Leaking fuel - Polish/Chinese Copy of Honda CG125 (2005)
TheGimp
PostPosted: 19:48 - 03 May 2012    Post subject: Leaking fuel - Polish/Chinese Copy of Honda CG125 (2005) Reply with quote
Hi folks,
Have recently discovered that I have a fairly steady drip-drip-drip of fuel from what possibly is an overflow/drain pipe from the bottom of the carb (indicated with red arrow on attached photo). This is my first bike, so I have no real idea. The carb is a Deni PZ26. Should I be worried or should I just, for instance, tighten that screw above the arrow?
Don't really have the cash for a professional to look and/or fix, so any advice appreciated.
Cheers,
Stuart.
"We were somewhere around Barstow, on the edge of the desert, when the drugs began to take hold. I remember saying something like "I feel a bit lightheaded - maybe you should drive...."
at106
PostPosted: 21:43 - 03 May 2012    Post subject: Reply with quote
That screw is to drain the float bowl. I would loosen it (too see how tight it is) and then screw it back in it so it's reasonably tight (with a screwdriver).
If that doesnt solve it, remove the screw, then remove the float bowl and check that there is no dirt stopping the screw from creating a good seal, also repalce any possible o rings on the screw if needed.
TheGimp
PostPosted: 22:17 - 03 May 2012    Post subject: Reply with quote
Thanks at106. There was a little room for tightening. With any luck that'll be it.
Cheers.
TheGimp
PostPosted: 18:09 - 04 May 2012    Post subject: Reply with quote
Bugger. That didn't fix it Sad
Fuel now pisses out when I stop the engine until I turn the fuel tap off, and the guy in the shop (it's still under warranty, but I can't afford the time it usually takes for his garage to do the work) says it's the carb, something broken inside, needs replacement. It'll get done for free next tuesday, but still, arse.
Anybody know if this is the carb from the original Honda design, or a crappy chinese replacement?
cb1rocket
PostPosted: 21:43 - 04 May 2012    Post subject: Reply with quote
the fuel drain outlet usually double up as an overflow, so check the float needle isn't worn or that the floats are punctured.
neil.
PostPosted: 22:09 - 04 May 2012    Post subject: Reply with quote
Float might just be stuck, whip the float bowl off and have a look, see that the pin which the float pivots on is there and that the float pivots on it easily.
Ariel Badger
PostPosted: 22:37 - 04 May 2012    Post subject: Reply with quote
It is under warranty so use it. It may take a couple of days but leaking fuel could kill you in a fire ( I happily spilt methanol over my hot exhaust today but I am an idiot Mr. Green 0) also if the fuel is high in the float chamber you will be running rich and this will soot up your motor.
andym
PostPosted: 22:41 - 04 May 2012    Post subject: Reply with quote
Rather than taking the bowl off... give it a couple of taps with the handle of a hammer first and see if that sorts it.... then follow the above advice
TheGimp
PostPosted: 16:11 - 05 May 2012    Post subject: Reply with quote
Thanks for your advice folks.
It's gone to the shop for warranty repair. I'll just have to do without for a few days.
The last post was made 14 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 59.19 Kb
