EVERY bolt is stuck?
nathan k
PostPosted: 20:34 - 29 Apr 2012    Post subject: EVERY bolt is stuck? Reply with quote
Decided to rebuild the engine my self, have been using you tube as my guide.
now I can't get off any clutch bolts, engine bolts, had to cut off two cylinder head bolts. getting fed up now. first what could cause all these bolts to get stuck? the engine was only rebuilt a year ago, did it overheat or something?
secondly anyone fancy trying to undo the bolts? I live in the new forest and would pay whatever as long as it's less than the extortionate mechanics. getting very fed up! Mad
oh I've tried literally everything even bought a blow torch today to heat the bolts up and still no luck
The Artist
PostPosted: 20:45 - 29 Apr 2012    Post subject: Reply with quote
How hard are you trying to undo them? Have you sheared anything yet? If not, you haven't tried hard enough.
PostPosted: 20:46 - 29 Apr 2012    Post subject: Reply with quote
Get a longer breaker bar.
J4mes
PostPosted: 20:49 - 29 Apr 2012    Post subject: Reply with quote
*could* try a rattle gun to free them off. I have done this in the past but you need to make sure it's on straight and the socket is a good, tight fit because if it jumps you'll wreck the head.
Aff
PostPosted: 20:52 - 29 Apr 2012    Post subject: Reply with quote
You using an impact driver?
Electric Bike Project
nathan k
PostPosted: 21:19 - 29 Apr 2012    Post subject: Reply with quote
there's a few stripped bolts in there, some have yet to attempt cause i know i'll just strip it. have yet to try plusgas? what is it?
Sako
PostPosted: 21:25 - 29 Apr 2012    Post subject: Reply with quote
https://www.google.co.uk/products/catalog?hl=en&sugexp=gsihc&cp=5&gs_id=i&xhr=t&q=plusgas&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&biw=1600&bih=793&wrapid=tljp133573472075208&um=1&ie=UTF-8&tbm=shop&cid=12895451323782130176&sa=X&ei=w7GdT9zoJsSE2wWIyoWTDw&sqi=2&ved=0CDsQ8wIwAA#
Raffles
PostPosted: 21:53 - 29 Apr 2012    Post subject: Reply with quote
One of these things is a very inexpensive friend at times like this:-
https://ww2.justanswer.com/uploads/conservitive/2011-07-19_205403_impactdriver.jpg
nathan k
PostPosted: 23:03 - 29 Apr 2012    Post subject: Reply with quote
Thanks for the help so far,
ordered some plusgas stuff and will borrow a friends impact screwdriver tomorrow, fingers crossed!
CaNsA
PostPosted: 23:32 - 29 Apr 2012    Post subject: Reply with quote
I usually tighten them up a little first.
Just enough to "crack" seal which has formed over the years.
m1tch
PostPosted: 16:17 - 30 Apr 2012    Post subject: Reply with quote
If you have further issues it might be worth (if safe to do so) to try and bit of heat on the area as if the bolt and the metal around it are different they will expand at different rates so can sometimes losen enough, I would suggest plusgassing it first though, ive only heard good things about it
nathan k
PostPosted: 11:36 - 06 May 2012    Post subject: Reply with quote
finally got round to trying out the plusgas and impact screwdriver as was ill last weekend, worked a treat.
going to try and get a video up to explain what's wrong with the clutch as i'm thinking the engine probably dosen't need splitting.
thanks for all the help so far!
karthead
PostPosted: 11:54 - 06 May 2012    Post subject: Reply with quote
What he said. Another way to do this is to tap the screw (not too hard) with a drill bit and hammer, if you cant make it any tighter.
When rebuilding a KE125 engine i found that a couple screws were kind of bent from the central point of the screw, probably because the holes in the engine cases were off a little, or maybe just vibrations from the enfine. This may be similar to what you're experiencing with those screws...
karthead
PostPosted: 12:01 - 06 May 2012    Post subject: Reply with quote
OOOH! OOOOH! I've heard about those but i dont know what it's called. Please tell me! i need one!
Fisty
PostPosted: 12:12 - 06 May 2012    Post subject: Reply with quote
An impact driver. Or an impact screwdriver.
Do not use them on stuck fairing bolts as my mate did, putting a huge hole in the nose of his laverda.
Fatter and faster than Fret
karthead
PostPosted: 12:29 - 06 May 2012    Post subject: Reply with quote
Yeah i've heard people mentioning impact drivers but i never really made the connection. Laughing
nathan k
PostPosted: 16:28 - 06 May 2012    Post subject: Reply with quote
quick question, kinda confused on what engine oil I need to order?
it's a 2 stroke 50 (80) same engine as aprilia rs 50 etc. is it the same oil that is mixed with the petrol?
Werny
PostPosted: 18:36 - 06 May 2012    Post subject: Reply with quote
Absolutely not that oil!
You need engine/gearbox oil. I'd imagine you'll want SAE 10w/40 semi or fully synthetic. If you have a manual it will specify in there.
Hopefully someone here can tell you for certain what oil to use.
The last post was made 14 years, 192 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 108.78 Kb
