tapping from engine
timboellis
PostPosted: 17:21 - 02 May 2012    Post subject: tapping from engine Reply with quote
Posted this over o bandit forums as well however looking for a second opinion so over the last 2-3 days and 200 miles tapping from the engine has appeared and just after a 50 mile run seems quite loud, the cam chain tensioner was just replaced so would it be the tappet clearances ?
Video if it helps https://www.youtube.com/watch?v=esDYSRXy_L0
I have already checked the spark plugs / headers etc and no air leaking.
I have dropped it off to the garage who think the same as me it may be the tappets needing adjusted.
They will be looking at it in Sunday/Monday just looking for piece of mind.
The Artist
PostPosted: 17:24 - 02 May 2012    Post subject: Reply with quote
Sounds like pistons might be going up and down
timboellis
PostPosted: 17:31 - 02 May 2012    Post subject: Reply with quote
Exactly the reason why I try not to post on here too often!!!
timboellis
PostPosted: 17:58 - 02 May 2012    Post subject: Reply with quote
Vincent wrote:
Exhaust leak?
I sealed the pipe and engine died and no leaks from anywhere def and engine noise
Mikey3
PostPosted: 21:35 - 02 May 2012    Post subject: Reply with quote
can you pinpoint its origin by casting an ear over it?
It does sound like tappets, quite bad at that mind, but does it seem louder at the cylinder head than say, the bottom end or gearbox area.
Might help you, perhaps.
Mike
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
Drake
PostPosted: 21:40 - 02 May 2012    Post subject: Reply with quote
its going to throw a rod...
timboellis
PostPosted: 21:42 - 02 May 2012    Post subject: Reply with quote
Mike
Checked with a socket extension and it appears to be coming from the head, more from the 2 centers
Mikey3
PostPosted: 21:50 - 02 May 2012    Post subject: Reply with quote
Well i'd get on with getting it checked. Best case that'll be it, worst case you can at least know for sure its not the typical story.
Mike
'04 Yamaha WR450F
Kawikyle
PostPosted: 11:57 - 03 May 2012    Post subject: Reply with quote
Maybe about to drop a valve right through your piston. Might be hitting your piston already? Oo
Curse of the GPZ; Crash - new head & piston; MoT fail - warped discs & rotted exhausts; Slip - new indicators & handlebar; Crash - bought crash protectors; Blown over - bent subframe; Dogstrike - dead pitbull, broken humerus, buggered knee, smashed fairing...& still going.
timboellis
PostPosted: 12:01 - 03 May 2012    Post subject: Reply with quote
Well time well tell will let you know Sunday/Monday.
PostPosted: 13:19 - 03 May 2012    Post subject: Reply with quote
Really? I'd expect a loud bang or crunch...
timboellis
PostPosted: 13:26 - 03 May 2012    Post subject: Reply with quote
Surley I would noticed a performance issue before hand , bike is still running fine albeit the carbs my be slightly out
timboellis
PostPosted: 18:09 - 05 May 2012    Post subject: Reply with quote
Well got the bike back and it was just the tappets needing tightened
Mikey3
PostPosted: 20:38 - 05 May 2012    Post subject: Reply with quote
At least now I know how severe the noise is when tappets go Laughing
Mike
'04 Yamaha WR450F
The last post was made 14 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 84.64 Kb
