front brake squeal
hellbound
PostPosted: 15:34 - 30 Apr 2012    Post subject: front brake squeal Reply with quote
changed pads, changed fluid, bled brakes.
Now every time I stop I can hear a faint squeal, same kind of noise a mini firework screamer would make but not as loud.
Didn't do it before and the pads have done 600 odd miles so they must be bedded in
Any ideas?
May you always see the road rising up to meet you and your enemies defeated in the mirror behind.
base
PostPosted: 15:40 - 30 Apr 2012    Post subject: Reply with quote
buy some Brake & Clutch Cleaner Spray clean the discs this should sort out the issue
PostPosted: 15:44 - 30 Apr 2012    Post subject: Reply with quote
Did use copper slip on the back of the new pads?
Check the anti squeal shim is seated (If fitted).
Another thing it may be is a build up of pad material on the discs. I find it can happen more during winter when I tend to brake lighter. Some good hard braking sessions..really get them sizzling has often cured many a squeak.
hellbound
PostPosted: 15:52 - 30 Apr 2012    Post subject: Reply with quote
done the copper slip, checked the squealer shim
so Violent braking all the way home Razz
Alpha-9
PostPosted: 16:05 - 30 Apr 2012    Post subject: Reply with quote
Glazed pads?
Be hard on those suckas to get rid of the glaze from gentle braking
Pretty sure mike said something like that to me, in more words
Fzr-600 1999
Walloper
PostPosted: 18:27 - 30 Apr 2012    Post subject: Reply with quote
My favourite fix for squealing brakes that have been serviced.
Drill out the pad residue/shite that builds up in the holes of the discs.
Use a drill that is a tight fit. You will find out when you see shiny material and not the black shite.
Sorted.
tlartist
PostPosted: 18:39 - 30 Apr 2012    Post subject: Reply with quote
Did you break in the pads correctly? A number of hard stops in a row? Should smell the pads burning a bit. Can't remember the procedure. Just do a search on the web. Something like up to 60MPH, then brake hard down to 10MPH and repeat.
Please see my motorcycle tire review sites at https://www.allmotorcycletirereviews.com and https://www.mototirereviews.com.
Walloper
PostPosted: 19:14 - 30 Apr 2012    Post subject: Reply with quote
Never heard of that 'procedure' until now.
I think you refer to 'burning-in' a brake.
I don't think it is required on modern brakes.
The procedure is to brake carefully for the first 100miles and allow the pads to conform to the irregularities of the worn disc/s.
Or are you taking the pish?
The last post was made 14 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 57.07 Kb
