'05 Kawasaki zr750 k1h
grant965
PostPosted: 21:05 - 29 Apr 2012    Post subject: '05 Kawasaki zr750 k1h Reply with quote
Hi, viewed the above tonight and thought it was real nice, only one issues, it is fuel injected but had a manual choke.
I know the bike is cat d so could it be as simple as the original switch was replaced with a cheaper one from an older year or is it possible for fuel injected to have a choke?
Also, how does it restrict?
thanks, Grant
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
garth
PostPosted: 21:18 - 29 Apr 2012    Post subject: Reply with quote
It's more a fast idle than a choke.
PostPosted: 21:39 - 29 Apr 2012    Post subject: Reply with quote
Fast idle for sure, I thought mine was a choke as it has the same logo but its defo a fast idle.
PostPosted: 21:42 - 29 Apr 2012    Post subject: Reply with quote
It's a fast idle as said by the others, and they restrict fine. Fitted with the worst suspension known to man.
grant965
PostPosted: 22:06 - 29 Apr 2012    Post subject: Reply with quote
so whats the point of a fast idle? It comes with two shocks, standard and an upgrade from a 636 or something, still fully boxed, he said Id need to modify the mount, has anyone got anymore details?
PostPosted: 22:32 - 29 Apr 2012    Post subject: Reply with quote
To idle fast I assume.
I use mine kind of like a choke, when its cold in the morning it just honks the idle up.
Sako
PostPosted: 22:36 - 29 Apr 2012    Post subject: Reply with quote
ride it first and see if it needs the shock upgrading first, aren't you still on a restriction? if so you won't need an uprated shock until you can actually get the performance needed out of the bike to outdo the standard unit.
PostPosted: 22:43 - 29 Apr 2012    Post subject: Reply with quote
Fast idle increases the idle speed. Razz
Never needed to use it on my ZX636R even in the depths of winter, and what year 636? The 2003-2004 636 shock is also useless.
DrDonnyBrago
PostPosted: 11:31 - 30 Apr 2012    Post subject: Reply with quote
My fuel injected CBR600f has an automatic fast idle.
When started cold it idles at about 2.5-3krpm, after it has warmed up (whilst riding it) for about 1-2 minutes it drops down to normal (1.3k ish).
I quite like it, means I can lazily ride out of my street and manoeuvre around the work car park without using the throttle Thumbs Up .
grant965
PostPosted: 11:34 - 30 Apr 2012    Post subject: Reply with quote
is that not just a choke?
Am I missing something but don't all fuel injected bikes has an automatic choke and so why is a fast idle needed?
PostPosted: 11:36 - 30 Apr 2012    Post subject: Reply with quote
To idle fast.
Christ, is it hard to get...really? Laughing
I makes it idle faster, when an engine is cold, it idles low. It doesn't have a carb you can flick the choke lever on. So you force it to idle faster.
grant965
PostPosted: 11:38 - 30 Apr 2012    Post subject: Reply with quote
##Paddy## wrote:
To idle fast.
lol
so am I right in saying its the fuel injection version of a choke?
it won't have both?
Sako
PostPosted: 11:44 - 30 Apr 2012    Post subject: Reply with quote
##Paddy## wrote:
To idle fast.
fast idle adjustment...the stunters favourite.
DrDonnyBrago
PostPosted: 11:52 - 30 Apr 2012    Post subject: Reply with quote
No.
A choke works in carbs to increase the amount of fuel going in, in order to richen the fuel:air mix. A fast idle works on FI bikes to increase the idle speed.
The fast idle function of my bike is a wax idle unit, a small container full of wax and a spring loaded finger that presses against the throttle pulley on the throttle bodies. As the engine warms, hot coolant melts the wax and the finger retracts, lowering the idle speed.
ALL that it does is increase the revs, in the exact same way that it would if you were to pull the throttle slightly. That is not how a choke works. Choking the inlet of an FI bike wouldn't have the same effect.
You don't need to understand it, but it's not a choke and not all FI bikes have an automatic idle adjuster. From the users view point an idle adjustment lever works a lot like a choke (i.e. push the lever when it is cold, push it back when it is warm).
grant965
PostPosted: 12:23 - 30 Apr 2012    Post subject: Reply with quote
Ah cheers thats what I wanted to know, whether or not I need to use it to start bike from cold.
Stupid me XD
PostPosted: 12:29 - 30 Apr 2012    Post subject: Reply with quote
I use mine to start from cold, it idles quite low anyway so its worth it for me.
That said... I also have a manual idle speed adjuster too Laughing
grant965
PostPosted: 12:34 - 30 Apr 2012    Post subject: Reply with quote
also, the bike is a zr750 k1h but its called differently on insurance, whys that?
z7 or z7s isnt it?
weasley
PostPosted: 12:40 - 30 Apr 2012    Post subject: Reply with quote
A choke makes the fuel/air mixture richer. A choke mechanism usually also includes a way of upping the idle speed because a rich, cold engine won't idle well (if at all).
An electronically-controlled FI system can provide a rich fuel/air mixture through controlling the injectors, so although there's no need for a choke valve in the throttle body, you still get a richer mixture until the engine gets warm. A fast idle valve is a way of helping the cold, rich engine idle smoothly and warm up quickly.
PostPosted: 12:46 - 30 Apr 2012    Post subject: Reply with quote
z7 or z7s isnt it?
It seems to be a yank one? Everywhere I type your thread title into google it finds american specs Laughing
grant965
PostPosted: 12:47 - 30 Apr 2012    Post subject: Reply with quote
##Paddy## wrote:
z7 or z7s isnt it?
nothing came up on the hpi to say imported
PostPosted: 12:56 - 30 Apr 2012    Post subject: Reply with quote
Might not be a yank model...but thats where the info comes from Thumbs Up
grant965
PostPosted: 13:00 - 30 Apr 2012    Post subject: Reply with quote
ah seller just updated me, its a z750.
PostPosted: 13:38 - 30 Apr 2012    Post subject: Reply with quote
Got a photo?
Z750
https://www.sportbikez.net/bikepics/124/medium/1247951341.jpg
You might have the Z750S
Fowlersrs
PostPosted: 19:42 - 30 Apr 2012    Post subject: Reply with quote
##Paddy## wrote:
Got a photo?
Z750
Can I ask what Belly Pan that is Paddy?, presuming thats your bike of course. Thumbs Up
PostPosted: 20:58 - 30 Apr 2012    Post subject: Reply with quote
Not mine, but either powerbronze or skidmarx Question
The last post was made 14 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 127.16 Kb
