| BoYSiE |
 BoYSiE Renault 5 Driver
 Posted: 18:55 - 01 Oct 2004 Post subject: Piaggio nrg's not working?? |
Well, i was going alone for a little ride, and about 10 mins into my journey it cut out. I tried starting it on button, but that didnt work, so i tried kick starting and still no go. I called the AA and got it home, i checked that theres a spark, all ok, then i checked petrol was getting in, again, all looked ok? Took the carb off and cleaned it, stillk would not work. I did hit a big bump about 2 mins before it cut out, dont know wheather this has anything to do with it or not. I find it wired as i thought if theres a spark and petrol thens its gotta go? Well, is there anything else i should check, as i have run out of ideas.
Thanks |
| swampy |
 swampy World Chat Champion
| BoYSiE |
| swampy |
 Posted: 19:48 - 01 Oct 2004 Post subject: |
https://www.bikechatforums.com/viewtopic.php?t=32963
Have a look at this post re spark plug (sorry cant be arsed to write it out again)  ____________________ "I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." Hunter S Thompson
"Faster, faster, faster, until the thrill of speed overcomes the fear of death..." Hunter S Thompson |
| BoYSiE |
| swampy |
 Posted: 20:20 - 01 Oct 2004 Post subject: |
Could be the fuel is contaminated with water etc. Makes the plug look wet, but wont run... Best thing to do is wait for kickstart to reply lol. Sorry I cant help any more mate, but i'm out of ideas... Keep us posted though...  ____________________ "I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." Hunter S Thompson
| BoYSiE |
| divuk83 |
 divuk83 World Chat Champion
| BoYSiE |
| divuk83 |
| BoYSiE |
| divuk83 |
 Posted: 09:24 - 02 Oct 2004 Post subject: |
If the bore kit was fitted badly or the mixture was wrong it would kill the rings and posibly the piston as well. I have had piston rings last a few a few dyno runs then a few miles up the road, but that was due to daft compression!
What did the plug that came out after it died look like?
If it looks like this, covered in speckly bits then the rings have gone. https://www.divuk83.com/images/bike/plug.jpg
If it didn't look like that then what did it look like?
Dave |
| BoYSiE |
| BoYSiE |
 Posted: 12:40 - 02 Oct 2004 Post subject: |
Ok, just checked piston, and it seems that the barrel (+ piston)is sliding from left to right in the cylinder, as i think theres a problem with the little end (if thats what the barrel goes through) and the 2 rings that go around the piston at the top, have scrapped the inside of the cylinder, wearing both the rings done and the inside of the cylinder is scratched. So would that cause the bike to not start even if theres a spark?...Anyway i guess thats the problem and ill have to fit the old 45mm standard bore one when i have someone else here to help me.
Thanks for all your replies.
If it is the little end bearing, any ideas how much that costs to fix? |
| divuk83 |
| binge |
 binge Emo Kiddy
| divuk83 |
| BoYSiE |
 Posted: 21:41 - 02 Oct 2004 Post subject: |
Ok thanks, my dad fitted my bore kit. I didnt do anything to the carb setup? it had big jets in allready though so i thought that would be ok. It was only a cheap one, about £60 off ebay, ill stick my old one back on, and hope my rod bearing hasent gone.
Thanks for all your help.
Btw, it is air cooled. |
| divuk83 |
| binge |
 binge Emo Kiddy
| BoYSiE |
| binge |
 binge Emo Kiddy
 Posted: 16:26 - 03 Oct 2004 Post subject: |
Your bottom end is gone too. Did your back wheel lock up when it went because when my 100 blew the first time, the little woodruff key which holds the piston on came out and got jammed in the outlet manifold causing my back end to lock up and nearly slinging me over the bars. Second time it was ok thought, my scoot just slowed down and stoped!
Good luck mate...
Ben |
| BoYSiE |
| yambabe |
 yambabe World Chat Champion
 Posted: 19:39 - 03 Oct 2004 Post subject: |
I have been advised to tell you to check the reed petals. (they are located in the inlet rubber). if they have split/broken, you will have no compression or suction on the carbs, and this could be your problem.
If this is what the problem is, they are fairly cheap to buy (around £10) and easy to replace.
HTH! ____________________ Sod falling in love, I wanna fall in chocolate.  |
| Kye |
 Kye Scooby Slapper
The last post was made 21 years, 271 days ago. Instead of replying here, would creating a new thread be more useful? |
