Bike jumping out of gear
Jayy
Mr. Ponzi
PostPosted: 13:59 - 02 May 2012    Post subject: Bike jumping out of gear Reply with quote
It does this every now and again and people keep saying it's probably me catching the lever but I know it's not me.
Today, was accelerating onto the motorway, got to about 60mph and the bike jumped into neutral (I think) well, it just reved like I had the clutch held in before knocking it back into gear. I wasn't in 1st either, was more like 3rd.
Not entirely sure what happened to be honest. The bike has a quick shifter if that makes any difference?
Shaane
PostPosted: 14:45 - 02 May 2012    Post subject: Reply with quote
Probably 1 of Kawasaki's chocolate gear componetns mate. My G2 did it a few times and to my rememberance my C1H has done it once.
^^ Non had quickshifters.
Previous: 1992 DT125R
Current: ~ 2005 ZX6R C1H
Jayy
Mr. Ponzi
PostPosted: 18:36 - 02 May 2012    Post subject: Reply with quote
Went out before and did it again but this time in 1st gear. So you think it's something in the gearbox?
JoeDougieDoug...
PostPosted: 19:23 - 02 May 2012    Post subject: Reply with quote
My CBF jumps from 2nd back into neutral occasionally - I found out its because the gear wasn't engageing properly when I knocked it into place, I went over a bump and it would knock it out into the previous gear.
Shaane
PostPosted: 19:37 - 02 May 2012    Post subject: Reply with quote
Possibly mate, I went out on the C1 earlier and booted it in every gear to see if I could tempt it to do it but it was all fine. If it's doing it in different gears are you defo giving it a right good click into gear?
Like already said can sometimes slip out if its not engaged properly. I did it a few times when I did Oulton Park trackday because i didn't engage it hard enough.
Wave2k
G's Stalker
PostPosted: 19:42 - 02 May 2012    Post subject: Reply with quote
Kwaks of old were pretty crap reliabilty wise really.
ZXR400s chocolate head gasket being my ultimate favourite Laughing
Ducati 1299 Panigale
2009 Corvette C6 z51
Jayy
Mr. Ponzi
PostPosted: 20:06 - 02 May 2012    Post subject: Reply with quote
It's an 04 ZX10 C1H, don't know if there were any specific problems with that model, can't see anything on Google.
Is it possible the quickshifter has fucked up? Like it's come out of alignment or something or something loose?
It hasn't always done this, only been doing it of late.
Shaane
PostPosted: 20:08 - 02 May 2012    Post subject: Reply with quote
Try removing the QS and see if it still happens?
My 2005 C1H 636 has done it without a QS though.
Piercee100
PostPosted: 10:10 - 03 May 2012    Post subject: Reply with quote
Hows your chain tension? I found my little H100a would do this occasionaly if the chain had to much slack.
Rides: Honda H100a (Retired), VT500e (Sold), Kawasaki ZX400 (sold), Kawasaki GT550 (Sold), Suzuki Inazuma (Daily), Honda CD185t (Broken), LML Star 2t (Last run edition).
haroman666
PostPosted: 10:31 - 03 May 2012    Post subject: Reply with quote
My CBR125 did this. And to combat it; when changing gear, keep the pressure on the gear lever as you re-engage the clutch. The lever might move up a bit more, and thus it's fully in that gear.
I think it's to do with the pawl mechanism being sticky or something.
I managed to partly cure it by just taking off the lever, pawl cover etc and just greasing it all up so it could all move nice and freely.
HTH if it's relevent.
Kwaks
I'm not a fast rider
PostPosted: 11:00 - 03 May 2012    Post subject: Reply with quote
Take off the gearselector and give it a good clean, mine would refuse to into gear when it was too mucked up, sounds like yours is on the way to that, a good clean solved that.
www.cliqueycuntsmcc.co.uk
Pie-Roe
PostPosted: 11:11 - 03 May 2012    Post subject: Reply with quote
I destroyed second and third gears on an rf900 once from slamming it into those gears while wheelieing.
Didn't take long at all for it to happen.
Answer was rebuild gearbox or sell.
garth
PostPosted: 14:29 - 03 May 2012    Post subject: Reply with quote
Is the quickshifter allowing the gear lever to settle in its original position?
Kawikyle
PostPosted: 16:20 - 03 May 2012    Post subject: Reply with quote
this happened to me loads during my bike training on an ancient CG125, apparently its just a little £3 odd spring? :s
Curse of the GPZ; Crash - new head & piston; MoT fail - warped discs & rotted exhausts; Slip - new indicators & handlebar; Crash - bought crash protectors; Blown over - bent subframe; Dogstrike - dead pitbull, broken humerus, buggered knee, smashed fairing...& still going.
garth
PostPosted: 16:44 - 03 May 2012    Post subject: Reply with quote
This.
Fairly sure CG125's are exactly the same as ZX10Rs.
:troll:
Mikey3
PostPosted: 17:52 - 03 May 2012    Post subject: Reply with quote
Hornet does it from time to time, just a false neutral, sometimes followed by the a noise similar to that of engine-death, then followed by the gear you were actually looking for originally Laughing, mainly does it on hard acceleration with a pillion, so I put it down to chain tension.
Mike
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
Mellow Matt
PostPosted: 13:55 - 04 May 2012    Post subject: Reply with quote
My GSXR 600 SRAD jumped out of 2nd when accelerating hard - had to strip it down and replace a worn dog. This fixed it but it was a massive PITA and still cost me about £400 despite doing most of it myself.
1999 GSX-R 600, 1999 TL1000R
garth
PostPosted: 14:37 - 04 May 2012    Post subject: Reply with quote
I replaced an entire gearbox for less than that on my ZX9.
Jayy
Mr. Ponzi
PostPosted: 16:24 - 04 May 2012    Post subject: Reply with quote
I hear a gearbox for the 10 is about £1000 Sad
Shaane
PostPosted: 16:27 - 04 May 2012    Post subject: Reply with quote
Your not at the stage where you need one mate. You tried giving the housing cases a clean etc likes been said?
PostPosted: 19:15 - 04 May 2012    Post subject: Reply with quote
Detent pawl spring. Not likely but possible, they do break sometimes.
PostPosted: 19:32 - 04 May 2012    Post subject: Reply with quote
Mike
Well known one on those between fifth and sixth.
If it's actually jumping out of gear then it could be bent forks or a knackered drum, as said it could also just not be going in properly, so check all your linkages and stuff first.
Mikey3
PostPosted: 19:50 - 04 May 2012    Post subject: Reply with quote
That be the one!
any clues as to why?
Mike
'04 Yamaha WR450F
PostPosted: 20:01 - 04 May 2012    Post subject: Reply with quote
Mikey3 wrote:
That be the one!
Mike
They all do that sir. Just the design of the box I suppose.
Mikey3
PostPosted: 22:08 - 04 May 2012    Post subject: Reply with quote
Oh, oh dear Rolling Eyes, not a nice noise when you slam it back up into gear.
Mike
'04 Yamaha WR450F
The last post was made 14 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 126.22 Kb
