Kick start and electric start jammed
AcID ZeR0
PostPosted: 15:35 - 04 Oct 2004    Post subject: Kick start and electric start jammed Reply with quote
I was trying to start my moped on kick start as it is something I needed to know how to do then the kick start jammed it wont budge at all and the estart just makes a little noise then stops what have I done Crying or Very sad
McJamweasel
BCF Junkie
PostPosted: 15:38 - 04 Oct 2004    Post subject: Reply with quote
It sounds like you've probably seized it. That means a top end rebuild, new piston and rings, little end bearings and a rebore.
If you are OK with spannering then whip the head off and have a look. If not, take it to a garage, grab the lube and bend over.
AcID ZeR0
PostPosted: 15:42 - 04 Oct 2004    Post subject: Reply with quote
Oh dear Sad
If I was to take the panel thats near the kick start off what would I look for and do you know how much it'd cost around to get it repaired?
PostPosted: 16:18 - 04 Oct 2004    Post subject: Reply with quote
Is it stuck in the up or the down position?
AcID ZeR0
PostPosted: 16:44 - 04 Oct 2004    Post subject: Reply with quote
Up, I relised after that the kick start has an extention on it which comes out like a peg, I was kicking the kickstart with the peg in so I was kicking the base of the kickstart could I have bent it or something as I was kicking at an angle to so I would have been kicking it into the side of the bike.
AcID ZeR0
PostPosted: 17:13 - 04 Oct 2004    Post subject: Reply with quote
If the engine has seized would I be able to tell somehow without stripping it down? because I'm a complete newb on bikes.. Would I be able to push it and hear a sound or something
PostPosted: 17:15 - 04 Oct 2004    Post subject: Reply with quote
I'm 99% sure that the engine has seized. Take it to a garage and get them to have a look.
PostPosted: 17:35 - 04 Oct 2004    Post subject: Reply with quote
It is not really that likely it has seized if the engine wasn't running at the time.
What bike is it?
My guess would be that the kickstart mechanism has jammed, locking the crank in position and also stopping the electric start working (as the crank cannot turn).
If you are feeling mechanically able I would remove the kickstart lever and then remove the engine cover (likely to release the gearbox oil) and examine the kickstart mechanism. My guess is that the kickstart acts on the clutch basket (if not an automatic clutch).
cagiva gezzer
PostPosted: 18:06 - 04 Oct 2004    Post subject: Reply with quote
What bike? Anyway, i agree with ^^^
mrchips
PostPosted: 18:11 - 04 Oct 2004    Post subject: Reply with quote
If it made a funny noise and locked up on you last time you were out chances are you have siezed, if you remember that sort of insignificant detail.
cagiva gezzer
PostPosted: 18:21 - 04 Oct 2004    Post subject: Reply with quote
When a engine seizes it doesn't lock up for long. The piston shrinks and everything moves freely.
AcID ZeR0
PostPosted: 18:26 - 04 Oct 2004    Post subject: Reply with quote
Hi, it's never locked up before I've never had any probs with it before untill i tried the kickstart it's a piaggio nrg
PostPosted: 18:32 - 04 Oct 2004    Post subject: Reply with quote
Mumbles about a seized main bearing on a Gilera CX125 where the metal cage broke up.
Ghost_rider
PostPosted: 19:23 - 04 Oct 2004    Post subject: Reply with quote
Hi acid zero, my friend has a moped and his engine seized and he took it to a garage and the repair cost about £160. If you are unfortunate and it turns out your engine is seized that gives you an idea of the cost of repair. But it is most probable your engine isnt seized and there is just a glitch somewhere. Thumbs Up
PostPosted: 20:16 - 04 Oct 2004    Post subject: Reply with quote
Yep, sounds to me like the kickstart mechanism has got itself in a tangle, taking it off and putting it back on again SHOULD fix it, at worst, you may have bent something in there.
Taking the sidecover off the engine should reveal what has happened, there is a fair chance various bits on the end of springs will fly out when you remove this cover. Given that you are a complete novice with a spanner (I assme) you may want to get some help with this, it is not a big job but could be fiddly...it is difficult to see something that has gone wrong if you don't know what it was supposed to look like in the first place.
PostPosted: 20:18 - 04 Oct 2004    Post subject: Reply with quote
Trump that with a SNAPPED! conrod in an XTZ660 engine Shocked
AcID ZeR0
PostPosted: 20:46 - 04 Oct 2004    Post subject: Reply with quote
I couldn't take a look at it if I wanted 1. The nuts are in hard to get to positions 2. I'm a complete noivice and the thought of fiddling with the engine quite frankly scares the cr@p out of me Embarassed. I'll book it in with my local garage they'll come and pick it up for me and everything hopefully they don't try and say I need a brand new top end if it's just the kickstart bent or something.
Thanks for all your help guys I'll let you know how it goes.
PostPosted: 21:19 - 04 Oct 2004    Post subject: Reply with quote
Probably with similar effects to this:-
https://www.alfa-pages.co.uk/TempPicture/piston.jpg
That is the piston from Charlottes old CB125T which snapped a con rod.
The last post was made 22 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 99.63 Kb
