tyre slow puncture.
burnleyman188...
PostPosted: 17:58 - 05 May 2012    Post subject: tyre slow puncture. Reply with quote
hi my SV650s has a slow puncture on the rear tyre, is there any quick fix for this or does it require a trip to the garage?
J.Cook
reckless_b
PostPosted: 18:14 - 05 May 2012    Post subject: Reply with quote
is there something in the tyre, is it leaking from the valve or tyre beading, all require different actions to repair.
40 years on the road on and sometimes off bikes with a very recent OFF
burnleyman188...
PostPosted: 18:38 - 05 May 2012    Post subject: Reply with quote
it looks like it as gone over glass, it is almost like a a small cut. there was nothing in it when i looked at it
J.Cook
reckless_b
PostPosted: 18:44 - 05 May 2012    Post subject: Reply with quote
tyre repairers take a dim view of "cuts" a small round hole is ok not sure of the size but 4mm diameter comes to mind as max size, had a cut caused by a strip of steel on the bandit a few years back, not a long cut but was "beyond" repair cost me a new tyre.
tlartist
PostPosted: 04:59 - 06 May 2012    Post subject: Reply with quote
You could also try and plug with a worm and see how it holds air. Short ride around the block and check.
Please see my motorcycle tire review sites at https://www.allmotorcycletirereviews.com and https://www.mototirereviews.com.
yen_powell
PostPosted: 07:52 - 06 May 2012    Post subject: Reply with quote
You can't repair it, the whole bike has to be replaced or you void your warranty!
XT1200Z and a DR350 in bits
burnleyman188...
PostPosted: 09:08 - 06 May 2012    Post subject: Reply with quote
i was looking for serious answers but thanks for this WONDERFUL insite
J.Cook
Babba This post is not being displayed because the poster is banned. Unhide this post / all posts.
yen_powell
PostPosted: 11:56 - 06 May 2012    Post subject: Reply with quote
In that case, if the soapy water over the damage already mentioned doesn't produce bubbles of escaping air, try using a valve tool to remove the valve core, give it a clean and replace it. Pump the tyre back up, check the pressure after an hour and see if it still loses air.
Valve tools are either built into some metal valve caps or you can pick one up at Halfords for a few quid.
https://i16.ebayimg.com/02/i/001/27/83/8ce3_35.JPG
https://www.pclairtechnology.com/Media_Products/EN/Images/22194556_TVT01.gif
PostPosted: 12:04 - 06 May 2012    Post subject: Reply with quote
A small cut in the rubber isn't such a big deal but if it extends into the carcass then it most certainly is! Up-side is that it's rare for a significant cut to give a slow puncture, it's either flat or ready to go bang.
The last post was made 14 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 65.4 Kb
