| D O G |
 D O G World Chat Champion
 Posted: 21:18 - 29 Apr 2012 Post subject: Testing a starter motor 'on the bench'. |
Hello.
I think the starter motor on my missus' Kangoo is knackered - it doesn't turn with the key, no fuses are gone, jump starting didn't help, but bump starting is fine.
So I took it out this afternoon.
I have a multimeter any easy checks I can do to confirm the diagnosis? Would like to be certin before I get a replacement.
Cheers mofos. |
 Posted: 21:20 - 29 Apr 2012 Post subject: |
I normally connect jump leads to a battery, clip the black on the casing and jamb the red on the terminal. If it jumps off the bench it's good. ____________________ a.k.a 'Geri'
| AlexW |
 AlexW Spanner Monkey
| P.addy |
 P.addy Red Rocket
 Posted: 21:58 - 29 Apr 2012 Post subject: |
Put the car in 5th (Assuming the Kangoo is a car...van thing) and rock it gently back n forth? Freed the BMWs dodgy sticky starter. Had to do it once a week mind.  |
| D O G |
 Posted: 22:00 - 29 Apr 2012 Post subject: |
It would do nowt when you turned the key, not even an attempt to turn. It has done 195k tho, so if things fail it is hardly unexpected!
I'll do the jump lead test in the morning, simple but brilliant.
Thanks all.  |
| Vincent |
 Vincent Banned
| D O G |
| D O G |
| bikenut |
 bikenut World Chat Champion
 Posted: 13:00 - 01 May 2012 Post subject: starter motor |
hi dude,
i presume you connected the red to the starter solenoid and energised it??
or
conected red lead to actual starter motor input lead or post?
feed back as could be solenoid etc........ |
The last post was made 14 years, 155 days ago. Instead of replying here, would creating a new thread be more useful? |
