566
PostPosted: 10:20 - 01 May 2012    Post subject: Reply with quote
Good news well done never underestamate the power of a spark plug
The last post was made 14 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 94.01 Kb
