Scratches in black plastic
Werny
PostPosted: 10:39 - 01 May 2012    Post subject: Scratches in black plastic Reply with quote
In a couple of dozy moments I managed to scratch both my mirrors (at separate times) on walls as I was moving the bike. It's left scratches in the black plastic surrounds.
Is there any way of removing them, smoothing them out so they are unnoticeable? I assume it's going to be hard/impossible as the plastic has a sort of dimpled surface finish to it and a smoothed out part would be as noticeable as scratches?
Any ideas?
Thanks in advance Mr. Green
robbyb
PostPosted: 11:28 - 01 May 2012    Post subject: Reply with quote
Never used it myself but when reading your post this was in the advert underneath
https://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=190603240457&clk_rvr_id=337948731549&item=190603240457&lgeo=1&clk_rvr_id=337948731549&vectorid=229508
Yamaha FZ8
Walloper
PostPosted: 11:50 - 01 May 2012    Post subject: Reply with quote
robbyb wrote:
That is a polish for plastic screens etc. It would remove the 'dimples'.
There is nowt you can do for it except polish it out with wet&dry to smooth it.
It is difficult to repair and normally they get replaced for cosmetic appeal.
If you don't mind then just rub it out.
You will not see it personally anyway as you sit on the opposite side. (Don't you?)
Werny
PostPosted: 12:55 - 01 May 2012    Post subject: Reply with quote
I figured that was the case, just wondered if someone had a simple and obvious method I'd overlooked.
And the scratches have been there over a year - I only see them when cleaning the bike - ie not often. Mr. Green
Thanks for the replies!
BlackBetty
PostPosted: 19:04 - 01 May 2012    Post subject: Reply with quote
halfords used to sell a plastic repair kit, would recreate the texture of the original plastic. Sold as dashboard repair or something.
2 wheels good, 4 wheels bad
Suntan Sid
PostPosted: 21:51 - 01 May 2012    Post subject: Reply with quote
Posted this before, here:-
https://www.bikechatforums.com/viewtopic.php?t=236006
To save you the trouble:-
What you need is some cabinet makers hard wax, it comes in a variety of wood colours and black, one stick is about the size of a Mars Bar.
All you need to do is shave some small pieces off the wax stick with a Stanley knife. Roll the pieces between your finger and thumb until they become soft, (the heat from your hands will soften the wax, although don't expect it to go as soft as, say, plasticine).
Once the wax has softened, work some into the scratches, don't worry if you apply too much.
Once you've filled the scratches with the wax, you can scrape any excess off with your finger nails or a plastic scraper.
Once you're happy polish over the area with some wax polish, ie Turtle wax, this will remove any smears.
This is the stuff you need:-
https://www.jpennyltd.co.uk/shopping/pgm-more_information.php?id=304
Suntan Sid
PostPosted: 07:23 - 02 May 2012    Post subject: Reply with quote
It's £5.99 + £4.95 P&P, if you ordered it from here:-
https://www.axminster.co.uk/liberon-liberon-wax-filler-sticks--50g-prod23602/
Pick the "Stick Ebony" colour!
I've seen "Liberon" branded products in most of the big DIY shops, so you can, probably, avoid the postage.
PostPosted: 10:33 - 02 May 2012    Post subject: Reply with quote
I watched a guy fix my scratched me mirrors right before my eyes. He rubbed them down a bit to give a key, then sprayed them with an aerosol which was some plastic texture coating that went on like paint. He flashed that off erith a heat gun then sprayed them black on top. I inspected then closely and I couldn't tell they had been repaired. Whole operation took 20mins or so.
Walloper
PostPosted: 10:57 - 02 May 2012    Post subject: Reply with quote
I could tell.
Razz
The last post was made 14 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 69.38 Kb
