It wont start
mmulvaney95
PostPosted: 22:53 - 03 May 2012    Post subject: It wont start Reply with quote
Hi i have a sukida sk50qt-11a 50cc moped and it will not start i have checked everything, it has fuel, the spark plug sparks but it just doesnt wanna start and everytime i try to start it it blows air out of the air filter pipe.
can anyone help me??
thanks
Matt
MyCarVsYourHe...
PostPosted: 03:17 - 04 May 2012    Post subject: Reply with quote
Has this problem started suddenly, or has is been a progressive issue? try taking the air filter off and blocking the air intake on the carb with your hand to manually choke it, if that doesn't work I'd move onto removing + cleaning the carb/jets.
bikenut
PostPosted: 11:41 - 04 May 2012    Post subject: wont start Reply with quote
Karma hi dude,
some pics of the bike please, showing engine, carb, end of exhaust and sparkplug.
mmulvaney95
PostPosted: 12:08 - 05 May 2012    Post subject: Reply with quote
Hi, (matts dad here) lol
well it seems the bike won`t start due to a what seems like a bent inlet valve (top one) turn the engine over by hand with kick start slowly and rocker pushes down valve but when its on the return ie the cam is bottom side of the cam lobe valve will not return untill piston knocks valve back up, now this rectified it self yesterday afternoon and the engine started and run, matt was happy even went off on his travels only to brake down a few miles away and had to walk the bike home, so my question is if this is a bent valve would it not be like this all the time? not rectify its self or has the valve turned around and its not right,i have not worked on bike engines before only cars but im guessing they both same?
https://a4.sphotos.ak.fbcdn.net/hphotos-ak-prn1/532976_10150817062553048_720403047_9810151_2032170876_n.jpg
pic of gap between valve and rocker.
Usher4566
PostPosted: 13:43 - 05 May 2012    Post subject: Reply with quote
That's a bloody big gap considering I've just done my valves and gap on mine should be 0.05 not even a mm
New cd200 benly owner
PostPosted: 13:49 - 05 May 2012    Post subject: Reply with quote
A bent valve is a bent valve. It won't straighten and it won't last long either, it'll also damage the engine and it might have damaged the guide.
Don't run the engine any more. Tear off the cylinder head and find out why the valve isn't seating. My bet is that the engine has been over-revved and there's been some piston to valve contact.
Taught2BCauti...
PostPosted: 13:54 - 05 May 2012    Post subject: Reply with quote
Its possible that the valve is damaged in such a way that it jams in one position and is free in another - i.e. when it rotates in the valve guide.
Running the engine like this will run the risk of the valve snapping and doing more extensive damage inside the cylinder, so best to have the head off as soon as possible and assess what needs to be done.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
mmulvaney95
PostPosted: 17:39 - 05 May 2012    Post subject: Reply with quote
Hi ya, matt`s dad here again lol,
have removed head to find a bent valve but no marks on piston which is good, when i removed the valve stem seal i found this,
is the head finished or can it be saved?
https://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash3/552980_10150829208533048_720403047_9816143_1573427016_n.jpg
Teflon-Mike
tl;dr
PostPosted: 20:10 - 05 May 2012    Post subject: Reply with quote
You have put an 'Imp' on a Chinese-Fake-Away'?!?!?!
Worse still... a Chinese fake-away, with a fueling problem, bought off the Chuink-meister! (hows his dog? Max?)
https://i178.photobucket.com/albums/w269/teflons-torque/030_037_Ridgeway/triptowiltshiresept09064.jpg
Big, La-ad, inee?
The frame probably twisted when he sat on it and kinked the fuel hose!
YES, Rovers, its scrap.
& the head's probably not much good either.
Get in touch with Riders or Yoevil... not far from you... do a lot of chinky bits including new cylinder heads, which at I seem to recall about £70 are probably cheaper than trying to get the guide reamed out and replaced by local M/C shop.
& I've hardly been 'Hiding' over here... Snowie brought me over with her ambition to build a Super-Dream to 'learn' mechanics. See profile, links to her 'project' thread on there.
You may remember, in explanation of the 'Teflon' pseud; on LRO, actually came from Road-Rash, and was convenient six letter user-name, when I signed up for one of the earliest bike forums, or 'bulatin boars' as they were then, circa 1995, called Planet-Bike; joining UK based Visor Down when it started up, Oh! sometime towards end of last century! & carried over to LRO when that started up, and I had bought my First Landy to haul kids and Trials-Bike about! YES I have been around THAT long that my original user name was because they databases ONLY accepted six letter user-names!
What's happened to the tudor?
mmulvaney95
PostPosted: 20:38 - 05 May 2012    Post subject: Reply with quote
well i have to say you lost me,lol okies ill see if ebay got cheep one, cheers tef. Shocked Very Happy
Teflon-Mike
tl;dr
PostPosted: 23:09 - 05 May 2012    Post subject: Reply with quote
From another post:-
mmulvaney95 wrote:
so this is where you hide now mike?lol roverv8 lro forum, Razz
Where Rovers sig gif was link to the Imps Motorcycle display team, and his posts for a certain duration were concerned with renovating an old Two-Door Rangie...
Who am I talking to, Roverv8, or one of the 'imps'?
Roverv8, bought chinky-fake-away Shinray off fellow LRO Forumer, Chunkster, wiltshire 'Laner with pooch in pic....
Shinrays are renound for being made of cheese... and he's a BIG lad... hence joke about the suggested fuel problem being he had squashed it when he sat on it!
Shinrays and Chinese takaway bikes are also renouned for being incredibly low quality, 'scrap', hence joke that yes its scrap, and the head dont look any better!
New heads are avaiolable from Riders of Yeovil, which I believe is virtually on your door-step... both you on here, and Rovers on LRO claiming to live in Wiltshire....
Or am I barking up the wrong tree, lead astray, by comment quoted above?
Clear as mud? 'Cos now I'm confuddled?
temeluchus
PostPosted: 23:28 - 05 May 2012    Post subject: Reply with quote
Mike, calm down, you're here with your friends Smile
**leads mike back to his cell**
mmulvaney95
PostPosted: 01:23 - 06 May 2012    Post subject: Reply with quote
Teflon-Mike wrote:
From another post:-
ah with you now tef,lol Embarassed Very Happy
mmulvaney95
PostPosted: 12:38 - 06 May 2012    Post subject: Reply with quote
fuel problem was sorted with a brand new carb £27 Very Happy was running very well till last week when the spark plug decided to remove its self from cylinder head,but other then that bike was doing fine. tho i have to say tef it don`t go as fast as his 250cc Yamaha at imps and he misses jumping over his team mates,lol not somthing id try on a 50cc Laughing
Teflon-Mike
tl;dr
PostPosted: 13:08 - 06 May 2012    Post subject: Reply with quote
Coming from school boy trials, presented with a cone slalom on my 'Part One', and limited steering lock, I did the OBVIOUSE thing.... I did it on the back wheel!
Gained me a round of applause, the congratualtions of the examiner and a FAIL!
I have images of him, attending modern tests, told, "Yeah, they're a bugga, not like my day when bloke just watched y' wobble round t'block... make you jump through oops they duz these days, the' doo!"
Coming back all perplexed... "Well I couldn't find any hoops Dad.... so While I was waiting for the examiner.... I set some up...... I was JUST setting fire to them...... And no! I didn't even get to take the test!
Some bloke came running out the test office with a fire extinguisher, then three fire tenders turned up, and NEXT think I know, I had a GUN to my head, and was being 'Detained' under 'Terrorism' act!
mmulvaney95
PostPosted: 15:33 - 16 May 2012    Post subject: Reply with quote
well bough my boy a brand new head for his bike(£30) starts no prob but there's tones of smoke and very little go had this with the old head to,it only since we changed the oil to service it (should have left well enough alone) im thinking along the lines of piston rings/bore but it happend to quick so any ideas? Rolling Eyes
Teflon-Mike
tl;dr
PostPosted: 15:41 - 16 May 2012    Post subject: Reply with quote
Piston Rings & Bores.
If a ring has snapped, rather than just worn out, it would 'happen quick'. Would also extra phuck the bore!
Back to Riders.... think they do big-bore kits, take them out to 142cc!
mmulvaney95
PostPosted: 16:04 - 16 May 2012    Post subject: Reply with quote
will see what his mum says,lol
cheers tef. Very Happy
fraggie
PostPosted: 19:03 - 17 May 2012    Post subject: Reply with quote
After an oil change.. maybe you overfilled ?
The last post was made 13 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 113.05 Kb
